It is currently Sat Jul 19, 2025 4:26 pm
Post new topic Reply to topic  [ 95 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Jan 18, 2023 3:03 am
Wonderful! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
Just wondering: why wood for the gun port framing, but plastic for the knees?
PostPosted: Wed Jan 18, 2023 6:23 am
The wood will still be covered. But it is the easiest to sand down to adjust the angle of the lower and upper sill. Evergreen works too but is far more difficult to put into shape.
The direction is: If wood is shown in the original, I use wood. If the wood is painted, I use what ever is the most convenient ;-)
Lazy bastard I am, I know ...
XXXDAn
To Victory and beyond ...
PostPosted: Wed Jan 25, 2023 8:33 am
In the meantime, the bow is paneled. After the "take photo without card lock" of the camera was turned off, I am missing the pictures of the open subconstruction ...
First as usual the frame imitations inserted, then the whole thing was paneled.
Since the anchor cable hatches are also misaligned, those were closed up right away as well.
XXXDAn
PostPosted: Wed Jan 25, 2023 10:10 am
Lazyness is the mother of efficiency! :big_grin: :big_grin: :big_grin:
PostPosted: Wed Jan 25, 2023 2:16 pm
Online
All your work is just beautiful.
PostPosted: Thu Feb 02, 2023 6:43 am
Thanks both of you!
And then it was time for the doll's house in the rear. First of all, the width was determined.
Then the reminder that there is still a lot to squeeze together in the back. So the width must somehow remain flexible, more about that later.
The cabins in the back are represented in the kit, but not the front bulkhead to the wardroom.
The passages into the side pocket is also a bit sporty in size.
So a quick replica in the right thickness.
And in place. The door was hinged on the outside of the hull and aft like Boudriot.
After that came some paneling.
And since that was still a bit too rough for me, a printing test.
Even if the bottom fit is not yet matched it is already a bit finer in texture :-)
XXXDAn
PostPosted: Mon Feb 06, 2023 6:51 am
I'm getting the feeling you will be going as much in-depth with Constitution as you did with Vic... :big_grin:
Excellent! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
PostPosted: Mon Feb 06, 2023 10:28 am
Not that much. This time I am choosing a compromise in between detail and effort. Looking already going back to the Vic :-)
I already mentioned the problem of the bulkheads to the officers' mess and the captain's cabin. Because I still have to press the hull shells together at the top, I don't have a clean connection to the ship's side.
So I marked the beginning of the bulkhead ...
... and made a small slot in the hull. Then the bulkhead can slip in when pressed together and everything is clean :-)
Then up to the next adventure. Window bars were cut out of the rear windows.
And the first two print tests went right off the bat. I'm slowly getting the hang of it.
And then the full width, even with the minimum curve upwards in the center.
On the inside the frames between the windows also were applied, but I still need to adjust the length properly.
Next were the side galleries. The starboard side even fitted on the second try.
Port side took me two more tries, I had measured stupidly once when trying it on the first time. Probably I held the part upside down. Meanwhile I have a mark on it, so that something like that can't happen.
The paneling of the aft cabin is also a bit more accentuated, below the first try, above new.
The bench seat under the stern windows has been panelled, once it looks better and also hides the base of the planks.
Here then the ensemble, the bulkhead between officers mess and captains cabin is missing. It is only indicated by the small tail. This time I left a slot in time, one can learn. Sometimes at least ;-)
Cheers, XXXDAn
PostPosted: Tue Feb 07, 2023 3:16 am
That slot is a very clever solution! :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
The new paneling looks better indeed.
PostPosted: Sun Feb 12, 2023 5:28 am
As always thanks for the clicks and comments to the gentlemen and of course the ladies :-)
At some point I noticed again the dark hole to the orlop and also how painful I still have to suffer on my Vic because of a similar omission ;-)
So I prepared two matching blocks, took out the big tweezers ...
... and sank the blocks from above through the hole into the depth, with huge amounts of glue positioned underneath. In addition, also fixed supports to sides, so that they do not end up later as shaken goods.
Of course, there was a stowaway right away ...
.... which my little brave sailor had to drive away with death-defying courage.
Then prepared the deck ...
... for this purpose photographed a piece of deck and printed it out tiled.
Colorwise I could have done some corrections, of course, but for this purpose it does quite well. I'll put a grating or something similar over it later anyway.
But how to get the parts in there? The prepared piece of deck was fixed with a little double-sided tape to a long ruler ...
... luckily I had spotted the small gap in the stern and with a loud *yikes* rammed it inside ...
... and pressed it into the right place into the glue waiting there, aligned properly ...
... and let the gentleman of the quality control look over it :-)
Was accepted so, luck!
XXXDAn
PostPosted: Sun Feb 12, 2023 7:22 am
top man!
