It is currently Fri Jul 11, 2025 10:44 pm
Post new topic Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jul 15, 2009 12:47 pm
Thanks for the offer of help! Any detail closeups, particularly of the areas I mentioned, would be useful.
I haven't yet decided which individual ship to build. I'm building the model more or less in standard configuration, without the additional armament and other changes made to the ones operating in the Gulf. It'll have the 25mm on the bow and .50 cal MGs on the bridge wings (the former will be scratchbuilt, the latter adapted from 1/48 aircraft spares)
Note that the text on the hull is missing the "U.S" - I'll add this later along with the hull number and name. The "Coast Guard" text, along with the crest on the stripe, was taken from a USCG aircraft decal sheet.
Model Ship Kit Reviews
PostPosted: Wed Jul 15, 2009 7:27 pm
Edward
I selected 5 photos of USCGC Grand Isle (1338) including a front 3/4 water side shot, 3 that show parts of the after deck area (all starboard side) including the crane, with and without the RIB, and a close side profile of the front 25 MM. There is a lot of clutter on the after deck, gang plank and all. They are dated 1991 and 2001. My printer can scan so I will see what happens and will send them to you over the weekend. The tall ships are in this weekend so there are lots of distractions!
Best Wishes
George
PostPosted: Fri Jul 17, 2009 8:39 pm
Edward
I got them scanned and as I'm new this photo software I went with the defaults so they are BMPs about 2 MB to 2.7 MB each. I can email them to you as I know they are over the limit for this site. I'm pleased with the scanning and it didn't leave anything behind. Otherwise I can resave them in some other format (at a lower level resolution & detail) or cut and crop when I learn how to do that.
Best Wishes
George
PostPosted: Wed Aug 12, 2009 3:51 pm
A Yeoman's job to say the least. Just beautiful !!!!!
Boy do those photos bring back memories !!!!!!
Is this the same resin model you previously showed?
I cannot even find a plastic model of a Seaplane tender to convert to CG cutter.
I was on the Halfmoon, and well remember rolling around, slow ahead, slow astern, roll, roll, roll, while the scientists were dropping their Nansen bottles and doing their Ocean work---
Glad to get back on routine patrol.
Paul Cox
PostPosted: Mon Aug 24, 2009 7:13 pm
Edward Pinniger
I hadn't seen a response from my comments of July 15 & 17 about the photos of 1338. Just checking to find out if you are still interested and how you would like to receive them. Since that time I have purchased a DSLR and therefore am gaining some experience with the software so I can put the files into a more suitable format, size, etc. Let me know what you would like.
Best Wishes
George W
PostPosted: Tue Aug 25, 2009 8:05 am
George W wrote:
Edward Pinniger
Sorry - I sent you a PM on the 18th of July regarding the photos, it's still in my "outbox" so it looks you didn't receive it for some reason.
In the meantime, I've now virtually finished my Island-class model (I found some more photos of the 25mm gun, RHIB and crane on the USCG's own site), the only area remaining, other than a few small details like rigging, is the flying bridge. Lacking any photos or drawings of this area, I'll just have to use guesswork based on photos of other USCG craft and contemporary vessels with a similar bridge design.
PostPosted: Tue Aug 25, 2009 6:32 pm
Peter
I did some cropping to reduce their size but I think the conversion into jpeg reduces the size in any case. I hope this is useful to you but good practice for me in any case as it is the first opportunity I've had to do this and upload to the Internet. Those may present rigging and bridge detail then the others.
Best Wishes
George
File comment: USCGC Grand Isle, dated Aug 19, 2001, Lunenburg, NS, Canada
File comment: USCGC Grand Isle dated Aug 19, 2001, Lunenburg, NS, Canada
PostPosted: Tue Aug 25, 2009 6:44 pm
Edward
Well that bit of cropping and uploading worked! However I will not make the gods envious as I will now have to work on your name, its Edward, Edward, Edward . . . Sorry about that. But it will keep me modest & humble over this bit of staisfaction.
Best wishes
George
PostPosted: Wed Jan 20, 2010 2:37 am
Does anyone know where I could get a WW2 Cg cutter model built for me?---at 87 the hands and mind are not steady enough to try a kit job---I was chief engineer of CG83464 at Normandy, 6/6/44----CG43(Invasion # for ease of recognition) was assigned to JunoBeach----we were one of 60 cutters attached to USCG Rescue Flotilla 1 base at Poole, Dorset------I have found outfits that make m82' Viet Nam era models but no WW2 83 footers----thanks
PostPosted: Sat Jan 30, 2010 1:22 pm
There are some drawings of WW2 amphibious CG vessels at http://www.uscg.mil/history/plans/USCGL ... ft1944.jpg
If you could identify the designation (LCM, LCP, LCVP, etc.) that might be a start. There are modelbuilders around who specialize in USCG vessels, though I don't recall any at the moment.
