USS Indiana BB-58 Scratchbuild in 1/96 - 1944
Bill Waldorf
Waldorf Productions
Waldorf Productions
Post by Bill Waldorf »
Well, it's been a bit quiet here on this thread, so here's a little appitizer for you. :cool_2: Check these few shots out.......................
Here's the bow of the Indiana, now scupted in with autobody filler and primed with a preliminary coat of grey primer to check the shape. Hmmmm............... Not too bad! :thumbs_up_1: Note where I put the styrene strip leaves that nice sharp edge. The ship is actually up-side down, I just rotated it to give a better perspective.
Note here how that sharp edge blends in at the very top of the bow and at almost the bottom of the bulb. Alot of finish work to be done yet, but I have the shape.
Here's another rotated view. Note the teardrop shape. Took a few tries to get this right, at least I think it's right.
Here's one last look. Big update coming soon. Stay tuned!! I continue on........................ :wave_1: :thumbs_up_1: :lol_spit_1: :lol_spit_1:
Looks good! May I request a broad-side shot of the hull?
Bill Waldorf
Waldorf Productions
Waldorf Productions
Timmy C wrote:Looks good! May I request a broad-side shot of the hull?
Soon, my friend, soon............................
Millard
Post by Millard »
BILL
THE HULL IS REALLY TAKING SHAPE.ARE YOU WORKING ON ANY OF THE SUPERSTRUCTURE OR TURRETS YET OR JUST CONCENTRATING ON THE HULL?
ROD
Bill Waldorf
Waldorf Productions
Waldorf Productions
Millard wrote:BILL
ROD
Hello Rod!! :wave_1: I am studying the superstructure and the turrents, but I really want to get the hull completed first. Once that's done, I can concentrate on other things. It's coming...................
herrmill
Post by herrmill »
Bill,
Both your work, as well as your shop, are simply amazing! I look forward to meeting you & seeing Indiana in person when I arrive back in Jacksonville next month.
Chuck
Bill Waldorf
Waldorf Productions
Waldorf Productions
herrmill wrote:Bill,
Chuck
Ditto............... I look forward to meeting you, too. Welcome aboard!! Thanks for your post. :thumbs_up_1: :wave_1: :lol_spit_1: :lol_spit_1:
Bill Waldorf
Waldorf Productions
Waldorf Productions
Hello again all!! :wave_1: Things have been busy here at Drydock #3 in Jacksonville, Florida! The hull is now fully sheeted off, and three coats of epoxy marine resin have been applied to seal the balsa. Inside of the structure has also been treated with the resin, and the main deck has been installed. Bilge keels have been added, as well as the anchor bolsters. I have also completed the shaft /strut arrangement aft for the inboard props. let's take a look................................
Here's the stb. side of the ship. Note the resin coating really seals the wood and helps to shape the hull too. The main deck has been installed and is fabricated from 1/8" luan plywood, which bends easier than the 1/8" occume plywood used for the formers of the hull. I used construction adhesive to attach the main deck to the hull.
Here's the port side. Note the bilge keels have been added, made from 3/32" balsa strip, then glued and resined in to the hull. I have conflicting evidence of these keels which are shown in two different configurations on the plans I have. On plans for the Massachusetts, the plans show two bilge keels per side, a short one admidships and a longer one aft, while South Dakota plans show one long keel as shown here. I do not know which is correct for the Indiana, so I decided to go with the simpler of the two configurations. In any event, a bilge keel is installed.
A dead-on bow view here. Bow was shaped with autobody filler. Note the anchor bolsters. These were vac-u-formed from a small master I made. The bolsters kept the anchors away from the hull a little bit to keep them from digging and gouging the hull. Sort of like a collar around the hawse pipe. Note you can't see the fat battleship shape here as I am too close to the bow with the camera.
Port side of the bow here. Note the sharp edge of the bow, accomplished by the use of that styrene strip I installed earlier.
Stb. side shot here. Note the teardrop shape at the bottom of the bow.
