Oct 31st 2014
I�m looking ahead to rigging the ship. Since I�ve never done any detailed rigging before, I want to avoid as many problems as I can. So I came up with a plan that changes the order of build.
I know rigging lines will snag on every part of the ship as I try to rig it. So for now, I�m only adding subassemblies I need for the rigging - the two stacks, the forward mast, and maybe the tripod mast, if it becomes clear that it will be too difficult to add it afterwards. I�ll add the practice loaders and the searchlight platform later. I�m also leaving off some details of the subassemblies; things like the antennas on the rear stack.
These photos show where things stand now. I�m still bumping up against my lack of experience, and to other novices, I�ll give this advice: just because the advanced modellers here can make super-detailing look easy, that doesn�t mean it is easy. I�ve had to be satisfied with a slightly botched result, give up on a detail, or take shortcuts, a number of times - more, as time goes on.
Sometimes I wonder: will I ever, EVER finish this kit??
Case in point: I used the kit�s plastic depth charge racks, rather than struggle with the PE, which looks a little flimsy in the Gold Medal set. I used paint to detail the racks, and was happy with the result.
I did purchase some chain that was supposed to be correctly scaled to 1/350 anchor chain; for a battleship maybe, but it is a little over-scale for this destroyer. However, I did manage to create a simple representation of what my Gearing e-book shows: one anchor chain coming out of one chain pipe, wrapping around the capstan, then going to an anchor; the other chain being just a short length attached to the anchor at one end, and pinned to the deck at the other end, with a second chain securing it.
You can see that the �1/350� chain is really to big for the capstan and chain pipe, but I�ve got to move on.
PS: you can see the seam between the deck and the hull is uneven, another legacy of the struggle I had fitting the hull, deck and deckhouse together. Luckily the Gold Medal railings have netting along the bottom, which will cover the seam. I�ve seen other builders comment on the fitting problem with this Dragon kit, and I�ve resolved my next project will be something from Tamiya - their 1/700 Indianapolis had perfectly fitting parts.
