Calling all USS Wasp CV-7 fans
Charybdis
Re: Calling all USS Wasp CV-7 fans
Post by Charybdis »
On this evidence, it seems certain that CXAM-1 was fitted in her Jan 42 refit.
Your image of LSO McCampbell looks to be from a series of color photos taken in late 1941 or early 1942 according to NHHC.
They look similar but after comparing the photos, I don't think they are from the same series. In the picture I posted, McCampbell is wearing different coloured sleeves and the signal paddles are a different design to the picture you posted. I also agree that the CXAM-1 is visible in your photo but it's absent in mine. It's worth bearing in mind that McCampbell joined the WASP in April 1940 and was with the ship until rescued when she went down in Sept 42. Other interesting points in my photo are the searchlight platform which is in it's original layout with 4 x 36" searchlights (reduced to 2 in Jan 42 refit). Another point is the light grey paint on the radar platform, part of the Measure 4 scheme, also absent from your picture. And.... In WASP's original configuration, there was a large over hang on the top of the Navigation Bridge, port side aft (you can see it clearly in the commission photo I posted above) which was removed in the Jan 42 refit. It is missing in your photo. This leads me to believe that your photo is from 42 some time. You can just see the light area of camo on her funnel under the searchlight platform. It may even be from her Pacific service when a large number of other colour photos were taken.
I've also found that some official photos have got their dates incorrect; for example this official photo says this is probably WASP in San Diego in June. This cannot be, as the 40mm sponson, portside aft is missing. This was fitted in the June 42 refit and then she sailed directly to the Pacific due to mounting US carrier losses. It's visible in the lower picture from San Diego. I believe this photo is from April 42 at Scapa Flow, as I have other areal photos with identical planes spotted on the flight deck.
https://www.dropbox.com/s/67kgkzcuym848 ... .jpeg?dl=0
https://www.dropbox.com/s/7mri5ko4rhgcj ... 7.jpg?dl=0
SeanF
Post by SeanF »
Nice photos, Charybdis! Early Wasp with her black-tail airwing is one of my long-running projects. I'd especially love to see pictures showing her name written on the flight deck. (I'd expect it would be W A S P at each end, but seeing how Enterprise made due with only the two letters E N, and how Ranger only had R N G R at the stern, it'd be nice to find some confirmation!) I have the feeling that the photos are out there somewhere...
Just imagine all the fascinating details we might find in all the other photos that were no doubt taken, but not chosen for publication because they were a little out of focus or deemed uninteresting for the general public... That series of color photos of the battleships off Hawaii in 1941, for example, I'm sure that wasn't all the photos that were taken...
- Sean F.
Charybdis
Post by Charybdis »
I haven't come across any such pictures but I think it's quite likely she did have the WASP letters at either ends of the flight deck as shown in the builders plans (available to download at HNSA). HORNET CV-8 was completed late 41 and also had for a short while HNT on her deck, although I think the paint was probably white and not yellow. Unless someone turns up with a photo, we'll never know for sure.
When the Navy officially went to blue stained decks the lettering and lines were a stain to match 5-O Ocean Gray, not white. One area we're still exploring is that "each ocean" was doing camouflage experiments. We have a bit on the Atlantic fleet here and I have some documents for Enterprise in 1941 I need to get posted.
In March of 1940 CINCUS Fleet authorized the painting of one carrier experimentally with gray ramps and to experiment with the fore and aft lines "with the view of cutting down the possible assistance that these lines afford hostile bombers."
In May of 1941 the Bureau of Aeronautics forwarded and a recommendation from CINCUS Fleet to the Bureau of Ships that new construction be painted:
1) One yellow center line stripe, 4 inches wide
2) Two yellow fore and aft stripes, 16 inches wide, twenty feet on each side of the center line.
3) Athwartship yellow lines, 16 inches wide, under the first and ninth arrestor wires "from both bow and stern" (Remember that carriers were designed to also steam backwards and recover aircraft over the bow in case of damage) extending approximately six feet beyond the lines in item 2) above.
4) Abbreviation of the ship's name in 10 foot tall letters, ten feet from the ramp knuckle.
Post by Rick E Davis »
Well I goofed in not looking more closely at the main subject in the image. I was focused on the similarity of the photos. Do you have a source for this photo? There should be a 80-GK number associated with it. Many of the dates provided with photos from WWII are suspect and need research to verify or establish a date. Many dates given are when the photos were turned in, some are labelled as "Rec'd Date".
The photographers onboard USS WASP (CV-7) were quite prolific during her career. I have come across quite a few images (most are B&W of course) that they had taken of ships they sailed with during her career and their surroundings. Her aerial photographers took photos of their ship as well. USS WASP photographers took a series of famous color images of the ships in their convoy on her passage from San Diego to Tongatabu. It appears that her photos and color film (processing of color onboard ships wasn't possible) taken during that trip were turned in at Tongatabu, because no "verified" photos taken by USS WASP after Tongatabu up to her lost seem to exist ... likely going down with the ship.