On to the stern. Here you can see I have added the rudders,, fabricated and shaped from .250" balsa sheet. Props have been installed temporarily. They are from G.T. SITEK from the UK. A bit more shaping done on the stern here, as you can see by the autobody filler. A bit more work to do on this as the stern looks a bit blunt. I'll fix that soon. Once I prime the whole stucture, I'll be able to see spots that are not quite correct a little better, then rectify those areas.
Dead-on view of the stern. Note the interesting arrangement of the props. The inboard ones are slightly behind the outer ones, and a bit lower. Rudders are just forward of the outer skegs.
Another view of the business end of Indiana, this time from stb. side.
Here's the propeller arrangement from underneath. Inboard shafts are hardwood dowels with styrene added. Struts are balsa and styrene strip. I'll fair in the struts later after primer coats are applied.Threaded rod is installed into the wood dowels to facilitate installation and removal of the props as needed.
These next few photos show different angles of the prop shaft arrangement.................................
Well, that's it for tonites update. Hope you enjoy. On to priming the hull and a bit more fine tuning, then on to finish paint, Measure 32. Stay tuned............... More to come!!
I continue on ....................... :wave_1: :thumbs_up_1: :lol_spit_1: :lol_spit_1:
JIM BAUMANNN
Post by JIM BAUMANNN »
Looking really great!-- Love the bow and the fat rump!!
:thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :thumbs_up_1:
JIM BAUMANN
Post by Dave Wooley »
Hello Bill your hull is shaping up well and I do like the way you have formed the bow, clean and sharp work there.
Sleepwalker
Post by Sleepwalker »
Respect :worship_1:
God created Arrakis to train the faithful.
johndon
Post by johndon »
Looking mighty fine :thumbs_up_1:
John
jep1210
FanDAM tastic
Post by jep1210 »
Your build speed is incredible. You've gotten more done in this short amount of time than I have in the past 5 months on my CVE, and I'm building from a kit LOL.
:thumbs_up_1: Rock on!
J.P.
Avery Boyer
Post by Avery Boyer »
Jefgte
Post by Jefgte »
Congrat
Very nice hull
:lol_spit_1:
Jef :thumbs_up_1:
Current 1/700 WL
HMS Repulse
Post by ModelMonkey »
Superb!
herrmill
Post by herrmill »
:faint:
The classic Chinese kowtow to show respect to those above.
Post by Guest »
A-MA-ZING work Bill , your hull is so smooth , up to now she is really looking good.
Ludwig
Millard
Post by Millard »
Bill
Looking really good.Keep the post coming. Happy Thanksgiving to you and Barb
Rod
Bill Waldorf
Waldorf Productions
Waldorf Productions
Hello again all! :wave_1: Work continues on the USS Indiana build. Having completed all the resin coating on the hull and lots of sanding, it was time to apply the first few coats of primer to the hull. Here I will be using Hi-Build Red Oxide primer/surfacer, laquer based automotive product. Great stuff for finishing but it is best done outside as it smells very solventy and leaves dust everywhere. Extemely flammable, too. :flamed: Let's take a look......................
Here's the bow again. Sorry about all the upside down shots, but thats how I'm working on the hull for now. Note how the primer further smooths things out. This is not sanded yet. I'll be able to see any bad spots very well and correct them at this stage before adding final coats of primer. This procedure could take several days. Note I have added the anchors.
A stern view here, stb. side. Note I have covered the threaded prop shafts with styrene tube to keep the primer off of them. You can see a few minor imperfections here. These will be rectified with "spot putty", sort of a real thick primer that dries fast and fills imperfections in the surface, red in color. Overall, things are looking good. :thumbs_up_1:
Another view of the stern, this time from port. These primer coats are not yet sanded. Things will smooth out alot more once I do that. I'll use 220 grit wet or dry sandpaper next.
Another bow shot. The teardrop shape is really evident here. I was pleased with the results of my previous efforts. Again, note the anchors installed. Cast metal from HR Products.
