Dear All,
well I have finally taken the plunge and have embarked on my first real scratch build. I am afraid this build will be a little slow, as I am still working full time, traveling quite a lot (with work) and doting on my new grand daughter way too much
So, the details, a Russian Slava Class, based on Ozpirates plans, I will use George at Sitek for the running gear, and Action Electronics for the control stuff. I am building a plank on frame hull, to be skinned with 2mm ply and a Fiberglass mat coating and probably way too much bog.
Frames are 6mm marine ply, the main keel is 12 x 12mm oak and the focsle and quarter deck keels are 6mm marine ply.
I currently have 3/4 of the frames traced and cut, the main keel is cut and on the build board and the focsle keel is attached to the main keel. (This is the only part currently fixed in place, the rest of the images show dry fit only.)
First image are the focsle frames.
The next few images show various shots of the fore end frames dry fitted into the focsle part of the keel.
The couple of shots show the main keel being connected to the focsle keel and installed on the build board
I will assemble all of the frames with the keel down. once this is done I will invert the hull, and stand the hull on the "pegs" you see. I am hoping this will make skinning and forming a little easier.
The underwater stern section of the Slava is a little complex, with a neat tunnel down the Centre line. Above the water we have the door in the transom for the towed decoy or VDS, not sure which one. and the transom is inclined. I am planning to "carve this piece in Balsa and attach the structure to the last vertical frame. If anyone has any better ideas would love to hear them.
Next weekend I am off down the coast a few hundred klicks to attend a model show and have some time out. So not much will be reported for at least two weeks.
Feedback is always welcome. Please do not be too hard n a rank novice....
Andrew
