It is currently Sat Jul 12, 2025 1:41 am
Post new topic Reply to topic  [ 790 posts ]  Go to page Previous  1 ... 36, 37, 38, 39, 40  Next
PostPosted: Mon Jan 31, 2022 3:38 pm
For the 1/350 fans out there:
https://www.shapeways.com/shops/small-d ... UYrW-RzVXk
Found the hint on Ray Bean's Facebook page (Eyes of the Fleet 2)
PostPosted: Fri Jun 03, 2022 6:01 pm
Greetings,
How is your 1/700 "Beehive" Island going?
Mark
PostPosted: Sat Jun 04, 2022 9:22 am
the 3 d printed version of a last combat 1/700 scale USS CVN 65 Enterprise
PostPosted: Sat Jun 04, 2022 12:34 pm
Who makes this?
PostPosted: Sat Jun 04, 2022 1:23 pm
It is basically a 3d printed kit. You get it from globaltoy/ eBay.
I made a lot of additions to the basic kit you got from them.
PostPosted: Sun Jun 05, 2022 4:14 am
Hi Red,
The printer does an early version:
https://www.ebay.com/itm/175258164436?h ... SwmV5iaB0Q
And the later version:
https://www.ebay.com/itm/184936838459?h ... Swkllg60jU
It looks like it needs work here and there but a pretty good starting point. I think that I would still like to see Collector#1's Island on a Forces of Valor kit.
Mark
PostPosted: Sat Jun 11, 2022 12:39 pm
Hi guys,
currently I'm really exhausted with this project. I tried to make separate pieces to get good results on the surfaces, but I stopped somewhere in between.
But I can offer you the CAD/STL-files if you are able to print.
And I can offer them in different time frames - maybe you can spot the differences in the pictures (1962 and 1974).
PostPosted: Mon Jun 13, 2022 4:24 am
Greetings,
Your designs look really good. I wonder if Steve Larson, "Model Monkey", could take it to the finish line?
Mark
PostPosted: Wed Jun 15, 2022 1:51 pm
BTW,
does anyone know what those housings on the island are?
File comment: Housing at starboard above unrep station from 1968 on
File comment: Housing at aft end from launch until 1966-06
PostPosted: Wed Jun 15, 2022 4:22 pm
Greetings,
The lower pic is a SPN-8 I think.
Here is another Pic of one on the Lexington CVA-16.:
https://www.radartutorial.eu/19.kartei/ ... 055-01.jpg
Mark
PostPosted: Thu Jun 16, 2022 10:39 am
The Top pic is a compass. There is one on the other side as well.
PostPosted: Thu Jun 16, 2022 3:59 pm
I meant the big housing where the compass is mounted onto.
PostPosted: Thu Jun 16, 2022 7:12 pm
It appears to be the main support for the ECM framework on that side. It most likely has the ECM Electronics and power supplies inside.
I've noticed other ships like Bainbridge DLGN-25 and Long Beach CGN-9 got similar sized structures supporting the ULQ ECM in the same time period.
Darren (Admiral Hawk)
PostPosted: Sat Apr 22, 2023 2:15 pm
USS ENTERPRISE (CVN-65) 1:350 scale, thirty nine inches. A Tamiya kit. About 56 hours to build.
⚓️ U.S. Navy 1965-1969 ⚓️
PostPosted: Fri Apr 28, 2023 7:33 pm
What are the thoughts on the various layouts of the Enterprise's hangar deck that folks have done? Many of the aftermarket decks, including the drawings by Tom Pope depict a rectangular deck. However, in this post:
viewtopic.php?f=46&t=8817&start=240#p425251
...as well as the associated drawing, show the deck as NOT rectangular.
This seems like a cool kit, but I'm wondering about how realistic it is:
https://www.larsenal.com/1-350-ss-enter ... 2x29738723
Is the answer "To each their own?"
Thoughts? Thanks - Frank
PostPosted: Sat Apr 29, 2023 11:26 am
The problem is, you aren't going to get official drawings. That means you have to go by visual clues.
Here's my take on it.
1) The hangar walls are not the same as the hull sides. ie, there are rooms between the outer and inner walls. (bulkheads if you want)
That means that the hangar doesn't have to conform to the outer lines of the hull.
2) The Saratoga BoGP drawings show narrowing of the aft and fwd end of the hangar walls. She is a 'supercarrier' designed and built in the same era as Enterprise.
https://maritime.org/doc/plans/cv60.pdf
3) Naval Designers aren't going to design a curved inner wall unless they have to. Angled walls, yes. Curves not so much. Does that mean it's impossible, not by a long shot, just not likely in my opinion.
4) and finally, the rectangular offerings are perfectly suitable for a 1/350 model, unless you intend to remove the flight deck for viewing. You will never be able to tell if the fwd and aft sections are narrower.
Here are photos of CV60, CVN65 and CVN68 highlighting what I think are changes in the hangar wall direction.
Also included is a drawing from a training manual showing a curved hangar wall. I've come across errors like this in manuals before, The person creating the drawing doesn't care how accurate it is, as long as it gets the point across. I've added what I think it actually looks like.
And finally, overhead views of the flight decks. Interestingly, All the elevators have straight inner edges, except the furthest fwd one on Enterprise. Angled to match the hangar or hull? probably. The other ships have the door landing interface compensating for this.
PostPosted: Wed Dec 27, 2023 5:14 pm
I'm trying to create a better LSO platform area on my TAMIYA Enterprise carrier. The below pics are of the LSO area on the Gerald Ford class carriers. But the black colored "basket" for lack of a better word is fairly common on the LSO area on US Navy carriers. How can I create this for my Enterprise carrier? Is there an aftermarket set available or not? If not, then any tips and techniques for scratch building this?
337543160_956920218647164_4092909534379654313_n (1).JPG [ 85.42 KiB | Viewed 10154 times ]
278868446_2721279191337880_156685901644188392_n (1).JPG [ 108.69 KiB | Viewed 10154 times ]
PostPosted: Wed Dec 27, 2023 7:09 pm
Correct. Lots of space, for reasons, between the shell and inner hangar bulkheads. Top is FORRESTAL class looking aft, frame 123/124 and bottom is a NIMITZ class looking forward frame 78. That area in the NIMITZ is just forward of the hanger proper in shop space area.
PostPosted: Thu Jan 25, 2024 9:47 pm
Does anyone have pics of the focsle by chance? There are some in the detail & scale book but they are small and in black & white. I searched on here but nothing came up so hoping someone might have them from a tour or other sources. I’m modeling the Kitty Hawk right now so any of the class would be good.
Chris
PostPosted: Fri Jan 26, 2024 1:11 am
How would you model the fo'c'sle? I didn't even think a postwar carrier would have a fo'c'sle, but I guess it makes sense to still call the anchor chain handling deck that. Here's a pic of Kitty Hawk's: https://www.alamy.com/stock-photo-03102 ... 17542.html