Overall view of the stb. side. Note the little mark on the bilge keel. I bumped into a corner of a wall while moving the ship up and down the stairs, and took a small piece out of the keel. These are made from strip balsa, and although coated with the resin, they are still pretty soft, and can get beat up easily. I should have used styrene strip. The other marks visible are the bolt holes to mount the ship to it's base. I taped them off so as not to dirty up the threads in the t-nuts. The hull looks pretty good so far, not a lot of goobers in it. That's good, less work for me!! I'll fix that bilge keel with autobody filler. Note the armor belt is taped off with masking tape. Lots of detail work in this area to come, so I did not want primer on it yet. Adhesive will stick better to the unpainted styrene in this area.
Forward shot of the bow looking aft. Once a little body work is done and all is sanded out and then reprimed, I'll be ready for final paintwork on the hull before proceeding to topside construction. I was happy that the imperfections on the hull were few. Pay's to do your homework!!
Another shot of the stern here. Everything lining up pretty good so far. A bit more fine tuning on those outboard skegs yet to do, as well as the struts inboard.
The weather here has been rather cool, so I was not able to do primer work until today. While waiting for the temp. to get warmer, I have been working on the master pattern for the 16" 45 cal. main gun turrents. Here is what the progress is so far. When completed, I'll make a mold from this pattern and resin cast three turrents. Much to do yet, but it is coming along.
Here's another view of the turrent master pattern. The top and bottom of the turrent are .040 styrene, while the front, sides and rear are .030 styrene. Inside the turrent is a balsa framework, a center "keel" and ribs along each side to assist in attaching the styrene. Note the blast bag rings. These were made by making a small master pattern from balsa wood, then vac-u-forming that pattern to make a small mold. I then cast the rings from resin. The trunnion block is where the barrels will sit. This block is the same angle as the face of the turret. Drilling the holes for the barrels at the correct angle I wanted, about 15 degrees, was a bit of a challenge.Actually, I can attach the barrels anywhere from -5 degrees to about + 20 degrees angle. This allows for some adjustment when permanantly attaching the barrels to the turrent structure. I can also have each barrel at a different angle if I want, since all three guns could be aimed at different angles on the real ship. Turrents will also be moveable, in case the museum wants a different look! I doubt they will mess with it after the fact.
In this photo the barrels are loosely placed in the trunnion block. Barrels are cnc turned aircraft aluminum.
Here's another view of the turrent. Some of you may be asking,"What's he gonna do for the Blast Bags??" Good question. These things have drove me nuts ever since I built the 1/200 scale Yamato. In that build, I tried to use fabric, like bedsheet material, to duplicate the blast bags. The results were ok, but not great. For those of you who don't know what a blast bag is, it is a rubber shroud that covers the turrent where the gun barrel enters it. This keeps out water and debris. It is a difficult thing to duplicate accuratly. I think I have found a solution to the problem.At least, another attempt at them. Read on......................
Here's my attempt at solving the blast bag configuration. I have made a simple master pattern from balsa wood and modeling clay, seen on the left of the photo. The base and the wood dowel you see are at the correct angle that I want the guns to be at, about 15 degrees. The clay forms the "bag". This pattern was then vac-u-formed with red plastic, which, when heated, is thinner than white plastic. The vac-u formed part is seen on the right. Each time I mold the part the clay moves, so each bag is different than the last. I reform the clay after each "pull" from the master.
And here are the results! Note that everything here is loosely placed for now. Once I permanantly attach the barrels to the turrent, I'll slide the blast bag over the barrel and then glue it to the ring that I have made already, as shown here. Once the bag is attached permanantly, I can "scrunch" it around a bit to make more folds to duplicate the rubber shroud. Since the plastic is very thin, I can't fold it up too much more than you see here, otherwise it will tear. But, that can be fixed too. More fine tuning to come, --I'll get it.
Another view of the turrent, barrels and the blast bags. I'll add a clamping ring around the barrel and the blast bag, made from thin strip styrene, at final assembly. That will cover up the rough edge at the barrel end of the bag.
One last look at the turrent here. Note the folds in the bag don't show up well in this photo, but they are there!!
Thats's it for this update of the BB-58 build. Hope you enjoy!! Back to work!! More to come............. Stay tuned!!
I continue on..................... :thumbs_up_1: :wave_1: :lol_spit_1: :lol_spit_1:
