It is currently Wed Jul 09, 2025 1:51 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 06, 2020 3:22 pm
There are two more details that were out of scale that I need to address, the bollards and chocks.
Here is my prototype.
I seriously thought about casting duplicates, but I have no experience casting. So, assembly line it is.
First I cut a strip of .010 styrene.
Then I chopped it into the right size.
Then I cut .040 styrene rod.
And lastly, I used my smallest punch to make the tops out of .010 styrene.
This is how it turned out.
Next is the chocks.
Your shipmate, Ziggy
Work in Progress: USS Arizona and Arizona Memorial
PostPosted: Fri Sep 22, 2023 11:03 pm
I have work on the Arizona wreck and memorial and I added a new twist.
I purchased a second Revell kit of the Arizona and plan to build a 'Before the Attack' diorama
Here's an up date on the 'Arizona Today'
PostPosted: Sun Oct 22, 2023 7:48 am
First off, I have not given up on this build and secondly, I have added a new wrinkle. The new wrinkle is, a second Revell 1/426 USS Arizona model built as a 'Before the Attack' diorama complete with a scratch built USS Vestal!
I will be fixing some of the inaccuracies, starting with the decks. I smoothed the bottoms of the kit decks to make patterns out of 40 thousandths styrene.
Then, I mocked them up and will add 1/350 wood deck material.
Hey David, can you help me with the hull mods, how much did you add to the blisters and hull corrections?
PostPosted: Sun Oct 22, 2023 8:50 pm
Full hull, I wasn't sure how much in thousandths you added, if you remember
PostPosted: Mon Oct 23, 2023 10:15 am
yes and yes
Users browsing this forum: 1:6000 and 12 guests
