It is currently Tue Jan 14, 2025 5:20 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
 Post subject: USS England
PostPosted: Thu Jul 26, 2012 11:54 pm
New to ship building, but here is some build progress. A lot was of ideas were taking from Timm an Ed. Using Gold Medal PE and WEM paint for the measure 21. Also stealing parts from Dragon's Uss Benson were I can. Going by Floating Dry Dock's Buckley class CD.
Hull Done. A lot of sanding as it didn't line up right
Some details added
Painted with some details added to side.
 Post subject: Re: USS England
PostPosted: Fri Jul 27, 2012 6:52 pm
Nice! This is one of the many unfinished kits I have laying around. I'm going to do her in dazzle, eventually.
PostPosted: Sat Jul 28, 2012 1:17 pm
Nice work. I can tell you did a lot of sanding on the hull. I've built a few of these and the lower hull needs tons of work to look like yours. Also your build is nice and neat so far. Keep up the good work and welcome back to modeling.
On the Bench
1/350 Independence
1/350 Dunkerque
1/350 Shimakaze
1/350 Sharnhorst Dragon
1/350 Belfast
PostPosted: Sat Jul 28, 2012 4:50 pm
I agree, have this one half built and yours looks just the ticket(right).
Get on with it and watching with Interest :thumbs_up_1: .
Cornwall UK
PostPosted: Tue Sep 04, 2012 9:27 pm
Some Bridge work.
PostPosted: Mon Oct 01, 2012 4:58 pm
Motivation has been low, but bridge and Stack mounted.
PostPosted: Mon Oct 01, 2012 10:26 pm
IF you hadnt said anything I would have never known you were new to ship building! Superb work, thanks for sharing!
-Abram
ModelWarships Gallery Page
Joslin Models Facebook Page
PostPosted: Tue Oct 02, 2012 11:19 pm
Thanks all for the kind words. Well I've bought the kit twice now just to finish 1, so I am screwing up a lot. Half my time time spent looking for parts I dropped, so my hat is off for ship modelers. Was building large scale armor, so this is a change. I think my next project will be a 1/350th PT boat. Even this little DE is a detail hog.
PostPosted: Sat Oct 13, 2012 9:32 pm
Rear 3" gun island. Front and rear gun stops added. Some K-Gun arbors were removed to make room for the door and latter.
Mast mix of WEM and GMM PE. Forgot the combat lights though.
WEM air search radar
Mast painted and mounted.
Most of the major assemblies are in place. I don't see much contrast between the Deck Blue and Navy Blue. They seem to match when the verticals are in shadow and the horizontal surfaces are in direct light. Next will all railings, guns, and the deck detail.
The Trumpeter looked like a crappy kit at first, but it really builds well. I had no fit issues except for the hull.
PostPosted: Sat Oct 13, 2012 10:03 pm
You have done a very nice job on your England and I have enjoyed following along with your build. Droping small parts on the floor is a natural part of being a ship builder.
Gordon
PostPosted: Sat Oct 13, 2012 10:27 pm
Your building sequence is very impressive and I'll be using it. The only thing I wonder about is getting the hedgehog detail in place with the blast shield at least partially obstructing it. But your work is excellent and the only errors I see are kit details.
PostPosted: Sun Oct 14, 2012 10:14 am
Thanks, guys.
The problem I had with the build sequence was with mounting the mast. Luckily I hadn't glued down the bridge and could pop that off and mount the bridge and mast together. If the bridge was glued down you would have had to bend the mast a bit which, I think, would have popped off or bent the large ladder. The Hedgehogs should have been installed a long time ago and I was looking at Timm's build and there is not much space as you pointed out. I may leave the lid off and try to slide it in separately, so thanks for the heads up. I would have built it whole then would have to chisel off guides.
PostPosted: Tue Oct 16, 2012 8:07 am
Very nice! :thumbs_up_1:
They built a lot of DEs not far from where I live, and one of these days I would like to do one. I hope it comes out as well as this.
PostPosted: Wed Oct 31, 2012 10:04 pm
12" signal and 24" search light added.
Niko Resin 3" guns with Master Barrels.
primed
installed
1.1" guns and the first of the 20mm
Got in over my head with the Master's 20mm kit tried to use what I cound though.
PostPosted: Wed Oct 31, 2012 10:52 pm
Wow, excellent work there! Keep it up.
-Abram
PostPosted: Sat Nov 03, 2012 2:38 pm
HI Harpie
I missed this mounting ,clean and detailed :thumbs_up_1: congrats for your work ,I like it !
best regards
Nicolas
PostPosted: Sat Nov 03, 2012 2:49 pm
Online
Another marvel in this wonderland, great :-)
Daniel
To Victory and beyond ...
PostPosted: Tue Nov 27, 2012 2:00 pm
Four of the 20mm in place around the bridge. The big problem I had was the kit's deck mounts for the 20mm's sat up too high. Each had to be drilled flush to the deck which was pain at this stage. I should have checked much this earlier in the build. It would have also allowed me to move the front 20mm's more forward. Shield on the lower side one needs straightened too.
Other 6 primed.
Chicago Piano
50 #79 reharpened carbide drill bits off Ebay for $12. They are super delicate, but cut through about any material like butter and don't wander.
Think these are some of the last pieces to go on yet. The Capstan Brake Wheel is mounted on .2mm stainless wire. Waiting for the 26' Whale Boat yet.
PostPosted: Tue Nov 27, 2012 5:14 pm
Looking really nice! :thumbs_up_1: :thumbs_up_1:
Bob Pink. :wave_1:
PostPosted: Tue Nov 27, 2012 5:24 pm
Some of the finest work I have seen at this scale or any other for that matter. :thumbs_up_1:
James
http://www.modelshipgallery.com/gallery/users/James-Guard/user-index.html
Users browsing this forum: JIM BAUMANN and 25 guests
