desron48 wrote:
chris......one good trick i learned....before sanding is to put a thin layer of spackel over the entire hull...then coat inside the hull with resin or epoxy the spackel keeps the resin from seeping out side the hull this also locks the planks so they won't shift on you when your sanding.
....joe.....btw hulls looking exelent.....
Thanks Joe! Let's say I was looking into epoxy... What's the best epoxy to buy that will hold up for this purpose? I mean, I know there are some model rocket guys that are using this stuff:
What do you think?
Dave Wooley wrote:
Wow Dave, Thank you so much! Well, Ive never tried to attack anything quite like this before. So, prior to construction I did several adhesive tests using every kind of glue I could get at the hardware store. I then took these test panels and abused them severely. No kiddin', I threw these things around the shop, twisted them, pried on them and even whacked them with various blunt objects. The neighbors probably thought I was mad!
The ONLY one to hold up, and to my surprise was the one built with plain old "Super Glue". Don't get me wrong it DID break but the super glue never separated, the wood broke away from it. I was sold.
So, long story short, it's all held together with super glue. And I figured since I'm going to apply a coating over the entire hull that it should hold up just fine. Although, I have to tell you... I have always been guilty of over engineering things.
trigrodge wrote:
hi ccain,
your hull looks fantastic, i've never built a hull from scratch before but want to give it a go when my other projects are done, so trying to gather as much info as possible, am i correct in thinking this is just a plug for a fibreglass hull or will this be the actual hull?
many thanks
leigh
Hi Trig...
Nope, not a plug. She's gonna get a coating (to be determined later) and this hull will be used as the actual hull for the build. Good luck with your build!
hey chris......tell ya the truth iv'e never used epoxy....i've used polyester for many many years....my fiberglass supplier keep trying to sell me on that west epoxy but it's very pricey.....any way i would use some thing that can saturate the frames and planking real good and dry hard as a rock....maybe some one else has good points to say bout epoxy.....joe
