It is currently Sat Jul 05, 2025 9:29 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Fri Feb 27, 2009 10:45 pm
well after my experience with the musashi i think its time move on to the yamato (ten ichigo style)!
List of what is in the build:
-1/350 Yamato
-PE Lionroar
-PE Eduard
-PE GMM
-2x 5in AA set from Veteran models
-3x Veteran models Trip 25mm AA
-Veteran model voice pipes and binoculars
-Shinsegumi wooden deck
There will some scratch build stuff too...
more pics to come
UPDATE 08 APR 2020
FINALLY, after 13 YEARS of on an off building she is DONE! :jump_1: In a truly emotional moment the chrysanthemum crest is on and Yamato 1946 is finally completed. The crest in fact is part Z1 from the new mold kit, which will duly be replaced with the Pontos cast crest.
Its been a really long journey since the start. Come to think of it, Japan couldve made 4 Yamatos in the time it took for me to build this one. Hopefully when I get around to doing the new mold ship it wont take this long....
Image20200407_224443
Image20200407_224453
Image20200407_225532
Image20200407_225609
Image20200407_225712
Image20200407_230534
Image20200407_230907
Image20200407_230857
Image20200407_230758
UPDATE 14 SEPT 2016
Ship is now around 85% complete. The rocket launchers were a total pain to build but it will pale in comparison to the triple type 96 mounts....
new pics added at the last post
UPDATE 20 JULY 2016
I finally found time to work on it again. I added some late war IJN rocket launchers. Pics at the last post
UPDATE 8 JUNE 2016
Forward Secondary Turret, Type 89 DP AA guns and first of many Type 96 AAs have been mounted
ImageDSC_0689
ImageDSC_0691
ImageDSC_0690
UPDATE 30 May 16
A small update with a few progress shots. Unfortunately due to work I havnt been able to spend much time on it....
Fortunately though I have a friend who is keen on pushing me to spend more time working on this almost decade old project ...... :/
Mast with the tripod legs reconfigured to the correct orientation
ImageDSC_0649
I decided to redo the crane as the original one was warped from sitting around for almost 10 years.....Unfortunately the LionRoar instructions were rather poor.
ImageDSC_0647
The crane dry fitted on the stern. The AA platform was transplanted from the New Tool kit
ImageDSC_0644
I still have to repaint all the windows.....
ImageDSC_0651
UPDATE 25 APR 16
Well after 7 years... finally updated pics!
A more detailed explanation on the bottom posts
The windows were painted sharply black before the repaint....looks like ill have to paint it now with a toothpick......
File comment: Veteren model AA
File comment: Eduard and Lionroar decks
File comment: crane:
for those who are wondering why theres no mast: recent studies have indicated that Yamato did not carry it to ten ichigo
File comment: lionroar + GMM turrets
File comment: old mast to the left
scratch modified mast right
File comment: just how small the parts are for the trip 25m AA
File comment: lionroar+GMM+Veteran upper command deck
File comment: hull WIP...note the musashi to the right
 Post subject: Re: 1/350 Yamato
PostPosted: Sat Feb 28, 2009 8:25 am
A good start has been made!
But... do cover your other model with a glass case.. dust....!!!!
Jim Baumann :wave_1:
PostPosted: Mon May 25, 2009 10:52 am
FINALLY after months of no progress due to school I finally managed to find time to work on the big Yam again...
most of my latest progress was spent on modifying the structure at behind the bridge. Tamiya's rendition was too skinny so after hours of research and consultation of the AOTS as well as the Kure model I scratch built an extension to the structure.
skinning the deck with diamond plated PE was an adventure....had to combine 2 sections of unused deck from eduard and basically cut out the shape...took along time but the end product looks pretty decent...
btw...does anyone know of a site with walkaround pics of the Kure model? the one that i had was taken down... :(
File comment: adding the structural supports
File comment: half way done the sides
File comment: A closer look....
