Hello everyone,
Time is scarce, so when building on this model it tends to get late, by then I snap some pictures but at 00:30am I usually do not feel like updating the log. Tomorrow is a day off so this time I can do the weekly update a little earlier.
Quite a bit has happened the past week.
1. I have finished 80% of the first level of the superstructure. All that remains is a few windowcovers, 2 paravanes and 1 or 2 stairs. The detail on this kit is mind boggling. One piece is not present in the pontos set. You can see the scratch replacement.
I love those little firehoses
The paravanes are 6 parts each. Picture is darker than I thought it was, will make a new one for the next update.
Added all pe for the main deck. And some first stuff onto the barbettes.
I am thinking about when I want to add the wooden deck, but that is probably not too far away. Means I need to do some trials on spare pieces from earlier builds for some light weathering (probably some black powder)
I have added some bowrepairs using styrene to replace the broken tip. I bent two 10x10mm pieces in a round shape. Glued them onto each other. Then sanded and cut them down to size before mounting it with a little putty and glue.
Work has been started on the second level of the superstructure
I have painted the hull red (two layers, one layer being a mix of red, brown and hull red, and one being tamiya xf9 hull red), hull grey (xf66) and boottop (xf69). I am wondering whether I should use xf24 or xf63 for the fake bow, steel decks and turret torps. The barbettes, deckdetails and anchorsplates have been sprayed with xf19. Technically I could proceed with mounting the wooden deck, but I will wait until all paint on the hull is done.
That feeling when you peel the masking tape off not knowing how it will be and then seeing a boottopping that is sharp with 0 leakage remains great. I was elated when I pulled the tape off.
I hope you all enjoy what you see. Any comment, tip, constructive critique or advice will always be welcome welcome. Some pictures are from my phone due to the camera going on strike but they should all be decent enough in quality.
MartinJQuinn wrote:
Looking forward to seeing your progress.
Reading back I noticed I forgot to react MartinJQuinn, sorry for that, but I hope you are enjkying the progress made so far
Happy modeling