I can help on a couple of the images you are referring to. This color image, 80-GK-447, of USS WASP (CV-7) erroneously dated as June 1942 at San Diego (the configuration didn't match that date), has been an unknown as to place and date when taken. See first image. I scanned the original 5x7 transparency at NARA. I also, found other images obviously taken at the same time and which seldom get used. Two other overhead aerial views, 80-GK-448 and 449, are generally not used because they are out of focus!! However, another overhead view, 80-GK-451 also a 5x7 transparency, showing USS WASP (CV-7) in company with other ships allowed me to be able to determine the date and place. See second image.
The second image shows USS WASP with the same aircraft deck park as the first image. But more important is the fact that USS NORTH CAROLINA and USS WASHINGTON are BOTH anchored near her. USS WASP and USS WASHINGTON operated together often in early 1942. However, USS NORTH CAROLINA was seldom with either of them during that period. By going through Deck Logs, I found that these three ships were only together from late 24 to early 26 March 1942 at Casco Bay, ME. USS WASP arrived late on 24 March with cruiser and destroyer escorts to meet up with USS WASHINGTON and other units designated to be part of TF 39 (becoming TF 99) that left for the UK early on 26 March 1942, to be temporally part of the Home Fleet.
Hence these photos have to have been taken on 25 March 1942, at Casco Bay just prior to a historic Task Force departure. Whose aircraft was used to take these photos, is an unknown.
In addition, I came across and scanned this image, 80-GK-768 another 5x7 transparency, taken onboard USS WASP at San Diego. Since USS WASP arrived at San Diego on 19 June 1942 and departed on 1 July 1942, this photo was taken during those dates. You should have a pretty good idea of what her deck and markings looked like at that time. This is likely one of the first images taken with color film from the voyage to Tongatabu.
Charybdis
Post by Charybdis »
Marvelous stuff. So do you think that WASP would have had yellow lines though to Nov 41? The lines are definitely there in the Iceland picture I posted above. However, they seem to be larger than 16 inches in width.
In the article by Michael Vorrasi that you linked, it stated that the yellow stripes were painted over but could still be seen. This could be the case with the 8th Pursuit Group picture I posted above with the two tone stripes but then that would be a bit odd in October 1940 so therefore it that photo should be during the Iceland trip in July 1941. Would make a bit more sense.
That's great. I was convinced it was Scapa Flow, but the presence on NORTH CAROLINA and WASHINGTON seals it. Lovely photos by the way. I have those pictures but not in color.
On to another picture series...
I found a picture on NHHC dated March 42. I then found other angles of what appears to be the same time due to the way the planes are spotted on the flight deck. There's on image with a few more planes but I still think its from the same time. I would be interesting to know if it's before or after the collision with STACK DD-406 on the 17th March 42.
https://www.dropbox.com/s/7mp4tojrk2mo9 ... .jpeg?dl=0
https://www.dropbox.com/s/7sz41cry47u38 ... 9.jpg?dl=0
https://www.dropbox.com/s/1sqiyd6ej3m2kyl/003b.jpg?dl=0
Does this one also fit?
https://www.dropbox.com/s/ret5fl0m6jaxg ... 9.jpg?dl=0
I have four images of USS WASP (CV-7) "dated March 1942" (no idea if the dates are accurate). Two show her in a port and look to be taken at the same time from different elevation angles. The other two are at sea views.
Charybdis wrote:Marvelous stuff. So do you think that WASP would have had yellow lines though to Nov 41? The lines are definitely there in the Iceland picture I posted above. However, they seem to be larger than 16 inches in width.
Keep in mind that the memo I summarized was for new construction. We often see separate recommendations for new construction versus ships in the fleet, but from what I can remember it was usually early versions of what was going to be ordered for the fleet(s) and this one seems to lag the push for camouflage flight decks by quite a few months. I'll be at archives within the next month or so and if I have time I'll pull the box that would have Wasp's camouflage documents (if there were any specific ones) to see if there is any mention. There are multiple boxes of records are in volume format (arranged chronologically versus by subject) and I won't have time to go through them, but there's about ten arranged by subject so there's a good chance there's something of use there.
Generally what you find is specific directives for the ship or pertinent directives for the "type" of ship or fleet, but nothing like deck logs that list out what was used and what day it was applied, etc.. Often times all you see in shipyard reports is "painted as per current directives."
Charybdis
Post by Charybdis »
Would you be able to share these images?
It's interesting to note that in these pictures, the 1.1" gun director forward of the bridge is missing but present at Scapa Flow the following month. This must mean that it was installed in the Norfolk Navy Yard visit on the 21st March after the collision with STACK. Also, I can't clearly make out the 2 x 20mm guns on the Forecastle deck.
Regarding the last image I posted, I have my doubts if this fits with the other three photos. Mainly because the roller doors are arranged differently, as well as the extra planes on the Flight Deck. However, all the planes seem to have the red and white striped tail fins particular to this period.
Your knowledge and dedication are much appreciated.
I didn't finish my message above before hitting submit. I was going to say that most of the images I have from March 1942 duplicate ones you have posted already.
