It is currently Mon Mar 17, 2025 7:24 am
Post new topic Reply to topic  [ 203 posts ]  Go to page 1, 2, 3, 4, 5 ... 11  Next
 Post subject: IJN Myoko, 1/350, 1944
PostPosted: Fri Sep 28, 2012 11:26 pm
Here is my 1944 Myoko with the Flyhawk set. Initial work includes degaussing cables and funnel work:
PostPosted: Fri Sep 28, 2012 11:30 pm
Still trying to figure this out:
PostPosted: Fri Sep 28, 2012 11:37 pm
Aft superstructure progress:
PostPosted: Sat Sep 29, 2012 9:24 am
It's looking great, Joe. What's to figure out? :smallsmile:
PostPosted: Sat Sep 29, 2012 12:30 pm
Thanks. The thing to figure out is how to post those stupid pictures! Thanks for your help Dan by the way.
PostPosted: Sat Sep 29, 2012 1:06 pm
Forward superstructure work.
I closed up the aft area with a funnel shaped piece of styrene to close that big ugly rectangular hole. The wood is to help square the superstructure.
Platform work:
PostPosted: Sat Sep 29, 2012 1:12 pm
Hull work.
The model comes with indentations/locators for all superstructure and other parts. I hate thos because they leave a seem that must be filled, so I sheeted them in with 0.01 styrene. I know it raises everythin a little bit, but it only scales out to 3.5 inches!
Drilled out the hawspipe since there is no anchor entrance in the kit, just an indentation for a flat anchor:
PostPosted: Sat Sep 29, 2012 1:14 pm
Removed all plastic brass tie downs and drilled there locations. Replacements from Flyhawk will be forth coming:
PostPosted: Sat Sep 29, 2012 1:17 pm
Aft superstructure work. The aft superstructure received this platform for the twin 25 mm AA mounts in 1944:
Dry fitted:
Addition work on aft superstructure vents:
PostPosted: Sat Sep 29, 2012 6:04 pm
Looking good Joe :thumbs_up_1: :thumbs_up_1: man i wish i've had this flyhawk set when i started my 1941 Myoko.. i'm sure it would've saved me so many headaches haha
Jose :wave_1:
PostPosted: Sat Sep 29, 2012 7:06 pm
Thanks Jose. I have studied your work very extensively.
PostPosted: Sat Sep 29, 2012 9:34 pm
Yup what they said. You say 1944 Myoko. Are you using the 1942 kit for a starting point?
On the Bench
1/350 Independence
1/350 Dunkerque
1/350 Shimakaze
1/350 Sharnhorst Dragon
1/350 Belfast
PostPosted: Sat Sep 29, 2012 9:41 pm
Yes I am. I was able to identify the differences using Lacroix and Welles IJN Cruiser book. Although the kit is 1942 it does include parts for 1944. The Flyhawk set is also for 1944 so many of the kit parts will not be used.
PostPosted: Sat Sep 29, 2012 10:21 pm
I figured that. I also want to build the Myoko. But was wondering if the kit came with the Bridge for a 44 setting. I don't really like the early war war bridge. I will be watching your build.
On the Bench
1/350 Independence
1/350 Dunkerque
1/350 Shimakaze
1/350 Belfast
PostPosted: Sat Sep 29, 2012 11:50 pm
They give you both bridges, but only give directons for the early one. I am cleaning off the molded on bridge wind deflectors now and plan to add the photo etch this week. I'll post pictures hopefully by next weekend at the latest.
PostPosted: Mon Nov 19, 2012 8:50 pm
More progress. I replaced the plastic bridge wind deflectors with photo-etch:
PostPosted: Mon Nov 19, 2012 8:58 pm
I did not like the plastic baffles they give you for the funnels so I modified them:
PostPosted: Mon Nov 19, 2012 9:01 pm
Now the forward funnel:
PostPosted: Mon Nov 19, 2012 9:03 pm
Finally a bridge platform:
PostPosted: Mon Nov 19, 2012 9:36 pm
Looking great so far Joe. Are you going to use the kits AA guns? Was wondering if you could post a pic or two down the road of the stock guns if you are going to upgrade? This class is the only one i do not have in this scale yet.
On the Bench
1/350 Independence
1/350 Dunkerque
1/350 Shimakaze
1/350 Belfast
Users browsing this forum: No registered users and 64 guests
