It is currently Fri Jul 11, 2025 5:19 pm
Post new topic Reply to topic  [ 108 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Mar 16, 2022 1:39 pm
Very nice work. Like the rafts a lot. She's going to be very impressive when finished.
PostPosted: Wed Mar 16, 2022 2:28 pm
Excellent work Harpy, I had been looking at the Micromaster Pom pom directors myself but wasn't sure if the only difference was the radar which of course at the time of Hood's sinking they weren't fitted.
Is it as simple as removing the antenna's to get a good representation of the earlier design?
Keep up the great work
Pete
PostPosted: Wed Mar 16, 2022 2:54 pm
Thanks Martin, I think it's a good bang for the buck item.
Greenglade, I think so. I believe that Micro Master make a set without the antenna in a different scale. They looked pretty close to me. The only thing to be careful of is the Trumpeter's directors are pretty small and I really had to cram Micromaster's into the tubs removing a small platform on bottoms of the directors to get them to fit. It is also pretty easy to damage the directors removing the antenna. I did. I would recommend you leave them on the supports when chopping the antennas.
PostPosted: Wed Mar 16, 2022 3:07 pm
Cheers Hary
I am getting pretty used to handling Micromaster gear now, have to be very careful until painted and fitted, but boy do they look the part...:)
Pete
PostPosted: Wed Mar 30, 2022 6:15 pm
Greetings Everyone.
Quote:
Is it as simple as removing the antennas to get a good representation of the earlier design?
Mircomaster has added a set of Pom Pom directors without the antennas and added 9m Ranger finders on his site in 1/200.
The bigger directors that will go on top of the bridge structure. Pontos adds the Type 284 gunnery radar to the front DCT which was added during the 9/41 refit. On the smaller directors the long vision port should be on top. It was shown upside down in the instructions.
I left the director off the platform until the lower antenna was mounted. Will knock down some glue bumps with acetone before primer.
Nice engineering by Pontos with good fit.
PostPosted: Sun Apr 03, 2022 2:33 pm
Hello all.
Thankfully the bridge mast is not as complex as the other. Since I used the Trumpeter parts for the older style AA platform, the mast needs to be shortened by a 1/4" or so. I mentioned elsewhere it would have to be extended, that was incorrect.
Pontos deletes the compass platforms because I think they were removed and dropped down a deck in '42. I used an extra set of search light platforms to add them back.
The MM's quad Vickers added and a better peak at the signal lights. I broke off the top barrel on the Vickers, but made another.
Directors painted and test fitted.
PostPosted: Fri Apr 08, 2022 4:02 pm
Hello all.
I finally glued down the shelter deck to the hull and bridge structure to the shelter deck and can continue to populalte the main deck with everything glued down.
I got a couple of MicroMaster Pom Poms to try. My main concern was that they might not fit in the B turret tub, but that won't be an issue. Used Mr Surfacer 1500 for some of these parts as primer. Even though they are high quality prints you can see some print marks under magnifcation and in my mind, they look less fuzzy with Mr. Surfacer espesically with Colour Coats. The one pictured still needs ammo boxes.
PostPosted: Fri Apr 15, 2022 2:17 pm
Greetings all.
Pom Pom with all its parts.
Finally decided to start the main turrets. The Pontos barrels are longer the kits because they are mounted deeper into the turret to set the mantels back a bit from the openings.
Pontos gives you two shield types for high or low angles on the guns.
Edit: The mantel sides are installed backwards.
Inside turret top.
Test fit.
PostPosted: Fri Apr 22, 2022 3:12 pm
Hello everyone.
Had to flip the shield sides as they were installed backwards not allowing for the plastic support to be installed. I also made a barrel jig to help align the barrels.
Test fit of the turrets before they get finished up and the barrels set. X turret also has a duplicate of "A" turret's top brass from a partial set I had. On the Pontos X turret brass it has overhang for the 20mm tubs, again a '42 mod that would not be applicable to the 9/41 refit.
PostPosted: Mon Apr 25, 2022 9:18 am
Quite a behemoth, but very crisp job so far. Excellent and impressive PE work. :thumbs_up_1:
The merchant shipyard
PostPosted: Mon May 02, 2022 3:11 pm
Hello and Thanks Neptune. She was a beast.
Turret with all the etch and primed with Mr. Metal Primer.
"A" turre
"B" Turret painted. While drying on top of furnace the turrets began to melt, so they needed putty work and a new paint job which went poorly.
"B" and "X" turrets. They are still two-tone grey, but it is not picked very well here. Still WIP on turrets, but a lot of work is done.
A wider shot.
PostPosted: Tue May 03, 2022 4:46 am
Lovely looking build, the detail is very well executed.
Garry
PostPosted: Fri May 06, 2022 2:43 pm
Greetings everyone, and thanks Gary.
Finally getting to the 4.7" guns, some have been sitting around for almost a year.
I got some texture on the barrel, but it is a pretty tight shot.
MM's 9ft Range Finders with a bit Mr Surfacer to help find support bumps that need sanded.
All parts installed on bridge (I think). Pom Pom directors replaced after I butchered, and man handled them cutting the antennas off.
PostPosted: Thu May 12, 2022 9:00 pm
Hello, a bit more progress.
4.7" mounted then back to the main deck for hatches stowage.
The 3d printing technoloy is just mind blowing to me.
Test fit of the 45ft' boat to make sure the deck hardware is aligned.
PostPosted: Sat May 14, 2022 3:42 am
This is so mighty! Fantastic work.
One day Ill have a big enough house to.. house a 1/200 model. :heh:
PostPosted: Tue Jun 07, 2022 6:48 pm
Very impressive work. You mentioned that you used Mr Metal Primer on the turrets - did you brush it on or use and airbrush? If airbrushed, what thinner did you use?
John
PostPosted: Fri Jun 10, 2022 2:31 pm
Thanks Guys. Taking a bit of a break.
John, I used the Mr Metal Primer spray can.
PostPosted: Fri Jun 10, 2022 2:58 pm
Thank you.
John
PostPosted: Sat Jun 11, 2022 5:22 pm
Great stuff - that superstructure looks enormous!
PostPosted: Wed Jul 20, 2022 10:20 pm
Impressive work.
James
http://www.modelshipgallery.com/gallery/users/James-Guard/user-index.html
Users browsing this forum: normandie and 13 guests
