What-If Modern USN Battleship
carr
Re: Modern USN Battleship
carr
carr
- navydavesof
With a BB at 900+shipI think we can really get a lot done. While the guns lay silent, the ship
could be conducting missile strikes, or most likely ISR with Shadow and ScanEagle UAVs.
MatthewB
Lasers cannot be used at all as artillery, and they kind of suck at Anti-Ship as well, due to only being able to fire LoS.Admhawk wrote:It sounds like you just want to build more Iowas.
Tell me, where can the armor and 16" guns be made?
It would probably take as long for the manufacturing capability to be created as it would getting the rail guns up to par.
How about lasers? They're starting to be viable weapons.
If you need that many defensive weapons, you're in the wrong kind of battle.
And using a satellite mirror won�t work due to atmospheric distortions.
Rail-guys, though.... There you have all kinds of fun things you can do, included variable ballistic rounds (They have propellant and guidance systems to create extreme ballistics, making it possible to really confuse counter-battery fire). And that isn�t even the funnest thing you can do with them.
MB
OMG LOOK! A signature
Working on:
1/700 (All Fall 1942):
HIJMS Nagara
HIJMS Aoba & Kinugasa
USS San Francisco
USS Helena
USS St. Louis
USS Laffey & Farenholt
HIJMS Sub-Chasers No. 4 - 7
HIJMS Sub-Chasers No. 13 - 16
Working on:
HIJMS Nagara
USS San Francisco
USS Helena
USS St. Louis
- Admhawk
Bob, Sorry this has taken so long, but life gets in the way.
I agree.
To that end, a BB will have a large group of escorts to keep it safe, just like a modern Carrier Strike Group. That�s current Naval doctrine and strategy.
If a BB is offshore making holes in the ground of some enemy, what will it be fighting around it that requires so many defensive weapons?
- If there is another fleet nearby, the BB won�t be doing NFGS, it will be staying out of range or attacking the opposing fleet.
- If there are Aircraft coming in, the Carriers better be active as well as the rest of the battlegroup.
- If there are swarms of fast boats, why isn�t there a fleet taking them out?
- Etc, etc�
When I say the wrong kind of battle, I mean that the BB doesn�t operate alone and neither is it the only asset that is considered for an engagement. If a modern BB is being attacked by overwhelming firepower, then it�s pretty much game over because that means everything else has failed and the enemy is going to win. Or nobody wins because the big red button has been pushed.
A Naval planner wouldn�t send a BB into a fist fight with other Navies, without a whole lot of planning and support.
Current USN Strategy embraces the concept of Distributed Lethality.
http://www.navy.mil/strategic/SurfaceFo ... ontrol.pdf
While Current Naval Doctrine strives for a balance and offers peacetime objectives with deterrents to make fighting undesireable. NDP-1-Naval-Warfare-(Mar-2010)
https://dnnlgwick.blob.core.windows.net ... B7L%2FY%3D
If a modern BB was sent to fight a battle, it would be in a group. A typical standard formation provides a number of layers of defense within the battlespace, designed to give maximum protection to the fleet's high value units (HVUs). If a Carrier is present, it will have Combat Air Patrol and early warning aircraft 200 nautical miles (370 km) or more out from the main body. The ships of the outer screen operate between 12 and 25 nautical miles (22 and 46 km) from the main body. The inner screen is within 10 nautical miles (19 km) of the HVUs.
For the record, I�m a huge fan of the Iowa Class. I�m even working on a 9 foot RC version of the New Jersey. I just don�t think 70 year old gun technology is sustainable in this day and age, no matter how cool it is. I also don't think that enough armor could be put on a ship to protect it. I also think Nuclear power is the only way to go with large ships. It reduces the amount of time needed to refuel, therefore the vulnerable UNREP window is smaller.
It�s not a backward statement at all. You said it yourself, a modern battleship is, primarily, a land attack platform and, secondarily, an anti-surface platform.carr wrote:What an odd and backward statement!Admhawk wrote:If you need that many defensive weapons, you're in the wrong kind of battle.
If you're in that kind of battle, it's the enemy that's in the wrong kind of battle because they're about to be obliterated by a battleship.
I agree.
- Etc, etc�
Actually, they had them because they were so ineffective. If they had any hope of hitting a plane, they had to throw as much lead into the sky as possible to have any chance of hitting it. Missiles can be fired from pretty far away and are getting pretty fast. However, it only takes one hit to disable an incoming missile. The accuracy of modern AAW is far superior to those of WWII. So following modern practice, you simply don�t need as many.carr wrote:You do know how many defensive weapons a WWII Iowa had, right? Do you understand why they had that many? They had them so that they could stay in the fight even if the ship received damage.
