It is currently Fri Jul 18, 2025 12:00 pm
Post new topic Reply to topic  [ 232 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12  Next
PostPosted: Tue Oct 11, 2022 3:46 pm
New video posted 3 hours ago:
https://youtu.be/f1dmphXh8qc
Pascal
PostPosted: Sat Oct 22, 2022 11:08 am
I'm doing some research for a possible future project (1/700 USS New York) and had some questions regarding her Ms31 scheme. Looking at the trumpeter kit online the included painting diagram shows the camouflage pattern mirrored on both sides and using what looks like 5L, 5O, and black. Looking at navsource the camouflage pattern drawn up by the Navy is different side to side and using 5H, 5O, and 5N.
I'm guessing trumpeter is wrong and I should go with what the Navy designed? Anyone know where trumpeter got their info from? In my short search so far I haven't found any pictures of the port side of the ship, is this why trumpeter decided to mirror the pattern? Looking at the ship camouflage website it specifies 5H, 5O, and black for the colors. Which colors did New York ultimately use? I'm leaning towards the 5H, 5O,and 5N specified on the navy's drawing.
-Abram
ModelWarships Gallery Page
Joslin Models Facebook Page
PostPosted: Sat Oct 22, 2022 1:02 pm
I have David Doyle's book on BB-34 New York, and if you look closely at the photos, the waterline is much darker than the darkest color in the pattern so I think 5-N is correct per the USN camo drawing. Some info here at the USN Dazzle site:
some photos:
https://www.usndazzle.com/ship.php?id=106
Navy camo plan:
https://www.usndazzle.com/design.php?ca ... for_num=34
Ed R
PostPosted: Sat Oct 22, 2022 1:41 pm
Unless they deviated from the design, it really was (mostly) mirrored.
Starboard:
http://www.navsource.org/archives/01/013401l.jpg
Port:
http://www.navsource.org/archives/01/013401m.jpg
New York also shows just her starboard in most photos. Here's a little bit of port:
http://navsource.org/archives/01/034/013402z.jpg
Per photos (both New York and Texas), that's definitely not Black in the pattern.
http://www.navsource.org/archives/01/013501c.jpg
http://navsource.org/archives/01/034/013412.jpg
Always cross-check Trumpeter (most manufacturers, really) with more authoritative sources when it comes to ship colors and schemes. Some of the specialist resin companies apply that level of effort to get it right, but I have yet to see a major injection manufacturer indicate a paint choice that seemed off but turned out to be correct (again, as far as ship kits are concerned; and this is only in my own experience)
And, of course, don't forget the tendency - sometimes even pressure - to specify choices from certain paint lines, and in colors that are readily available in said lines. Both from cross-marketing agreements and from the simple desire of the ordinary modeler to just buy a bottle and go with it.
(How many times do we hear the "What is the closest out-of-the-bottle match for XXX in Tamiya? question! Although, Tamiya's Light Gray is closer to 5H than it is to 5L...)
Not that that justifies mixing up the Navy Blue with Black, mind you... :)
- Sean F.
- Sean F.
PostPosted: Sat Oct 22, 2022 11:00 pm
Thanks for the confirmation guys. When I looked at the pictures the first thing I said was "that's too light to be a black color". I always forget Texas also wore the dazzle scheme too, although for a much, much shorter time period.
I just remembered that I probably have the New York and Texas books on the shelf, guess I should actually look at my references I have on hand
-Abram
PostPosted: Sun Oct 23, 2022 12:24 am
Battleship Texas
8 h
Howdy y’all, we are back with our weekly report of the work going on around the Battleship Texas.
As we’ve said before, the foam removal continues on the starboard side blister tanks. Things are starting to move like clockwork now as they begin to move past midship. Along with the foam removal of the blisters, the foam removal around the stern continues as well. The large trimming tank has been mostly cleared and the last bit of foam seems to be coming out now. The smaller tanks around the stern have also had the removal process started and some hot work is starting to begin in the spaces which have been cleared.
The blister removal that has been ongoing as the blister tanks are cleared of foam has been moving forward at a quick pace. So far, the blister on the starboard side has almost made it to around frame 60. The ship's hull which is slowly being revealed is looking rusty but overall, good.
More parts of the hull are being cut open to expose the inner bottom tanks with work starting on the A section this week. Once they are all done, the process of cleaning them out and coating them to protect the steel can begin.
This week was particularly notable as the first 5” gun from the ship’s secondary battery was removed on Friday. The gun was lifted out of the mount and pulled from the gun port over the course of many hours. Once all the guns are out, we can start the process of moving them to our offsite warehouse to work on them alongside the ship’s AA guns.
We are grateful your continued support in the restoration efforts of this dreadnought. Thank you and “Come on Texas”!
Pascal
PostPosted: Wed Nov 23, 2022 7:32 am
https://youtu.be/S9gW0eKYZzI
Pascal
PostPosted: Fri Jan 06, 2023 1:09 pm
https://youtu.be/gzGaC3ahve8
Pascal
PostPosted: Sat Jan 07, 2023 10:00 am
Sorry for the silly question, but what am I looking at on the underwater cleaned section of USS Texas - bare black metal, or black primer, or black antifouling paint?
PostPosted: Tue Jan 31, 2023 2:35 am
Hello
Does anyone knows where can I find original drawings for antitorpedos bulges. Now there will be news.
PostPosted: Wed Feb 01, 2023 7:49 pm
I believe I read it is a coating they applied during her last drydocking
PostPosted: Sat Feb 04, 2023 6:51 pm
https://www.youtube.com/watch?v=fJf2KxQ5H6c
Pascal
PostPosted: Fri Feb 10, 2023 3:18 pm
Standing on the first blister module before it is welded to the ship.
Pascal
PostPosted: Sat Feb 11, 2023 5:01 pm
We had to turn a 5” gun this morning as it was in the way of the crane but it was well worth it! The second torpedo blister module is currently being fitted to the hull.
Pascal
PostPosted: Thu Apr 27, 2023 2:37 pm
Les travaux avancent bien:
https://youtu.be/z1lL9m8Wh18
https://youtu.be/aSHtC90XAAM
Pascal
PostPosted: Thu Apr 27, 2023 3:20 pm
The view of the port side inner hull without the blister is fascinating.
PostPosted: Sat Aug 19, 2023 2:13 pm
What a great job!
August 4, 2023.
Nice movie.
Battleship Texas USS Texas 5 Minutes of Raw Unedited Drone Footage At Gulf Copper Dry Dock:
https://youtu.be/3SRgk9My8II
Pascal
PostPosted: Wed Aug 23, 2023 11:52 am
Wonderful update on this huge project!
I wouldn't be surprised if the renovation exceeds the original (non inflation) cost of Texas.
Thanks! Tom
PostPosted: Fri Sep 22, 2023 7:15 am
Need some help checking Trumpeter 1/350 scale kits. If you have a Trumpeter 1/350 scale Texas or New York kit and have access to a digital caliper, please measure the diameter of the slot for the 14" turrets and let me know what you find (millimeters preferred).
Any help is hugely appreciated!
Have fun, Monkey around.™
PostPosted: Fri Sep 22, 2023 11:36 am
My cheap Harbor Freight calipers show 7.50mm. Another set varied from 7.35mm to 7.7mm. Maybe this is of some help.
Users browsing this forum: Bing [Bot] and 24 guests
