Sooo....
Just when I promised myself a short sharp project.....
Not cured of my French pre-dreadnought fever by the 1/700 Carnot build....
viewtopic.php?f=59&t=48865I have now started the 1/350 BOUVET--the culmination of the the semi class that Carnot and Massena were members of
( see here Massena)
http://www.modelwarships.com/reviews/sh ... eview.htmlThe Bouvet kit in the box I reviewed here at MW.com
http://www.modelwarships.com/reviews/sh ... eview.htmland ... as the starting point looks so good I thought...
' here is a quick build '.....
Well it would have been...--but I wanted my Bouvet to be set at anchor/buoy, booms and boats out, an awning--set in the Mediterranean, black and yellow....
Its a long journey from here....!!
It all starts like this:
The casting is ' waterline'-- but only a near waterline....
=> so--according to the Plans from the French archives and after viewing a number of photos--I applied some clear tape to the hull and checked the tape line for fairness- when satisfied I drew a pencil along the line
The sanding ' could' be done by hand--but I prefer machines!
more detail how that is done can be seen here:
viewtopic.php?f=4&t=18213With the hill perfectly fair I drilled the Barbettes for eventual screwing down of the model and screwed a few selftapping screws into the underside of the hull so that I could attach my spring clamp for easy handling.
the Butchery begins....
Open hatches ... are a pain.
To get the edges REALLY sharp is actually really rather hard-- so I drilled DEEP holes, cleaned up the edges with a microchisel and Stanley blades, blowing out the debris with the airbrush.
I inserted a PE 'frame' to give sharp edges,-- ( from the L'arsenal Libert ship 1/350 PE set- handrails )
These were cut into small squares--wasteful--but effective....
Installed with CA, pre-bent where the hull curves, and the edges filled with fine grain knifing putty filler.
When dry I pared away the excess with a blade-
after a guide wash of paint it looks like it could be pretty sharp once the hatches have been applied
a bit more filling and paring will make them look really good!
I have the benefit of the ' extra' PE fret available from YS Masterpieces-
-which also features the pierced grating PE bridge deck.....
The hatches will need to be cut in half--top and bottom halves-and applied to the apertures...
quick build eh...?
So far... so good....
More soon
Jim Baumann
http://www.modelshipgallery.com/gallery ... index.htmlIPMS UK SIG (special interest group)
www.finewaterline.com
