Calling Alaska-class (CB-1) fans
Re: Calling all USS Alaska class (CB) fans
Just a note on "splinters" these were a very serious danger to exposed positions outside the main citadel. Even gun shields and tubs are often made of 20 # (1/2") STS. Directors etc were often covered with somewhat thicker plate but not considered "armor" against first shell hits, but again protection against "splinters" resulting from nearby hits or even near misses.
- BB62vet
Here is a photo of CB3 in Philly in 1947:
You can see the windscreen frame and canopy on the Secondary Conn (upper level open bridge). This station is manned during entering & exiting port evolutions, not during General Quarters or at sea operations.
The Plexiglas windscreens are designed to give added protection against the elements for bridge personnel and I can say as one who has stood many bridge watches during good and also extremely inclement weather conditions that the windscreens were a welcomed addition - aesthetics be damned! When you're taking Greenies over the bridge in 35' Pacific swells, the windscreens were a welcome addition!
Just my 2 cents worth!
Ian Roberts
Interesting stuff - I didn't know this station was not manned while at sea (GQ makes sense). I assume at-sea primary conn is inside the armored conning tower below the 40mm position atop the "bridge"? The photo of CAPT Noble on the bridge would indicate he's using the secondary conn at sea though.
Friedman's Cruisers quotes a letter sent by P. K. Fischler (the ship's first CO) mentioning the bad visibility from the conning tower position and how it was easier to conn the ship from forward sky control (I assume that means the 09 level forward).
rotley
Most likely anyone else building the Hobby Boss 1/350 USS Alaska will be aware of this but whatever you do DO NOT follow the instructions when attaching the chocks (?), part K41 to the main deck. If you do you will not be able to attach the guard rail.
That will teach me to not study the instruction book right to the last page.
alexkon3
Nono don't get me wrong here I did not post here because I wasn't satisfied. I posted about the same time here because I was looking for models showing the screens. I thought maybe multiple people know stuff about this! I hope I didn't offend you or anythingIan Roberts wrote:Ha, I answered this exact same question (a literal cut and paste) over on the Shipbucket forum and even told the guy to come ask here if what I had provided wasn't useful enough. Here's the post: http://shipbucket.com/forums/viewtopic. ... 01#p186601
I bet Rick Davis might know the exact date the windshields became widespread!
alexkon3
Really thats the secondary con? I'll add to Ian Roberts that I would like to know more about that because in the Pic of Capt. Noble he seems to be up there and I also read that passage in Friedmans book. During General Quaters I can understand going into the Conning tower but normaly at sea? this would inhibit visibilty of the CO, wouldn't it? The plan froM Floating Drydock calls it Conning Station. Also the plans in Friedmans book calls it Conn. Maybe you are confusing something here because of the comment that "any captain can chose to stay on the open bridge and get shot if he wants to" or something like that in Friedmans book?BB62vet wrote:Here is a photo of CB3 in Philly in 1947: You can see the windscreen frame and canopy on the Secondary Conn (upper level open bridge). This station is manned during entering & exiting port evolutions, not during General Quarters or at sea operations.
I like those screens, I don't like open bridges all to much so I understand that you'd like em
alexkon3
Okay I�m reedditing this question because the question I asked here was answered a few pages earlier. Now for something different. How were the Alaskas as ships? I know that the Con was cramped and that it was found that the catapults were akward. We have one scathing review of the ship by captain Fischler and Admiral Rowcliff defending her. Besides Friedmans book there isn�t much written and most of the articles mentioning her use Friedmans book as source. Even tho they came into service after their objective of killing cruisers and Panzerschiffe was gone how would they have faired? In friedmans book its noted that they had a problen manovering, is this a true statement or is it just hyperbole? Tbh I can�t imagine a ship longer then NoCal to be realisticly super manoverable without sacrificing speed so what was expected? So what is the more balanced view of the Alaskas?
In Service the Alaska's had a maneuvering radius of about 800 yards. The original pessimism was based on model basin tests. For comparison thins is very similar to and slightly better than the maneuverability of both Fletcher Class Destroyers and Iowa Class battleships.
Capt Fischler did not take Alaska into combat and some changes had been made after the original shakedown. Early in the war the Japanese Kongo's created considerable consternation for USN operational planners as they created significant issues for US carrier groups which were at the time escorted by cruisers. In reality the Alaska's were probably almost as useful as the Iowa's for the role in which they were employed as FAST carrier escorts against cruisers, destroyers and as AA ships. Though they carried not as many 5" and 40mm weapons as the larger ships, they were considered good gunnery ships and had good dispersion of the batteries and open sky arcs. For instance the centerline weapons are particularly effective. They only had two Mk37 directors, which is a little bit of a limit on multiple targeting, however in a pinch the Mk 51 units could also direct the 5" mounts.
