Calling all Brooklyn-class (CL-40) fans
David Sandifer
Re: Calling all USS Brooklyn/Helena class (CL) fans
Post by David Sandifer »
Trying to contact maccrage of Milwaukee, OR regarding your Shapeways Brooklyn superstructure. Haven't seen you post since 13NOV2021.
taskforce48
Post by taskforce48 »
Random one for you all, decking on the stern of the USS Helena in 1942.
All drawing I can find of the Helena all show her deck planking ending just fore of the Hangar cover.(Blue arrow) which is supported by an image of her fitting out on page 4 of Leeward's Damage Report No.1.
However, this image of St. Louis in March of 1942 shows the planks ending further forward (Red arrow)
Question, did the Helena get the same treatment post 12/7/41 repairs or was St Louis built this way? On page 26 of the Leeward publication, there are two images I have not seen elsewhere of the Helena finishing her refit, one shows a potential answer shot but in the book it's not high resolution enough to pick out the decking. I have found two of the images in high resolution that are on that page, but the one in the bottom left corner I have been unsuccessful in tracking down.
TIA
DrPR
Post by DrPR »
I'm pretty sure the wooden decking did not go past the red arrow in your drawing. In the photo you can see the line of the transverse margin board (there the wood decking stops) crossing the deck just aft of the vents and other equipment.
The hanger cover front end is where your blue arrow shows when the hanger is closed. But when it opens if rolls forward on the two tracks visible in the photo and drawing to where your red arrow points. There is no wood decking between these rails.
The Clevelands were like this too.
I would guess that the catapults, hanger cover rollers, airplanes and such would leak oils and grease that would stain wood decking. Also, for the lower 6"/47 triple turrets the blast from the guns might also burn the decking. At least the wood decking stops aft of the gun barrel muzzles up forward, and ahead of the muzzles aft. I don't think this was a real problem though. The USS Oklahoma City CLG-5 had wooden decking extending far forward of the 6"/47 turret and it pumped about 18,000 6 inch rounds out of the forward turret in Vietnam. If there was any charring of the teak it was easily removed by holystoning.
Mike C
Post by Mike C »
bwross11 wrote:Greetings all,
This is a bit of a long shot, but I have in mind a project to build the aft section of a Brooklyn/St. Louis CL where the hangar cover would open by motor.
I have found a picture taken at the aft end of the hangar deck looking forward, but I'm wondering if anyone else has found any kind of pictures of the insides, or a general plan illustrating the general layout that I could use to fill in some of the blanks.
Thanks in advance,
Too late?
Quincy
Post by Quincy »
With Vee Hobby future release of a 1944 Honolulu, how difficult would it be to backdate it to a 1942 version?
Bob
maxim
Post by maxim »
DougC
Post by DougC »
If it helps, here is a youtube about Cleveland class hangar.
https://www.youtube.com/watch?v=wT6pRbK4bfg
Quincy
Post by Quincy »
Thank you Maxim :thumbs_up_1: :thumbs_up_1:
Bob
FFG-7
Post by FFG-7 »
CL-46 USS Phoenix Booklet of General Plans (19XX) (version 1) https://archive.org/details/cl46bogp19xx
CL-46 USS Phoenix Booklet of General Plans (19XX) (version 2) https://archive.org/details/cl46bogp19xxv2
CL-46 USS Phoenix Booklet of General Plans (19XX) (version 3) https://archive.org/details/cl46bogp19xxv3
sdk10159
Post by sdk10159 »
Quincy wrote:With Vee Hobby future release of a 1944 Honolulu, how difficult would it be to backdate it to a 1942 version?
Bob
Does anyone have any info on when this kit will be released?
Steve
TZoli
Post by TZoli »
Does anybody have drawings of Brooklyn and St Louis classes as finished? before the additions of Oerlikon and Bofors guns, eg with the Browning MG mounts?
TZoli
Post by TZoli »
Do somebody know the mark number designation or drawings of the Brookyln class 6" main battery directors?
It does not appear to be the Mark 34 type:
https://www.history.navy.mil/our-collec ... 92370.html
it looks much different:
Mark 33 director, open-top variant (covered with canvas and facing backwards in those two photos), and before radar was installed.
maxim
Post by maxim »
Mk 33 was the director for the 5".
According to Terzibaschitsch, Brooklyn originally had Mk 31 directors for the 6".
TZoli
Post by TZoli »
maxim wrote: Tue Nov 18, 2025 8:48 am Mk 33 was the director for the 5".
Thanks!
So two Mark 31, two Mark 33 and apparently a 12ft mark 35 in front of the forward Mark 33, above the erm... Pilot house?
Dick J
Post by Dick J »
I would be careful about some of Terzibaschitsch's information. Friedman is a much better source. The directors on the Brooklyn's were, in fact, an early version of the MK-34. They had spotting glasses protruding from the sides rather than the rangefinder found on the later versions of the director. Vincennes (CA-44) also had the same early version of the MK-34. Compare her directors to the MK-31's on the earlier New Orleans class ships. The Vincennes directors are visibly larger. During the war, the Brooklyn class MK-34's were modified with a rangefinder, but remained visibly distinct from the later MK-34's. Vincennes was lost before her directors could be modified.
TZoli
Post by TZoli »
I think Wichita carried the same Director for the main guns as the Brooklyns. I don't know if such large difference in shape and size would allow the same designation.
Friedman barely mentions such data.
Dick J
Post by Dick J »
Wichita and the two St Louis class ships had the rangefinder in the MK-34's from the beginning. A director system has multiple elements that define it. There are the "input" elements, which are the manned positions within the rotating structure, and a stable element and computational element below decks. The outer shell of the rotating element can change over time without leading to a change in designation. Consider the MK-19 AA directors. As originally mounted on the battleships, Lexington's, Pensacola's and Northampton's, there were two visible parts: the main director element and a separate "altimeter"/rangefinder element. On the battleships and cruisers, these were later mounted together on a rotating platform with a covering shell. The appearance totally changed, but they were still designated MK-19's. Lexington retained the separate pieces of the system to the end, while Saratoga upgraded to MK-37's. On the MK-34's, the other elements remained the same. They just had to modify the shell of the rotating part to include the rangefinder - first on the Wichita and St Louis, and then later on the updated structures on the Brooklyn's.
sdk10159
Post by sdk10159 »
One of my favorite ship classes is the Brooklyn. I've been waiting for a long time for a Brooklyn in plastic and I was really excited to hear that Vee Hobby was going to release one this year. No release yet and Vee Hobby does not answer on FB. Yes, I'm inpatient. :big_grin:
But, I just discovered Niko Models and a USS Helena is available on Squadron. I googled Niko, but I don't see any reviews on them. I'm not a big fan of of resin, but the images on squadron look good. Does anyone have any critique on Niko?
Steve Kubik
maxim
Post by maxim »
I have built Helena using the Niko Model kit.
There are two small issues:
a) the rear Mk 33 has to be positioned more forward
b) the anchors are too much forward
Usually Niko Models are easy to built.
Return to “Cruisers”