File comment: completed structure
File comment: Turret 1 completed...though the Micro Flat that i used was way too glossy....looks like ill have to recoat it with something "flatter"
File comment: Modded turret compared to one of my spare originals
PostPosted: Thu May 28, 2009 7:12 pm
Looking very,very good. I really like what you have done already. Just in case you happen to mess apice up (PE) I bought the lionroar kit and am building the Musashi so I'll have some extra parts. If I have it I'll send it to you. But looking at your work you probably won't need it.
PostPosted: Sat May 30, 2009 8:06 pm
Thanks to the updated drawings from the Model Art Yamato book,
now in my pursuit to get the most accurate model as possible, the rear overhanging platform now needs to be hacked up and remodeled to look like the drawings.... sigh...hope it wont become an expensive mistake
File comment: rear platform butchered...
File comment: the only part that will be reattached to the remodeled deck
PostPosted: Wed Aug 19, 2009 9:20 pm
After a long break due to Officer training in the Canadian Forces I finally found some time to resume construction...
Progress so far is approx at an amazing 15% done!! yay.... -_-
I think at this rate Ill be done sometime next year...
Anyways heres the latest progress shots
Ill post more pics when i get the chance to
File comment: lionroar/GMM catapults just after priming
File comment: 6in gun getting built up...
File comment: another view of the 6incher
File comment: modded gun tubs ready to receive their type 89 AAs
File comment: type 13 radar from lionroar
File comment: veteran model's trip 25mm... man it took forever just to assemble 1!!
File comment: trip 25mm w/ type 89
File comment: covered and uncovered type 89 5in AA
File comment: veteran type 89 compared to the OEM one
PostPosted: Sat Dec 19, 2009 1:42 pm
Well after many months of collecting dust due to school I finally started to work on the ship again
Latest shots are of the bridge structure
Changes:
-remodeled rear overhang to reflect on new findings on Model Art Yamato book
-all "sticks" replaced w/ proper binoculars and sighting equipment
-PE railings and parts by Lionroar, Eduard, GMM, Veteran
-scratchbuilt rear crew readiness room (enlarged over the original mold)
right now I'm trying to get the funnel and rear superstructure done up; will post more asap
Hopefully Ill get the momentum going, to get as much done as possible b4 school restarts
feel free to comment or flame:
PostPosted: Sun Dec 20, 2009 3:40 am
Fantastic job :thumbs_up_1: :thumbs_up_1:
Ciao :wave_1: :wave_1:
Luciano
Best Regard from Italy
http://www.navymodeling.com/
PostPosted: Mon Dec 21, 2009 4:18 pm
Outstanding pe work on your ship. Thanks for sharing the pictures.
Mark
PostPosted: Thu Jul 16, 2015 5:48 pm
So finally after about 6 years in the freezer I've decided to finally finish this ship.
However seeing that I've kind of lost the motivation to completely "accurize" this ship to Ten Ichigo config
i've decided to buy a new tool Yamato and do that. in the meantime for this one, I'm going to try and do something few have done on this forum
and do a 1946 Wif version complete with shielded mounts for all the type 89s (I used the ones from the earlier posts on my Maya)
and as many 25mms trips as possible (using the Lionroar resin turrets and kit ones). I'm going to try to do a late war camo paint scheme, something akin to the one
used for zuikaku or shinano. Anyone got any suggestions on what else I can do?
And now for some WIP pics.....
Well I got none yet....but stay tuned...hopefully I can get some on if I have time
PostPosted: Fri Jul 17, 2015 1:03 am
Tease! :p
Heh, in all seriousness, it would certainly look interesting to see what Yamato would have looked like if she'd not been sent on that suicide mission and made into a floating battery (akin to what you plan, and what was done for other battlewagons and heavy cruisers). The different greens, grays and other colors will certainly turn a head or two, just on their own... :thumbs_up_1:
On the ways:
1/200 Trumpeter HMS Nelson
In the stash:
1/35 Italiari PT-109
PostPosted: Mon Apr 25, 2016 11:27 am
Gosh...I cant believe its been 3/4 of a year since I promised to post pics.
