It is currently Fri Jul 11, 2025 2:42 am
Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Apr 27, 2013 12:59 am
How about a reverse Nelson with three aft turrets and a bridge at the bow.
Seasick
PostPosted: Sun Apr 28, 2013 9:38 am
Interesting, the Japs had a class of cruisers like that, 2 with a forward turret & 1 aft, the Itsukushima(F), Hashidate(F) & Matsushima(A). I always liked them.
PostPosted: Sun Apr 28, 2013 8:57 pm
well the dkm leipzig gun configuration would have worked for what you guys want , 1 bow gun and 2 aft guns
be inspirational today , you might never get that chance tomorrow
PostPosted: Wed May 01, 2013 4:39 am
mmm...not the same..she still had fore & aft turrets (& mags), the idea is to have the mags concentrated at 1 end
PostPosted: Wed May 01, 2013 1:15 pm
well dunkerque maybe ? ? had 2 bow main turrets but to invert everything would be tough because your bridge and comms would be exposed with no frontal defence system
PostPosted: Sun May 05, 2013 5:38 pm
They would be more like it. Any warship with big turrets aft & none forward looks wierd :crazy: !
PostPosted: Sun May 05, 2013 5:45 pm
question if a 10 inch or bigger shell hit an airplane would the shell even explode ? ? Why i am asking is because i read a few reports where a ship popped a plane here and there with its main batteries
PostPosted: Sun May 05, 2013 6:42 pm
Given the relatively light construction of an airplane vs a ship I'd highly doubt they'd explode. There's stories of ships of all sizes taking armor piercing shells in unarmored areas of the hull and simply suffering a pair of holes the size of the shell in the hull plating and that's it! An AP shell has to hit some something substantial, like armor, a an engine, a gun assembly, etc... to get them to go off. If a large caliber shell hit a plane chances are it'd send the plane and/or pieces of it for a ride off the ship.
PostPosted: Mon May 06, 2013 11:33 pm
As he stated, an AP round would likely go right threw. If it hit something solid (like the engine or a full bomb rack!) it may go off, but would likely just rip that section of the plane off. When the Germans invaded Narvik harbor in Norway on 04/09/1940, they sent 10 destroyers of group 1. When the British sent in a counter fleet on 04/13/1940 it was led by HMS Warspite. Reports state that, as the battleship approached the harbor, a German destroyer (Erich Koellner I believe) tried to leave the harbor & was shelled by Warspites forward 15"ers. They first used AP rounds (to see what would happen). They reported several hits at close range fallowed by explosions against the side of the fjord, behind the destroyer. Now if large calibur HE rounds are used then they would obliterate an airplane. I read reports of US 8” gun cruisers off Guadalcanal being attacked by Betty bombers with torpedo runs. They turned their 8”ers on them with HE & reports state that several Bettys took direct hits & disintegrated in mid-air! You should note that the Yamato carried 18” flechette rounds for AA during her final voyage.
PostPosted: Sat May 11, 2013 11:04 pm
i know of 3 types of ammunition used in WW2 , he rounds , ap rounds and high velocity rounds if i am correct , but here and there names pop up of experimental rounds that was tested , any info guys ? ? I asked the airplane question because of the airplane vs ship debat
PostPosted: Mon May 13, 2013 4:36 pm
well what's more important is the fuse! One of the great secret weapons of WWII was the US development of the Microwave proximity fuse. this was what really gave our AAA the extra punch that aloud the USS South Dakota to score 23 air kills (the highest ever in history for a single surface ship) at Santa Cruise where the Musashi was just a moving target. a lot of people disdain Battleships by pointing to Axis ship performance but they didn't have HE with Prox fuse ammo (a real killer). While I'm not aware of it being used in anything larger than the 6" on the post war AA cruisers there's no reason why it wouldn't work on something large. Whats more, with very large guns, specialised sub-munition rounds could be developed (like firing a half dozen or more 5" rounds at one time from a single 16" tube)
PostPosted: Mon May 13, 2013 7:03 pm
all turrets aft sounds like they plan on running from every fight
PostPosted: Tue May 14, 2013 3:46 pm
Yea, That's why the British G3 & N3 (what the Nelsons were based on) had no aft turrets, It was believed they should rarely have the enemy in their rear arc (though the Lion had the enemy in its rear arc when it was limping from Dogger Bank!). Still any BC (designed to run from anything bigger than it) might have to.
PostPosted: Tue May 14, 2013 8:31 pm
to have guns on only one side leaves major gaps in defence , if the enemy came from the front and all your guns are at the rear you are in major trouble same vice versa you would be shelled like crazy and all the enemy must do is to stay out of your guns position
PostPosted: Tue May 14, 2013 8:40 pm
axis ships were lethal at long range and scored hits where most ships couldnt , now a microwave fuse sounds interesting but germany was busy with theyre projects like a nuclear round , the project was disbanned after a while but if they got it right no ship would have been safe within striking distance of such ammo types , as it seems to me WW2 was a sci fi type of warfare as both allies and axis were developing new types of tech far beyond the imaganation of what was thought possible
PostPosted: Thu May 16, 2013 9:30 am
That's where Maneuvering comes in, at Tsusima the Japs stayed ahead of the Russians main battleships. the Russians had all-round fire but with only 2 guns (half) forward. if the Russian BBs had had all of their guns forward they would have been able to fire back better. the main problem is the fleet maneuver, with individual ships (like most WWII engagements) the ship in question can turn faster than the enemy can run around (unless their in a narrows), it's when the fleet has to turn in a tight fleet formation that you can't make sharp turns without running into each other.
PostPosted: Fri May 17, 2013 12:33 pm
I don't think so. How often have you known battelships to engage a target dead ahead?
I think the main reason why all turret aft arrangement is silly is it would force the machinery space farther forward, unnecessarily increaseing the shaft length, and compromising the defence of the magazines due to the need to route shafts under or around the magazines.
PostPosted: Sun May 19, 2013 1:49 am
The Reichmarine light cruisers Leipzig and Nuremberg both had a conventional gun layout with the 15cm on the center line. The K class that came before them had the oddly staggered 15cm on the stern. The idea was that the stern turrets would have a large firing arc that would reach very far forward. It didn't work well in practice and Leipzig reverted to the the conventional layout.
Seasick
PostPosted: Sun May 19, 2013 1:50 am
I came up with the reverse Nelson as a way of designing the oddest looking warship possible.
Seasick
PostPosted: Fri May 24, 2013 5:57 pm
well whats the dimensions of your ship ? ? To make it odd wouldnt be a problem but to make it practical is another story
