1/144 Kiev by Dave Wooley
ARH
Post by ARH »
Super Dave, getting better by the day :woo_hoo: :woo_hoo: :eyebrows: :eyebrows: :thumbs_up_1:
Simple but effective.
Sean Hert
Post by Sean Hert »
Ho-ly Moly! I wanna be as good as you when I grow up.... :cool_2:
Sean Hert
Laurent
Post by Laurent »
Hi Dave ,
I'm speechless ... :twitch: :faint: :big_eyes:
the day I'll be able to solder like that will probably never come :pout:
Laurent
Jefgte
Post by Jefgte »
Bravo l'Artiste
Jef :wave_1:
Current 1/700 WL
HMS Repulse
Cadman
Site Admin
Site Admin
Post by Cadman »
Sean Hert wrote:when I grow up...
Sorry Sean, you ain't ever going to grow up.
Dave, awesome work. I would love to see it up close some day. :thumbs_up_1:
Timothy Dike
Owner & Administrator
ModelWarships.com
H.A. Baker
Dave's Kiev
Post by H.A. Baker »
Sean,
I am grown up (I think) and I'll never be as good as Dave. He shows me these bits and I pretend to be non commital but secretly I'm green with envy.
HAB
Edward Pinniger
Post by Edward Pinniger »
As everyone else has said, your work on the radars is awe-inspiring! :shock:
Do you use the same type (melting temperature) of solder for all the joints in the parts? From my very limited experience of soft-soldering metal parts, I found that melting previously-made joints with the heat from the soldering iron was a serious problem.
Post by Dave Wooley »
EPinniger wrote:As everyone else has said, your work on the radars is awe-inspiring! :shock:
Apart from using the variable temperature heat source I use a single temperature solder but make plenty of use of simple heat shunts like paper clips which really are the ace in the pack when fine soldering .Although solder with different melting points can be a distinct advantage. Equally I swear by simple jigs or third hands , so all you need is to concentrate on the job in hand and not be to concerned about soldering and holding the job in place. That's a bit like keeping three balls in the air and rubbing your midrift all at the same time? :cool_2: :wave_1:
Torpedo
Post by Torpedo »
Dave thats simply amazing! When I see, what I try to do with my two left hands...
Can you make a little photo-workshop here? How to from beginning to result?
Uli "Torpedo" Setzermann
http://www.marine-forum.de - Das Kaiserliche Marineforum
Currently Building: SM TrpBt B-110, SM TrpBt S-37
Upcoming: SMS Derfflinger
Torpedo wrote:Dave thats simply amazing! When I see, what I try to do with my two left hands...
I've yet to make the second of the two "Head Light" radar arrays I'll compile a stage by stage build on that one.
Francisco P. de Nanclares
Post by Francisco P. de Nanclares »
Stunning job on those radars!. Realy top notch. Congratulations Dave!.
Pachi.
Image I will miss you Werner. Fair winds and following seas.
J. Soca
Post by J. Soca »
Wooooooooooow, those look great :thumbs_up_1:
Bluehawk
Post by Bluehawk »
Hi Dave!
You done an amazing work! :thumbs_up_1: :thumbs_up_1:
Currently Building: Krivak I 1/72
Upcoming: Udaloy I 1/72
Sovremenny (Type 956E) 1/72
Kirov 1/72
Bluehawk wrote:Hi Dave!
Hi Martin I note that you are presently building a krivak at 1:72 any pictures?
Dave Wooley :cool_2: :wave_1:
Post by Guest »
Hi Dave I'm thinking about an report here in the forum, but i must translate the report first! A German report alredy exist.
Picture from the German report:
The Krivak in my dockyard
Bluehawk
Post by Bluehawk »
Hi Dave,
sorry i forgot to log in so the both pictures above are from me.
Kirov 1/72
Hi Martin thanks for posting the pictures of your Krivak, she looks superb , please post more pictures , when you can , There are many questions we would like to ask. It would be great to see your "Krivak build" on the board :thumbs_up_1: :thumbs_up_1: :thumbs_up_1: :wave_1:
Sean Hert
Post by Sean Hert »
Martin-
You should start a Krivak thread! And then, you and Dave can start a line of Soviet/Russian 1/72 fittings and I can start my Slava!
Sean Hert
The next part of the build was to follow up on the various
platforms and arrays on the centre lattice mast supporting
the "Top Knot" dome. This involved some tricky solder work
as the "V" array is in "see through" form. The construction
of this array posed a problem of how to maintain strength
and symmetry when soldering? The net result was to
make use of a solid removable core and build up the frame
around this core. The other problem was that the array
was angled in two directions , upwards and outwards so
the support arm and the centre tube had to be angled
correctly other wise the entire "V" array wouldn't fit into
place. The remainder of the upper frame works were also
splayed, which made for some taxing solder work.
Support frames for the second platform up
Part of the frame work for the upper spar
One of two support frames for the upper spars
Upper spars and their support frames in place
Support arm for the V" form array around a removable centre
core
V form array with spacers on the centre core. The idea was to try and match the distance between spacers as per the photos of the
�V� array .
Spacers removed with the lengths of .31-brass wire cut and
ready to form the outer supports frame .
The centre core removed and the outer supports of the
V array in place.
The "V" array in place on the platform. Thankfully the two
angles of the support arms were correct. A big sigh of relief
that that bit is completed .
Dave Wooley :wave_1:
ARH
Post by ARH »
Dave, harry would be proud of that work, :woo_hoo: :woo_hoo: looking good.