..... just ingenious! :thumbs_up_1: :thumbs_up_1:
cheers
JB :smallsmile:
PostPosted: Mon Feb 13, 2023 4:54 am
Thank you Jim!
At the weekend was "Dafi home alone". As children are, there was again goofing around to be done.
On the agenda was the doll's house in the back. In the kit there is only the bulkheads to the captain's cabin. But contemporary sources still show the bulkheads of the wardroom and the pantry for these two areas. Since the Constitution seems to me like a mixture of French and English influences, I looked at the various templates in the Boudriot as with all the England girls.
Also interesting is this Englishbeauty from the NMM, one of the few contemporary models where you can see the internal bulkheads.
The adaptation of the vertical structures to the inclined ship's side is very nice, but I ended up going with the classic vertical version. Interesting also the change of the height of the subdivision: at the ship's side at the level of the lower edge of the gunports, otherwise almost in the middle.
The first print came out quite usable.
The basic layout looks like this, the bulkheads in the captain's cabin are still missing.
And here are just a few impressions of what can be done. Focus on the bulkhead to the captain's cabin.
And here are a few pictures of the forward bulkhead and pantry.
Now it's on to the right fitting :-)
XXXDAn
PostPosted: Wed Feb 15, 2023 7:05 am
As somebody who has walked Old Ironsides' decks many times, I can say with complete confidence you're honoring those who served aboard her and still sail her today. Just incredible stuff.
PostPosted: Fri Feb 17, 2023 6:47 am
But not to forget the basics besides all the fascination of printing. The next step was the stern cabins layout.
Since the sources about the position of the cabins are quite "soft", I took another look at the situation. In the galley runs the mast and in front of it the rudder ropes. And food preparation should also be there. According to most sources, there is a cabinet with a worktop there, consequently the front edge has been pushed forward and the space for a small cabinet has been created.
Fits just so with the grating, although I do not know to what extent this opening is historically documented.
Inside was now the necessary place for food preparation. And doors and guns don't get in each other's way either.
The back of the captain's cabin is also nice and cramped.
For the bed, I did away with the lattice structure and provided a curved entrance in the French style.
The sofa is also now in place.
A little side note: I had already mentioned that the lattice structure gets a nice belly when printed, which almost disappears again when cured under UV light.
XXXDAn
PostPosted: Sat Feb 18, 2023 5:28 am
Quite a puzzle Daniel! Just like the real thing... :big_grin:
Beautiful work! :thumbs_up_1:
PostPosted: Sat Feb 18, 2023 6:43 am
I think Daniel should pick your painting technique and apply it to this nice panelling - not that easy for something that was presumably painted white all-over.
Eberhard
Image Image Image Image
PostPosted: Mon Feb 20, 2023 3:39 am
So far I had ever avoided, and the gun ports not yet clad inside. Was made up, so that one does not see the wooden slats and also file irregularities are concealed.
First all 4 sides laminated with 0.25 polysterol ...
... then trimmed the inside with a scalpel ...
... built a small sanding block with a handle ...
... and neatened everything.
Fortunately only 30 times and not 100 like the Vic :-)
Saved the scraps, you can still fill up any gaps with them.
XXXDAn
PostPosted: Mon Feb 20, 2023 12:30 pm
After that, I took care of the anchor hawses. In the kit, these go 90° perpendicular to the ship's axis and out downward.
Considering that the ship is driven away from the anchor by the wind on the tensioned anchor cable, there would have been a nice bend in the tensioned cable.
That's why the anchor nozzle has to sit parallel to the ship's axis with minimal downward slope. A toilet paper roll happened to be the right height and served as a rest for the Dremel.
The anchor cable has about 2 mm in my scale, so printed short semi-finished tubes with 2.2 mm inside and 3 mm outside and glued them in and then still trimmed all after that.
Then the cable was threaded ...
... and noticed, omg, there is missing the clearance. Often the anchor cables were still secured with various wrappings against chafing.
In addition, I decided that the ship is represented before 1812, and there the bridle port, the foremost port was not cut in yet. This one was not equipped anyway and served to facilitate the anchor handling. So this port was closed and I noticed that this would probably result in a nasty patchwork on the internal planking.
So came what had to come, a dafi did what a dafi has to do: Demolition!
With these cruel pictures I just want to leave you ...
XXXDAn
PostPosted: Mon Feb 20, 2023 1:14 pm
....>>> demolition.....<<<<
ARGHHH!!
.... the price of perfectionism & obsession!
:thumbs_up_1:
Good luck!
JB :wave_1:
PostPosted: Tue Feb 21, 2023 3:13 am
... at least on wooden ships and at this scale the traces of demolition can be removed relatively easily :thumbs_up_1:
Eberhard
Users browsing this forum: maurice de saxe and 64 guests