Anyway, these first two images show USS WASP (CV-7) at anchor somewhere. I suspect Hampton Roads or during her travel to the UK, but don't know for sure. The aircraft parking doesn't look like the aerial views at Casco Bay on 25 March 1942. The first one is an aerial as you can see, likely taken by a cruiser seaplane. The second image looks like it was taken at the same time based on the aircraft parking and boats alongside. There wasn't enough info on the caption or identifiable ships in the background to establish a likely date range date.
These two aerial views duplicate some of the ones that you posted. Again there isn't much info to go on, except likely they were taken by aircraft from USS WASP.
Charybdis
Post by Charybdis »
Thanks for sharing. I think we're getting somewhere with these shots.
According to DANFS, Casco Bay is mentioned twice in 1942.
First, after the Jan 42 overhaul were she went on patrol in the North Atlantic touching on Casco Bay and Argentia, Newfoundland. There are a few shots from Feb '42 with crew shoveling snow off the flight deck. She headed home toward Norfolk on March 16th. She collided with STACK on the 17th and arrived at Norfolk on the 21st March.
During the three days in Norfolk, her 1.1 inch gun director was fitted. Then she sailed for Casco Bay and arrived on 25th March and left the next day for Scapa Flow.
Here's my conclusion.
What I call the Casco Mill Pond photos were taken either in Jan or Feb 1942 on her way to her North Atlantic patrol because in the picture you posted of her portside, the 1.1 inch director is missing. Whereas in the aerial photos there is a stiff breeze over the water, in the color shot, the director can just be made out.
https://www.dropbox.com/s/umlr7na7s2u6g ... t.png?dl=0
https://www.dropbox.com/s/xngd7sm89ufsg ... m.png?dl=0
Further evidence would be this shot of WASHINGTON leaving Casco Bay on the 26th March. The sea state looks very similar to the above picture.
https://www.dropbox.com/s/3yjvwanp8i7oh ... 2.jpg?dl=0
I suppose the flaw in thi theory would be if WASP made several visits to Casco Bay. There is a photo of ARKANSAS on Navsource which clains to be at anchor off Portland and taken in Feb.
Charybdis
Post by Charybdis »
Here's the definitive proof that WASP had her name painted on the flight deck. I came across this image while watching a documentary on David McCampbell by the US Naval Institute "Ace of Aces". I'd love to have a better resolution for this photo, so if anyone has it, please post it. The ship is in Measure 12 (graded) and I think it's likely taken in Hvalfj�r�ur in Iceland, Sept/Oct 41 but I can't be sure.
EDIT: another point of interest is that the No.1 elevator seems to be in a raised position; something not often seen in pictures.
https://www.dropbox.com/s/8yvdikidu0sxk ... 1.jpg?dl=0
SeanF
Post by SeanF »
I see the evidence at the bow... four distinctly discolored patches straddling the deck stripes, right across where the deck edge angles our as you move aft from the jack staff. No doubt an effect of the original lettering poking through the new deck stain when she repainted into Ms. 12 (original), but completely obscured in her Ms. 12 (mod) days - as evidenced by many others of these great photos we've been looking at.
Definitely all four letters, with position and size reasonably apparent. I'd consider the bow name a complete lock.
Now, if only those Vindicators weren't sitting right on top of there the stern letters ought to be...
- Sean F.
Charybdis
Post by Charybdis »
If her name is on the fwd flight deck it must be at the stern because, as Tracy said earlier, carrier's from CV-5 to the early ESSEX's were designed to land planes over the bow as well as the stern. It would make no sense to have letters only on the bow. RANGER, LEXINGTON and SARATOGA only had letters on the stern because they weren't designed with this capability in mind. I think CV-8 HORNET was the last carrier to be constructed with letters on deck and these were removed before she became active.
SeanF
Post by SeanF »
Charybdis: I completely agree. Not doubting the stern letters were there (sorry, didn't meant to sound like I was), just wishing for a little more verification of positioning. Pretty sure they'd run aft of the elevator and not across it like on Ranger (since on Wasp there was space for it). It'd be nice to see in the interest of certainty, but I'm satisfied enough to commit to laying down decals with the smallest of chances of needing to re-do them (well, more like cutting masks and painting the deck - no Wasp 1940 decal sheets out there that I'm aware of...)
- Sean F
Charybdis
Post by Charybdis »
I think the general plans booklet are as accurate as you're going to get.
https://www.dropbox.com/s/swu3nw88z52zx ... s.jpg?dl=0
Charybdis
Post by Charybdis »
Seems like the MV Petrel crew have found the WASP.
https://www.facebook.com/rvpetrel/photo ... =3&theater
Amazing to see the carrier in 2019!
Rod Dickson
Post by Rod Dickson »
For those into Grumman AVENGER a/c instruments.
https://www.youtube.com/watch?v=7lG16kuE1HY
DennisJP
Post by DennisJP »
Paul Allens boat found the Wasp. You can look it up on the internet. It was in Jan and just posted last week.
Updated list of available kits and gallery entries on page 1
Return to “Aircraft Carriers”
