Martin, actually I suspect that USS ATLANTA is wearing a "standard" Ms 12mod(R) scheme with 5N and 5O on the hull and 5O and 5H on the superstructure. The "hazy" weather (maybe drizzle?) conditions kind of subdue the colors even at this limited range. Some of the USS SAN JUAN photos do indeed look like 5H was carried down to the hull sides in a few places.
There are actually a fair number of USS ATLANTA (CL-51) photos, unfortunately the ones I have scanned are starboard side views.
An interesting set of images follows that shows the evolution of USS ATLANTA's camo. The first image shows ATLANTA after returning from Shakedown on 19 March 1942. By the end of of her Post-Shakedown Availability (about 30 March 1942), she apparently had her camo scheme on the hull altered from her May 1942 photo (2nd image) taken an Pearl Harbor and during the Battle of Midway (3rd image). But, the superstructure pattern was little altered. The last image (4th image) shows her during her 22-23 October 1942 layover at Espiritu Santo by which time her hull has been repainted with 5N. But, her superstructure appears to be the same as applied during her fitting out at NYNY. ATLANTA was delivered by Federal painted in "Peacetime" scheme and her Ms12mod(R) camo was applied by NYNY during her prolonged fitting out there.
The first four ATLANTA class cruisers exhibit different Ms 12mod(R) Camo "philosophies". The Federal built units delivered to NYNY, USS ATLANTA and USS JUNEAU, show the use of small patterns on both the hull and superstructure. While the Bethlehem-Quincy built units delivered to BosNY exhibit the use of a larger size of patterns on the superstructure and to an extent on the hull as well. It appears that USS JUNEAU was painted by Federal prior to delivery to NYNY in a similar pattern as was applied to USS ATLANTA. But both during the fitting our period (11 February to 22 March 1942) and her Post-Shakedown Availability (21 May to 1 June 1942), JUNEAU had her camo altered with DIFFERENT patterns on at least the hull on the starboard and port sides. So she left NYNY in early June 1942 in an "Experimental Pair of Schemes" not even standard for Ms12mod(R). Plus as has been pointed out her superstructure (hull?) camo was altered again on 15 June 1942. There is a possibility that at least her hull scheme was further altered, even if only slightly, while at Balboa on 19-22 August 1942 during drydocking to repair a leaking fuel tank. Something that would require at least some "touch-up".
At any rate in mid-September 1942 she looked like this.
Fortunately for those who wish to model USS JUNEAU in her Battle of Santa Cruz camo, there are a couple of good photos of her. You decide the color.
