Peter H wrote:
Hi Mark
I have just gone onto your web site to briefly look at some of your builds including your USS Bataan, the LEDs are what I have seen before as you previously explained. Excellent work mate.
Another question if I may?
As I have two (2) 1/350 Trumpeter Arleigh's to build, 1 being the Momsen, I would like to have the "Remote Minehunter" area open and lit. What colour LED would you think or know would be used in this area? Yellow / Orange / Green or pale White??
Again, thanks in advance for your assistance.
Peter Hoskins
Sydney, AU
First off, thanks for checking out my site.
I found this picture a while ago
If you look at the hanger bay ceiling you'll notice two fluorescent light fixtures side by side.
One of the lights is white, and the one next to it has a red cover.
In this picture
you can see on the right side of the picture about 4 feet or so down mounted to the bulkhead is an incandescent/Mercury vapor type fixture, and below that is a RED light fixture.
I've found that a "Warm White 2900K" LED looks most like an incandescent light, where as the "White 6500K" LED looks close to a fluorescent bulb.
So to make a long post longer, to light the Minehunter bay, I'd use the smallest "Warm White 2900K" LED I could get, and I'd go with "White 6500K" LEDs in the hanger bay ceiling.
I'd love to do a ship running red, but my problem with red is even dimmed as far as it can go it's overpowering.
I did a few tests, and even tried to paint the red led with Tamiya smoke red. There is just to much light.
That's why I chose to do my hanger bay in 6500K white. This simulates fluorescent light well, and can dim without turning yellow nicely. I like the 2900K for simulating incandescent because, even though it's a white light it still shows a bit of yellow.
This is just my opinion, purely based on the pictures I found while doing research on my Momsen.
Not sure if this will help or not, but it's the best I could find on the subject.
Oh Yes, I found out the hard way that LEDs will show threw model plastic, so if you don't want your light to bleed into places it shouldn't do this
Mark
~ Chester W. Nimitz ~My Builds ~
http://ussnorthcaroilna.shutterfly.com/
