It is currently Tue Jun 24, 2025 12:12 pm
Post new topic Reply to topic  [ 161 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Thu Feb 17, 2022 9:30 pm
Here's my 3D model of the saluting gun - should be suitable for 1/96 scale. I spent 2 hours designing them, and printing will take about 47 minutes for 3 of them!
ICBM Address: 44:78N 063:63W
PostPosted: Thu Feb 17, 2022 10:32 pm
quick question, where were those saluting guns installed in Colossus class carriers?
PostPosted: Fri Feb 18, 2022 10:16 am
Portside aft of the flight deck - just behind the round shelter for launching weather balloons.
PostPosted: Fri Feb 18, 2022 10:22 am
Here's a slightly better view - guns crews are closed up in this one, it's snipped from a larger photo that shows the crew lining the decks on the way into a harbour somewhere.
PostPosted: Sun Feb 20, 2022 2:32 am
For whom it may concern: I stumbled across these photos of HMS Venerable in camouflage, ca 1948, when she was just transfered to the Dutch Royal Navy as Hr.Ms. Karel Doorman (2), pennant QL-2. The 'V' for Venerable was retained on the flight deck for some time, only after the modernization mid 1950s this was replaced by 'D', the pennant being R81 by that time.
http://www.vlaggeschipsmaldeel5.nl/html/scheepsfoto_s_1.html
Roger Whittaker +9/13/2023
PostPosted: Mon Feb 21, 2022 12:19 pm
Are they the same as mounted on the ship in 1946-48?
Mike Bartel
PostPosted: Mon Feb 21, 2022 7:53 pm
DavidP wrote:
Should have been more specific. Are they the same as mounted on the Warrior in 46-48?
Mike Bartel
PostPosted: Mon Feb 21, 2022 8:30 pm
I suspect not - the mounts are old (very old - 1901 old) but the guns are WW2 vintage, and there are date stamps on them from 1966 indicating that's when they were assembled into the saluting gun configuration.
PostPosted: Tue Feb 22, 2022 11:34 am
That's what I need, Warrior's saluting guns, 46-48. If anyone has good photos of them, I'd appreciate it.
Mike Bartel
IHP
http://ihphobby.tripod.com
PostPosted: Tue Feb 22, 2022 4:07 pm
Hi Mike,
One of the issues of IPMS Canada's R/T (Random Thoughts) published sometime around 2010 or 2011 has an article on HMCS Warrior with what I remember to be pretty good art work and some photos. I have the issue somewhere myself but I'll be darned if I can figure out where it is right now. I don't know if the answer to your question is in the article but it might help. Maybe someone else has a smarter storage system than me (probably) and knows where the issue is in his or her collection...
I'll keep looking for it anyway.
Roy
PostPosted: Wed Mar 02, 2022 11:25 am
Roy wrote:
Hi Mike,
Roy
If someone could find it, that would help. We're not going to release the Warrior or the Ocean for awhile after all (plans have changed here) so you have some time to look. If we don't hear from anyone, we'll just release the kit without them when the time comes.
Mike Bartel
IHP
PostPosted: Wed Mar 02, 2022 10:23 pm
I'm pretty sure my copy of the issue of R/T with the HMCS Warrior article is in my storage locker. My storage locker is presently buried under a pile of snow (at least the door is). It's expected to get up to 12C this weekend so maybe I'll be able to get into the locker and look for the issue then..., if I don't drown in the melt off...
PostPosted: Wed Mar 30, 2022 1:25 am
What changes are needed to convert the IHP 1/700 Theseus kit into Korean War configuration (say 1950)? Thank you.
Hong Kong Naval Model Association
https://www.facebook.com/groups/659559407492511/
PostPosted: Wed Mar 30, 2022 3:10 am
Maybe you have some use of the photos on this page (and the next two), when a Dutch squadron was embarked on her, 1951-ish.
http://www.vlaggeschipsmaldeel5.nl/html/mld_en_hms_theseus__1_.html
PostPosted: Sun May 22, 2022 6:55 pm
Thank you NavyShooter
If I am going to make a 1945 HMS GLory, should I add salute guns?
There were three guns on the platform right?
PostPosted: Tue May 24, 2022 11:03 am
Almost every warship carries salute guns, in that time period these were permanently fitted in the shape of 3" guns from WW1 vintage. So yes.
PostPosted: Wed Jun 29, 2022 9:23 pm
I found a picture of HMCS Bonaventure's Saluting Guns.
It confirms my suspicions that the RCN is still using these guns and mounts today.
NS
25439896_10156127888922642_4104995891096846761_o.jpg [ 254.86 KiB | Viewed 5465 times ]
PostPosted: Thu Jun 30, 2022 1:09 am
It confirms my suspicions that the RCN is still using these guns and mounts today. NS
Today? The photo is showing Bonnie, I thought she was reduced to razor blades in Taiwan early in the seventies! Fifty years ago. So what makes you say these guns are still being used today, anno 2022?
PostPosted: Thu Jun 30, 2022 1:33 am
Probably he means they look pretty much identical to the ones on our MCDVs and Halifaxes when installed:
https://i.redd.it/z6a28563ku751.jpg
https://i.imgur.com/uN47tOq.png
PostPosted: Thu Jun 30, 2022 6:44 am
I'm quite certain they are the same guns. I've got detailed photos of 5 of the ones we still use today in the RCN - I took them in my role as Tech Services Chief in Base Logistics, and have actually had contact with the LCMM (Life Cycle Materiel Manager) in Ottawa about them in the past. I just sent him the above picture this morning.
Compare the access panel and data plate location on this picture from 2018.
I think this might actually be the gun seen on the left of the photo from the 60's.
NS