Lee Anne
PostPosted: Sun Feb 14, 2010 6:11 pm
Mr.PINNIGER; That sir, is one fine looking model even at this point. When she,s done I would like to see her again. I converted(for real) a coast guard bouy tender into a not so fast luxury houseboat.She sure got the looks though.Outside, with some dummy equipment she looked every bit ready to do the job she was built for.The lifting capabilities helped me help friends whose boats got swamped or damaged in collissions with fixed objects(read levees) in NOR.CAL over twelve years ago. My special love in model form is the "CAPE" class cutters.I like to think of them as motoryachts with an attitude. commodore4
PostPosted: Sun Mar 28, 2010 1:03 pm
cmomm wrote:
Does anyone know where I could get a WW2 Cg cutter model built for me?---at 87 the hands and mind are not steady enough to try a kit job---I was chief engineer of CG83464 at Normandy, 6/6/44----CG43(Invasion # for ease of recognition) was assigned to JunoBeach----we were one of 60 cutters attached to USCG Rescue Flotilla 1 base at Poole, Dorset------I have found outfits that make 82' Viet Nam era models but no WW2 83 footers----thanks
I found my 'grail'---made contact with Bill Waldorf of Waldorf Productions (believe you folks know of him) and he is going to build me my 83' WPB after he finishes his USS Indiana---seems I 'lucked out' and got one of the premier scratchbuilders to do the job since there are few plans available for that model of a WW2 anti-sub, SAR cutter----excited about thye prospect of having a museum quality model to show off at conventions, etc. and h ope3 then Good Lord spares me to see the end product----cheers and thanks to all
PostPosted: Sun Mar 28, 2010 4:51 pm
Lee Anne
You must not have looked in scratchbuild, my build of USCGC DUANE 1943. :heh: :heh: :wave_1: :wave_1:
Simple but effective.
PostPosted: Thu Apr 29, 2010 3:44 pm
Hello All
I'm late to this thread but thought someone whould enjoy this diorama. It depicts a USCG 83' patrol boat getting repaired in an English dock yard after D-Day.
PostPosted: Thu Feb 03, 2011 7:45 pm
Hey guys, does anyone know of any plans available for the 255' Cutters known as the Owasco-Class? They were classified as WPGs (gunboats) during the war and then became cutters afterwards. I'm looking to scratch build one in their as built WWII scheme and have only found a small handful of small, blurry photos and one side view drawing. Anyone have any info? I got a lead on a 1/96 scale fiberglass hull with superstructure plans from a place called "Coast Guard Models" but all their website is a catalog request feature and nothing else :(
I did find this neat postwar International Ice Patrol newsreel with scenes shot on board an Owasco.
http://www.youtube.com/watch?v=ki87QHiJYwQ
Any and all help is greatly appreciated as always.
-Mike
PostPosted: Thu Oct 27, 2011 8:28 pm
I WAS ON THE BERING STRAIT FROM 67 TILL 69 WHEN IN TAS IN VIET NAM, SHE WAS WHITE THEN AND WE PUT THE FIRST RACING STRIPE ON HER IN 67
AM INTERESTED ON WHAT YOU HAVE PUT TOGEATHER , NOT MANY PHOTOS OF HER THEN
PostPosted: Thu Oct 27, 2011 9:42 pm
Back-Aft Models
Back-Aft Models
Marcus,
Are you familiar with the model that I built of the Bering Strait WHEC-382 in 1/350 scale?
http://www.modelshipgallery.com/gallery/misc/uscg/whec382-350-cm/cm-index.html
I have a few photos of her in her gray paint scheme as well as white, with and without the racing stripe.
As a matter of fact, right now, this minute, I am working on conversion parts for the Bering Strait (some 311' Cutters in general) for the 1/350 scale Iron Shipwrights resin model kit of the USS Mackinac AVP-13.
See photos of my conversion parts progress, here:
http://s264.photobucket.com/albums/ii194/carlomaha/AVP%20Custom%20Ship%20Model%20Parts/
When I'm finished, it should be much eaiser for other modelers to convert the Iron Shipwrights kit to a 311' Cutter.
I'd enjoy swapping info, photos, plans, and stories about the Bering Strait and the others of Squadron Three.
Carl Musselman
(Formerly Back-Aft Models)
Photobucket
YouTube Channel:
PostPosted: Sun Oct 30, 2011 5:00 pm
What an awesome build! You can definitely count me in for conversion parts/kit! Your build has inspired me to buy this kit from ISW to build alongside my 2 ISW 378 post and pre-fram builds. I'd like to buy their 327 kit and build it in a late 70's or early 80's fit, but I don't think my scratch building skills are up to it!
PostPosted: Fri Dec 09, 2011 7:07 am
Hi All
I have just started a plug of the 327' Treasury Class Cutter .
[img]http://i136.photobucket.com/albums/q186/byrdman6/CG%.jpg20Cutter/CG323[/img]
PostPosted: Fri Dec 09, 2011 1:22 pm
I like the photo of Duane, :heh: :heh:
