It is currently Tue Jul 08, 2025 3:42 am
Post new topic Reply to topic  [ 310 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 16  Next
PostPosted: Wed Jun 04, 2008 10:24 am
I didn't see if anyone answered Wildspears question of what Anti-fouling paint was used. I always thought that Anti-fouling Red was used. Please correct me if I am wrong. I know Testors makes an anti-fouling red paint. :smallsmile: hope this helps you out wildspear
 Post subject: Cigarette Deck
PostPosted: Wed Jun 04, 2008 12:44 pm
Could someone tell me please how did cigarette deck get it's name on US subs. I have never found any information on why they nicknamed it this. Only information I find on it is where they were located.
PostPosted: Tue Jun 10, 2008 11:03 am
Location: Connecticut, USA (Submarine Capital of the World)
I know early war subs used black. An authority on WWII subs (and a Navsource contributor) told me it was a resin based substance so a satin finish black paint would replicate that well.
Kits in dry dock:
1/400 Mirage Blyskawica (Grom conversion)
1/535 Revell USS New Jersey (from Missouri kit)
1/228 Monogram Skipjack
 Post subject: Hey Gato Class Xperts...
PostPosted: Sun Jun 15, 2008 1:12 am
Just received a 1/144 Trumpeter USS Gato recently. The 1941 version :woo_hoo:
What I wish to know is, What subs can I build her as?!? It is to my understanding that my options are limited with this kit due to the limber holes (? they the same as flood holes??)
Been at least 25 yrs since I've built a sub and am mostly an aircraft, PT Boat Aircraft carrier guy. So, any input would be appreciated!
And John@WEM... I'll be hittin yer site for some goodies too :thumbs_up_1: :heh:
You've lost everything...
On the Bench:
PostPosted: Sun Jun 15, 2008 2:55 pm
The kit depicts an "as built" early Gato, with Electric Boat limber holes. If you accept the kit parts and limber hole pattern, you are limited to a relative handful of submarines built by EB just before and early in the war. You can expand your range into Balaos built by either EB or Manitowoc by using these aftermarket resin kits from Iron Bottom Sound:
http://ibs.eastcoastarmory.com/Csets3.htm. These are all specific for the Trumpeter kit.
Additional conversion kits from Nautilus Models: http://nautilusmodels.com/Gato/144Gato.htm permit you to build either pre-Gato Tambor class in 1943 fitting, or USS Haddo (Gato class) in late 1942. They also make a photoetch set for the kit.
Tom Dougherty
Last edited by Tom Dougherty on Sun Jun 15, 2008 4:17 pm, edited 2 times in total.
PostPosted: Sun Jun 15, 2008 3:04 pm
The aft gun deck was used by the crew (are you ready for this...) to smoke cigarettes (and get fresh air)! When the submarine surfaced (usually at night) to recharge batteries, crew members came up on deck in limited numbers for a cigarette break. If the submarine had been running underwater long, the depleted oxygen content made it difficult to keep cigarettes lit. Often after long submergence, the diesels were started and the bridge hatch left open "to take a suction through the boat" and essentially change the stale, depleted air for fresh air. If only the main air induction valve was opened, the air took longer to change, as the air induction line ran directly aft into the two engine rooms.
Tom Dougherty
PostPosted: Sun Jun 15, 2008 3:59 pm
Thanks Tom, I knew I was limited "oob" Now it's onto researrching which sub ta build
On the Bench:
PostPosted: Sun Jun 15, 2008 9:53 pm
My suggestion would be to ask Mario Grima of Iron Bottom Sound. He is very knowledgable on these subs and was a great help in my build of the USS Sennet. You can find him listed in this forum as well.
PostPosted: Sun Jun 15, 2008 10:01 pm
Ok Thanks for the idea. I'll try to locate him.
On the Bench:
PostPosted: Mon Jun 16, 2008 8:12 am
Mario is a great one to ask and his products are top rate. Also go to http://www.models.rokket.biz, great site about gato's and "Rokket" is anothergreat person to talk subs with
http://www.USS-Silversides.com
PostPosted: Wed Jun 18, 2008 12:59 am
Ok I shot Mario an email and he gave me some good ideas to kick around on which sub to build. I'm kinda leaning towards the USS Grunion but, am also looking for others with an intriguing story... Darter perhaps...
On the Bench:
PostPosted: Wed Jun 18, 2008 3:13 pm
Ok, Spent a good portion of my time surfin' thru Navsource & other sites
and have found a few subs that are quite intriguing... Would these be buildable from the kit I have?
USS Darte (SS-227) at the time of her grounding
USS Grunion (SS-216) as lost 31 July 1942
USS Tullibee (SS-284) lost 36 MAR 44
USS Tang (SS-307) lost 24OCT 1944 also rescued fliers off an OS2U near Truk 1 MAY 44
USS Baya (SS-318) Jan 1944
Tia,
Eddie
On the Bench:
PostPosted: Thu Jun 19, 2008 12:05 am
Ok, after having contacted Mario I now have a better understanding as to what subs I can build. The Darter, Tang and Tullibe would be better with the 1944 version of the Gato. So, I am contemplating building 1 of 3 subs...
Grunion, Baya or Bullhead...
What y'all think I should build? I can order the Balao set from IBS for about $40 and do up the Baya. The Grunion has an interesting story behind it's loss and then being found by the captain's sons. Decisons... decisons...
On the Bench:
PostPosted: Thu Jun 19, 2008 12:33 am
I think the IBS conversion sets are awesome, and give you a sub that is more unique than the 100's of OOB builds out there. Just my 2 cents worth.
PostPosted: Thu Jun 19, 2008 12:55 am
Yea, I been looking over the IBS site and am impressed with what I have seen.
Btw, Thanks for steerin' me towards Mario for advice. He's quite helpful :thumbs_up_1:
My thoughts are beginning to lean towards the USS Baya...
On the Bench:
PostPosted: Thu Jun 19, 2008 6:41 am
How about U.S.S. Wahoo ?. Capt. Morton was one of the few commanders at the time to take big risks in the the early years of the war, essentially taking a meek (passive) force and turning it into an aggressive hard hitting force. Capt. O'Kane from U.S.S. Tang wrote a great book about his experiance on the Wahoo.
Regards, Hans
PostPosted: Thu Jun 19, 2008 12:55 pm
Regards, Hans
Hmmm, I'll have to look into this... I have been told I am limited to the boats I can build and not being a sub guy, I'm askin' for opinions on what I can build from the 1941 Gato.
Early Gato vs. late Gato I guess that is what it boils down to.
The research continues...
Eddie
On the Bench:
PostPosted: Thu Jun 19, 2008 1:55 pm
You won't be able to do Wahoo as lost for sure, but perhaps as launched.
PostPosted: Thu Jun 19, 2008 2:01 pm
Ok Tracy, since you opened the door... Why can't I build the Wahoo at the time of her loss? And, is this typical of all early Gatos? Please explain the differences.
Eddie
On the Bench:
PostPosted: Thu Jun 19, 2008 2:16 pm
Well, I'm not a Gato expert, which is why I didn't speak up before... I figured there would be someone better who could help list the boats you could do.
Wahoo at the time of her loss had been modified away from the 1941 as launched configuration... the big ones I Know about deal with the sail... look at your kit's sail and compare it to the 4th photo on this Navsource page. If you can get a conversion sail that's one thing, but I don't know about any differences in the limber holes at all... that may be an issue for you as well.
I'm doing the 72nd Revell kit and had looked at Grunion, Wahoo, Tang, and finally settled on Barb. So I have a *little* familiarity with those hulls.
