Calling all Gato-class (SS-212) fans
SS, and SSN.
Re: Calling all Gato SS-212 class fans
Maybe you're thinking of the older Argonaut and Narwhal class, with two 6" guns? They'd certainly be the most heavily-gunned US subs in the war.
maccrage
Post by maccrage »
Timmy C wrote:Maybe you're thinking of the older Argonautand Narwhal class, with two 6" guns?
I also remember reading about either Gatos or Balaos with 5"/25s fore and aft. They were referred to as gunboats.
Woodstock74
Post by Woodstock74 »
Yeah definitely wasn't the Narwhal or one-off Argonaut, definitely was something more "standard" like Gato. Frankly, might have read about it in the Time Life "War Under the Pacific" as maybe it was one of the high scoring/really aggressive US sub commanders who retro-fitted his sub. So like the Tang or Barb? But I guess the base question is whether or not it's feasible in the first place, which I think it is, because at very least they could choose a fore or aft position for their singular mount, correct? So meaning there's the underdeck reinforcement for a gun in either position, thus you could feasibly mount 2 if you had them? Digging a bit more, seems Friedman discussed this topic in his book so I'll have to have a look when I'm home from work!
Tom Dougherty
Post by Tom Dougherty »
In 1945, USS Blenny SS-324, had 5/25 guns on fore and aft decks. One of the crew members provided me with a videotape from 16mm film of Blenny, using the guns on smaller targets. Not common, but such gunboats did exist.
I built a model from the old Revell Lionfish, which I heavily modified for the crew member, Frank Toon. Frank provided me with information, photos and the videotape. The model can be seen here:
Here�s another couple of examples of gunboats, Cobbler and Blueback
http://navsource.org/archives/08/350/0834416.jpg
http://www.navsource.org/archives/08/0832608.jpg
Tom Dougherty
maccrage
Post by maccrage »
Woodstock74 wrote:Yeah definitely wasn't the Narwhal or one-off Argonaut, definitely was something more "standard" like Gato. Frankly, might have read about it in the Time Life "War Under the Pacific" as maybe it was one of the high scoring/really aggressive US sub commanders who retro-fitted his sub. So like the Tang or Barb? But I guess the base question is whether or not it's feasible in the first place, which I think it is, because at very least they could choose a fore or aft position for their singular mount, correct? So meaning there's the underdeck reinforcement for a gun in either position, thus you could feasibly mount 2 if you had them? Digging a bit more, seems Friedman discussed this topic in his book so I'll have to have a look when I'm home from work!
Yes, gun foundations were present in both positions.
davinort
Post by davinort »
Kit option question:
Of the "old school molds" of Gato/Balao class subs by Revell, Lindberg, Aurora-Atlantis, which one is preferred? Looking for a companion to my Aurora U-505 and I-19 kits. I suspect a new Trumpeter kit will look out of place.
Tom Dougherty
Well, the correct answer for accuracy is:
E.) None of the above
But, the old Revell kit (lately and incorrectly boxed as Liofish, previously Flasher or Wahoo) is probably your best choice. It�s really a Gato class like Flasher, not a Balao class like Lionfish was. You can fill in the limber holes with a black marker or cut them out (a very tedious process). The guns provided are rudimentary and both propellers have the same blade angle twist, instead of opposite screws. If you want, you can cut the blades off the hub on one screw and reglue them on the hub with the opposite twist. The basic hull shape is not bad, either. With some care, it can be made into something decent, on par with the other kits you mentioned. Back when this kit was the �only game in town� for a fleet boat, Nautilus Models came out with more much accurate accessories for the Revell kit. Resin conning tower fairwaters and wood decks. These are still available on their website.
The Lindberg kit is considerably off on several details. The decking is oversized and it is more like a Balao sail than a Gato. At one point Lindberg even put a rocket launcher with a rocket that looked like one from the old Destination Moon film on their Nautilus kit, about to be rereleased by Atlantis. I think Lindberg kits in general are all in the �looks okay, close nuff� school of plastic kits.
The Kit by Atlantis looks decent, but there are no railings around the conning tower fairwater platforms. Looks odd to my eye. At least the Revell kit has plastic railings.
As you know, much better kits in terms of accuracy are on the market. But if this is more or less for nostalgia, go with Revell.