When the steel shortage forced delay or cancellation of the Montana's, Kentucky and Illinois, construction on Hawaii was not canceled as there remained interest in the utility of the type.
Though the Iowa's 16" 50 was probably the finest Naval Rifle ever fielded by any power, the Alaska's 12" was also a very fine weapon. However logistics always play a role and having another large caliber round available for the fast carrier force tended to complicate things. We think that Joe might make a good Marine but we don't want to issue other than size nine shoes...
- chuck
Regrettable a ship that close to completion was to be scrapped incomplete.
Various schemes were proposed to use Hawaii for other purposes, mostly with regards to missiles etc. However in any proposals to modify BB & CB's post war, their armor often proved the biggest obstacle, difficult to remove or alter! Additionally ships must remain in the water with appropriate balance and draft. Not insoluble problems, but ones that reduce the cost effectiveness. In the event such often somewhat experimental programs were conducted on existing CA hulls.
Weapon systems and ships often are affected by political sponsorship. Whether or not choice of Missouri as the site of the surrender ceremony was influenced by HST being a proud Missourian is an interesting question. Certainly states were proud to have a Battleship in service bearing their name.
Never as a serious combatant... However the hulls were large enough to suffer various removals and addons. Mississippi replaced Wyoming as a training and experimental ship as part of a 1945 post war program. The original plan was to remove turret 1 and replace with the new 6"47 DP , turret 2 by instrumentation, turret three by the new triple rapid fire 8"/55 turret later used in Des Moines. Turret 4 was retained. Additionally there were various other mounts of the single and dual 5"/54, some 5"/38, 3"/70, 3"/50 etc.
A smorgasbord ship to try out a little of everything. Early 50's the ship was outfitted to test and was the first to fire the Terrier 28-29 Jan 1953.
Many WWII ships were retained in the reserve fleet with reductions beginning from circa 1960 on. I remember seeing Massechutsets swinging at a bouy in Sinclair Inlet (1959?) before getting towed off to the razor blade factory...
DougC
The Massachusetts was not made into razor blades. It is a museum ship at Fall Rivers , MA.
You are of course correct! I saw way too many ships of that era be towed off, nests of destroyers, cruisers and the great lady "Bunker Hill". I am pretty sure that Indiana was there as well during that time.
The bridge and pilot house on the 07 level was intended as the primary conn station except in Battle where the armored conning tower was to be used. Apparently this decision was arrived at after a long drawn out fisticuffs was finished with regards to use and value of armored conning towers. Originally an open bridge immediately above the conning tower was envisioned but placement of a 40 mm Quad in that location was considered essential. Initially it was thought that installation of a catwalk around the front of the conning tower (Ala SODAK and friends) would interfere with the 51 mount. However in the final event such a catwalk was installed, note photo of Hawaii.
- mister me
hello,
i read the whole thread but did not found anything conclusive concerning the famous bow step just below waterline.
is there some definitive comprehension about this point ?
thank you.
thank you.
Ian Roberts
I'm also very curious about this topic. I have a set of plans that show the "stem extension for CB-2", but it's unclear to me 1) why this modification was required, and 2) if CB-1 also received it (and when).
Any info would be helpful. It's obvious from photos of CB-2's stem that it curves at a different angle than CB-1 (which makes me think the modification was indeed done to Guam), but Alaska photos aren't so clear.
Wild Az Guess? A heavier shell plating was added in this area, afterwards?
Zacharias
What is the deal about 1/350 Hobby Boss USS Alaska bow shape (that strange "step" below waterline), is that correct shape or that step needs to be removed?
Any pictures of the correct USS Alaska bow line available as a reference?
tigerdvr
The HobbyBoss Alaska bow profile is correct as far as I was able to establish when I built it in 2019.
Cheers, Harley
Cheers, Harley
Zacharias
Thanks for reply, what reference did you use back then to check it out?
Any idea what is the concept (purpose) behind that kind of strange stepped curve bow shape?
Have never seen anything like that before in any other ship class.
tigerdvr wrote:The HobbyBoss Alaska bow profile is correct as far as I was able to establish when I built it in 2019.
Cheers, Harley