I agree. I neglected AAW weapons on my design, most likely because I was overwhelmed by the coolness of it.carr wrote:Let's take the extreme case of a BB with a single close in AAW weapon. If it gets hit, even by simple shrapnel - it's unarmored, then the entire BB is just a floating target to be slowly pounded below the waves. Okay, that's valid, so let's give the ship two AAW weapons.
I totally disagree. A BB used for NGFS shouldn�t be in heavy fighting. That�s what the screen of escorts are for. Same as a carrier. There is also the possibility of interference between so many sensors going active at once, then you�d have to have programming to determine which targets are selected so a million shots don�t concentrate on one missile, ignoring the others. Development of software seems to be a huge weakness in the modern day, delaying a number of weapon systems.carr wrote:A BB is MEANT to be in heavy fighting. Its unarmored topsides may well be riddled. That being the case, we're going to want as many AAW weapons as we can fit so that no amount of damage will leave the ship defenseless. This is also why I called for weapons that have their own sensors - so that no single hit can take out a radar and render all the AAW weapons inoperative.
No need to be rude. Discussions include Criticisms and arguments to support ones views. If you can�t stand the heat, then get out of the kitchen. If my earlier response seemed heated, or angry, it was probably just the short pointed form it took.carr wrote:A note on responses - I'll gladly DISCUSS my battleship concept - it's fun - but I won't respond to people who want to nitpick, criticize, and argue for the sake of argument. We have several of those people on this forum and they contribute nothing worthwhile.
I did. You dismissed it because I thought it was cool. Your response wasn�t what I expected. That doesn�t mean I didn�t think about it. Did you even read my responses to your queries? There may be some refinements that could be made, but I believe the concepts have merit.carr wrote:Maybe consider throwing out your concept of a modern BB. You had a drawing that was, apparently, more of a cool-factor than a real concept. Maybe give it some thought and offer your modern BB features and see how they compare to mine?
Darren (Admiral Hawk)
- navydavesof
Admhawk, nice post but...no, I won�t suppport it. Your belief on BBs seems to be based more on lore rather than reality. There is a very practical reactivation and maintenance plan for the 65 year old Iowas. A new BB would be that plus 60 years...
- Admhawk
I'm not sure I understand "lore rather than reality", can you expand on that?navydavesof wrote:Admhawk, nice post but...no, I won�t suppport it. Your belief on BBs seems to be based more on lore rather than reality. There is a very practical reactivation and maintenance plan for the 65 year old Iowas. A new BB would be that plus 60 years...
Which reactivation plan do you refer to? Link?
carr
- navydavesof
Here is my first draft of what the modern BB might look like!
Very capable and heavily loaded. What do you think?
- EJM
Do you have a higher res version of that pic available? Some details are a bit hard to see. But I do love the concept! Very creative!navydavesof wrote:Here is my first draft of what the modern BB might look like! Very capable and heavily loaded. What do you think?
InchHigh
- EJM
Or a Burke, Iowa, and HMS Daring.DavidP wrote:I thought it was a cross between a Burke & an Iowa.
- navydavesof
An incredible 3some.EJM wrote:Or a Burke, Iowa, and HMS Daring.DavidP wrote:I thought it was a cross between a Burke & an Iowa.
- navydavesof
I just received the base model for this project and some pieces from shapeways. I am really excited about this. While work is getting busy and hectic, we will continue the discussion.
I especially want to focus on:
- Armor (especially missile defense)
- Torpedo defense system
- Armament
- Air facilities for UAVs and occasional air det
- Sensors
- Propulsion type
- Brass etch set
- Boat storage and boat type
- Embarked Marines? For what purpose?
- Paint scheme
- Use of wood on the deck
- The first reliable use of non legacy (SPS-48/49) air search radars but retaining the SPQ-9 ...and this will all be dictated by mission set. What kind of mission should a modern day battleship execute? We will do the opposite of what the Navy does and actually dictate a mission FIRST and then configure a platform to meet that mission with room to grow.
- Armament
- Sensors
- Propulsion type
- Brass etch set
- Paint scheme
carr
InchHigh
The Iowas rarely (never?) engaged in shore bombardment.
You should check that. Missouri bombarded Iwo Jima, Okinawa, and the Japanese home islands during WWII. I'm sure the others were used as well.
carr
carr
- navydavesof
Base model is in hand. 16� turrets are in hand, 155mm/52caliber mounts and barrels are in hand. Now it�s time to lengthen and widen this bad boy. We�re looking at 2.5� in length and widen her by .4�
After the spacers, then the armor belt needs to go on, and the notched stern needs to be lengthened by about an inch. Easy day!