Tom Dougherty
davinort
Post by davinort »
Thanks for this info, Tom.
maccrage
Post by maccrage »
Woodstock74 wrote:Not 100% sure where to put this, as I'm not sure if the sub in question was a Gato, or a Balao, or what, but what was the most heavily armed USN Fleet Boat during WWII? I seem to recall one that was armed with a deck 5" both fore and aft? Or maybe it was a 40 mm and a 5", along with the usual 20 mm on the sail? I think I recall the sub captains experimenting in the field with alternate AAA/armament arrangements, though not certain what was feasible (I mean, how easily could an additional 5" deck gun have been installed, was there even the reinforcement in the deck for the mount?)? I also seem to recall options, fore/aft, as to where the single 5" could go? So clearly you could do that, should you be able to procure an extra 5"? Anyhow, contemplating an armed-to-the-teeth what-if with an extra Gato AFV Club kit I have laying around.
Ok, page 215 of Friedman's US Submarines Through 1945. Shots of Pargo and Aspro, both with 5" /25s fore and aft, a single 40mm forward of the bridge, and a twin 20mm on the cigarette deck.
Tom Dougherty
Foundations for large guns were installed on both fore and aft decks. Several subs (e.g., Bluseback, Boarfish) were armed with both near the end of the war.
Tom Dougherty
krgf15e
Re: Calling all Gato-class (SS-212) fans
Post by krgf15e »
Has anyone ever used the RCSubs for the 1/72 Gato kit? I have used it for U boats and the instructions on the site are clear for them. For the Gato though, I cant tell if the deck goes on top of the plastic or if the deck is supposed to be cut out. Does anyone have any answers for this?
Tom Dougherty
That would be a question best asked on either on the SubCommittee webpage or on their Facebook page. Several people there have converted the 1/72 Gato to R/C. Links below.
https://www.subcommittee.com
https://www.facebook.com/groups/141800550555213/
Tom Dougherty
krgf15e
Post by krgf15e »
Tom Dougherty wrote: Thu Jun 11, 2026 2:36 pm That would be a question best asked on either on the SubCommittee webpage or on their Facebook page. Several people there have converted the 1/72 Gato to R/C. Links below.
Thank you very much sir
krgf15e
Post by krgf15e »
Does anyone know when USS Gato had the Port side anchor removed? The earliest pictures I can find of her without it are taken in August of 1943.
FFG-7
Post by FFG-7 »
krgf15e, I presume you have checked for the latest time that sub had that anchor before it was removed?
krgf15e
Post by krgf15e »
Yes. All of the pictures I can find have a gap between December 1941 and August 1943. The August 1943 picture it has a plate over the anchor well, 1944 has it completely smoothed over.
Tom Dougherty
Gato was overhauled at Mare Island Naval Shipyard in mid-1943. That is probably, based on her war patrol records, the most probable time the port anchor well was plated over. It’s probably MINSY where the additional limber holes in the Government Yard pattern were added to Gato’s Electric Boat D-shaped limber holes.
As far as I know, Gato and a very few early Gato’s (e.g. Grouper) were the only boats that had both limber patterns. Virtually all the boats constructed by EB or Manitowoc, which used EB plans, had the D-shaped, half moon limber holes only. The Government plans (MINSY, Cramp, Portsmouth NSY) had the multiple rows of limber slots. Government design had portside anchors, EB anchors were starboard. Except of course for the early Gato boats with dual anchors. Cutbacks of the conning tower fairwaters to reduce silhouettes occurred throughout the war on the Gato’s with a series of modifications over the time period. A variety of modifications to radar antennas and their locations, gun outfitting, and other items occurred based on the war experience and technical developments. Best to pick a specific submarine at a specific time for a model.
The Balao and Tench classes incorporated some of the lessons learned in their construction. Visibly, the fairwaters were very different, again with several variants. Both Balao and Tench classes had deeper test depths than Gato class due to different hull steel and thickness. Of course those are not visible modifications. The Tench bow had a different shape below the waterline that allowed additional forward torpedos to be carried.
Tom Dougherty
krgf15e
Post by krgf15e »
Tom Dougherty wrote: Sun Jun 28, 2026 8:32 am Gato was overhauled at Mare Island Naval Shipyard in mid-1943. That is probably, based on her war patrol records, the most probable time the port anchor well was plated over. It’s probably MINSY where the additional limber holes in the Government Yard pattern were added to Gato’s Electric Boat D-shaped limber holes.
Thank you sir, I am going for the August 1943 all black or the Feb 44 Measure 32 . Both of those are before the covered wagon cutdown. The Differences between those appear to be mainly the 20MM pedestals and on the Feb 44 the Port anchor cutout was smoothed over instead of the obvious plate in Aug 43. I have everything to do her in 1/72 except the Fore and AFT wooden deck set from RC subs which I hope to have soon.
Return to “Submarines”