But anyways I finally found some decent spare time to work on it....
at this rate they wouldve been able to build both ships CONSECUTIVELY and still beat me to finishing a model of it....
Some potato quality cell phone pics:
For some reason, the paint callouts for the Tamiya Shinano that I based my camo from gave a turquoisy green for the lighter shade, even though I added another 3 parts of green on top.
I guess the small bit of blue determined the overall colour. O Well...it is a whiff so who knows....They could've developed a super sayan shade of green that hid them from view nicely....
Then again they are the Japanese ..... :flamed: The side profile of the late war CV camo doesnt really look as good on a battleship than on the carriers, so maybe Ill add stripes later on down the road to dress it up. First I have to finish major construction which is really being hampered by the fact that the Lionroar PE scaling for some of their parts are really off and require correction (the tower crane and stern AA platform for starters...) I was also hoping to be able to acquire some Veteran Model rocket launchers like the ones on the Pontos Musashi but apparantly Mr Kim has bought out their entire inventory the last time I asked him.....Does anyone know the contact info of VM? I'll post more pics when I have the time to. Feel free to comment :)
PostPosted: Wed Apr 27, 2016 3:36 pm
Very nice. Can't wait to start mine!
PostPosted: Sat Apr 30, 2016 2:11 am
Outstanding work. Very nice. I admire your perseverance (and perhaps perversely) to first take on Musashi, then immediately upon completion of that project, begin the Yamato. I doff my cap.
Bob M.
PostPosted: Mon May 30, 2016 12:32 am
The first post has been updated with a few photos
PostPosted: Wed Jun 08, 2016 12:35 pm
I finally able to get some time in to complete the installation of all the shielded Type 89 DP AA guns. This was also my first experience with using wood decking so that was a chore and a half.
I used the Shinsegumi Ver.2 deck since I didn't want any of the circular holes for the on deck mounts as well as the punchouts for the single type 96 mountings that was incorrect for the 1945 fit.
What I ended up getting myself into though was a bare deck that I had to modify significantly just to fit, including trimming the edges and cutting out the sections where the scupper drains were (these were already done in the ver. 1 deck) Fortunately I had the ver. 1 deck as a template and many hours later it you can see the results in the uploaded pics in the first post.
Good news also, as VM announced that they will sell the IJN late war rocket launchers in open and shielded mounts (see the post in the vendor thread) so it looks like I'm going to but a couple sets :)
PostPosted: Wed Jul 20, 2016 5:08 pm
I finally found time to work on this again.
Finally got the funnel painted
ImageDSC_0776
ImageDSC_0775
Since this was a Whif Yamato I figured it was only fitting to add some whif armament. Behold! IJN rocket launchers found on late war vessels
ImageDSC_0783
ImageDSC_0778
ImageDSC_0781
ImageDSC_0780
I plan to also have some open mount rocket launchers as well including the turret mounts. Does anyone know if these launchers were any good in AA?
PostPosted: Wed Sep 14, 2016 1:01 pm
After a summer of little progress I finally had the time to complete the open mount rocket launchers and other parts of the superstructure.
Long story short, these launchers are a piece of work...I spent many frustrating profanity laced hours putting together these things...
Also for some reason despite following the same ratios I couldnt get the exact shade of light turquoise from the first batch....it was more "swampy green"
ImageDSC_0852
ImageDSC_0850
so in order to paint match I had to repaint the hull again...but not before I dropped my air compressor onto the aft Fire control tower while fumbling for the light switch.... :(
ImageDSC_0848
Overall, Im finally starting to see the light outside the tunnel. All thats left is the mast, stern crane, railings rigging and other small details.
ImageDSC_0854
ImageDSC_0853
Thanks for looking!
PostPosted: Wed Sep 14, 2016 1:07 pm
ImageDSC_0855
ImageDSC_0852
ImageDSC_0850
ImageDSC_0848
ImageDSC_0854
ImageDSC_0853
Thanks for looking!
PostPosted: Wed Sep 14, 2016 7:16 pm
Very nice!!
Users browsing this forum: Bing [Bot] and 5 guests
