It is currently Sun Aug 03, 2025 9:01 pm
 Post subject: PLASTIC Hull Banana Fix?
PostPosted: Fri Jan 15, 2016 1:30 pm
As the title says, how do you fix a PLASTIC hull that's decided to emulate a banana? Will the same, "heat and press" method for resin hulls work or is there another way?
PostPosted: Tue Jan 19, 2016 6:40 pm
Any ideas at all guys?
PostPosted: Tue Jan 19, 2016 7:02 pm
Online
1/700 destroyer: viewtopic.php?f=4&t=160829&p=674789&p674789
1/350 Academy Graf Spee: viewtopic.php?f=4&t=78882
1/350 Tico: viewtopic.php?f=4&t=62649
The first one is probably the most applicable, but it sounds like the technique is similar regardless of the part.
