It is currently Sun Jul 13, 2025 6:54 pm
PostPosted: Thu Feb 01, 2018 4:27 pm
Which 31-32 measures [green] were used on LSTs in the Pacific theatre? I've several different ones, some obviously local, looking through the Navsource pictures.
Walt Haynes
Moved from CASF Amphibs, added [LSTs] tag to subject
 Post subject: Re: Camoflage measures
PostPosted: Thu Feb 01, 2018 8:39 pm
I'm not an expert on what camo, where, but if you Google "LSTs at Iwo Jima" or whichever location you're interested in. Lot's of photos come up.
http://c8.alamy.com/comp/HG0PCM/uss-zun ... HG0PCM.jpg
https://www.ibiblio.org/hyperwar/USN/sh ... lcanal.jpg
Not sure if you've seen all these,
https://www.ibiblio.org/hyperwar/USN/sh ... T/?C=N;O=D
Darren (Admiral Hawk)
PostPosted: Thu Feb 01, 2018 10:50 pm
I had good luck with LCI camo patterns on the Navy History Command website. I did a quick search using LST, measure and came up with these:
https://www.history.navy.mil/search.htm ... 2C+measure
PostPosted: Fri Feb 02, 2018 8:39 am
Thanks, that's very helpful
Walt
PostPosted: Sat Feb 03, 2018 10:38 am
Floating Drydock also has some LST camouflage design sheets:
http://floatingdrydock.com/camo.htm
Ed
PostPosted: Sun Feb 04, 2018 9:28 am
Thanks Ed. I found both of those at the link above posted by our Arkansas friend Mr. Henning. Thanks to all those who replied.
Walt
PostPosted: Mon Feb 05, 2018 12:17 am
Glad to have helped. Ran across the different measure schemes on that site while building the Lindberg LCI as an LCI(G). Lots of good stuff on the website.
Which LST kit are you building? I sure wish someone would come out with a 1/144 or 1/200 injection molded version.
David
PostPosted: Mon Feb 05, 2018 5:36 pm
Only one I can find in 1/350 is the Iron Shipwright.
PostPosted: Wed Apr 04, 2018 5:19 pm
I've got another pattern as well, but can't seem to get Photobucket to upload the images. Will try later.
John Snyder
Shady Grove Farm
PostPosted: Wed Apr 04, 2018 5:30 pm
John Snyder
Shady Grove Farm
PostPosted: Sat Jul 07, 2018 10:44 am
I always run into the problem of matching the camouflage schemes to specific ships.
PostPosted: Thu Jul 12, 2018 11:44 am
For what it's worth AFV Club will be releasing one in 1/350th scale:
http://www.moxingfans.com/new/news/2018/0409/4603.html
