It is currently Fri Jun 27, 2025 10:13 pm
PostPosted: Sat Nov 07, 2009 4:40 pm
For the past few days, I've been painting my Project Habakkuk ship in a Measure 13 scheme which is described here:
http://www.shipcamouflage.com/measure_13.htm
Because the Habakkuk has an extremely long/large flight deck, I want to spray paint it rather than brush paint it. Airbrushing is out of the question as I have bad eyesight and don't own an airbrush. Since Deck Blue 20-B does not come in a spray can, then which color could I substitute that would come close to 20-B? Either FS35164 Intermediate Blue or FS36118 Gunship Gray?
PostPosted: Sat Nov 07, 2009 6:52 pm
Neither.
What spray cans do you have access to? In Model Master, #1917 FS15042 Dark Sea Blue would be closer- but you'd have to follow up with some Dullcoat.
Sean Hert
PostPosted: Sat Nov 07, 2009 7:50 pm
Yep, I've had people tell me about that. Though I wasn't sure about using it as I've always had bad problems spraying gloss evenly in the past on models, then following with dullcoat. :( But the flight deck I have to make is in small sections and not one large piece, so I might give it a shot.
