Calling all IJN Sub-Chaser fans
MatthewB
Re: Calling all IJN Sub-Chaser fans
Post by MatthewB »
I also see that Five Star also makes a short 8cm/23.5 (3-in) gun. Some of the sub-chasers had these in lieu of the 40mm Pom-Pom or the 3rd Year Type 8cm/40.
MB
OMG LOOK! A signature
Working on:
1/700 (All Fall 1942):
HIJMS Nagara
HIJMS Aoba & Kinugasa
USS San Francisco
USS Helena
USS St. Louis
USS Laffey & Farenholt
HIJMS Sub-Chasers No. 4 - 7
HIJMS Sub-Chasers No. 13 - 16
ch hoeltge
Post by ch hoeltge »
Yes they are new :woo_hoo: .
I had needed them for my Wa-1 Minesweeper.
So a welcome additon :thumbs_up_1: from Fivestar.
It becomes more and more my favorite company :big_grin: .
Greetings Christian
At work:
1/700 IJN Yahagi
juergen.klueser
Post by juergen.klueser »
MatthewB wrote:...I cannot find any information about SC 103. SC 102 was the Captured USS Stewart (DD-224), a Clemson-class 4-stacker. It was technically known as PB-102, but was used as a Sub-Chaser. ...
Patrol boat and sub chaser number ranges denoted different boats. Auxiliary Sub-Chaser 103 was Cha 103, a former Dutch Mine sweeper of class B1.
Cha102 was the former Ardjoeno.
rafacarasig
Post by rafacarasig »
Hi
Im trying to build the Five Star Type 1 Submarine Chaser
I have a question, is the deck all steel? Or is it with linoleum or even wooden deck?
Thanks in advance.
MatthewB
Post by MatthewB »
As far as I can tell, the deck was all steel.
I like these little sub-chaser kits. As soon as I can get my desk re-cleared off, I hope to finish the three I had started (and nearly finished before my cat chewed them - I had to order replacement PE from Rainbow and Five Star).
The Five Star kits are a bit sturdier than the Rainbow kits, as well.
But, from my reference materials, it looks like the decking is all steel. It had the tread-pattern on some of them.
MB
Working on:
HIJMS Nagara
USS San Francisco
USS Helena
USS St. Louis
rafacarasig
MatthewB wrote:As far as I can tell, the deck was all steel.
MB
Thanks on this, i'll now start priming and painting
rafacarasig
Hi
Im stumped at the instructions of thw five star models for their Type 1 Submarine chaser. The instructions call for a dual gun mount but does not indicate where to put them, although obviously at the bow but i cant find enough references that indeed there was a gun mounted there.
Forgive me for the ignorance but are these sub chasers un armed except for their depth charges?
MatthewB
Post by MatthewB »
They typically had single dual 40mm Vickers Automatic Guns (similar to the British Pom-Pom, but only two guns, side-by-side).
These were known as the 40mm/62 (1.575") "HI" Type 91:
http://www.navweaps.com/Weapons/WNJAP_40mm-62_HI.php
Sorry that there isn't a better image of one of these that I can easily track down.
Some ships would have the 8cm/40 (Actual 7.62cm or 3") 3rd Year Type, 11th Year Type, or Type 88:
http://www.navweaps.com/Weapons/WNJAP_3-40_3ns.php
The 8cm/40 was found mostly on the later Type Sub-Chasers, such as the No. 13-class and No. 28-class. But I can swear that I can see one on one of the No. 4-class Sub-Chasers (But it could also be a board).
But Sub-Chaser #1 had the 40mm Vickers gun, and later had it replaced by a dual version.
No one makes a decent one, and I have had to scratch-build them out of styrene (I do have a 3D file for the gun, but have yet to get it printed due to a computer failure that I have yet to fix).
MB
Working on:
HIJMS Nagara
USS San Francisco
USS Helena
USS St. Louis
rafacarasig
Thanks a lot Matthew!
So the 40 mm is a single gun variant for the early or i stick with the kit supplied dual 40mm for the late? TIA
intending to depict the CH 1 or CH2 assisting the invasion of Aparri in '42
MatthewB
Post by MatthewB »
rafacarasig wrote:Thanks a lot Matthew!
As far as I can tell, that isn�t a PE "HI� Type 91 dual-40mm that comes with the No. 1 Sub-Chaser, but rather a plain-old Type 96 25mm or Type 93 13mm twin-AA Gun Mount.
That was one of the reasons I started with my No. 13 Sub-Chasers, as they had the 8cm guns, which Five Star makes proper models for.
MB
Working on:
HIJMS Nagara
USS San Francisco
USS Helena
USS St. Louis
ch hoeltge
I haven't the kit yet but from the layout it seems the No.1 kit has the 40 mm gun.
It looks similar to the one supplied in the No.53 kit.
Greetings Christian
At work:
1/700 IJN Yahagi
MatthewB
Post by MatthewB »
ch hoeltge wrote:I haven't the kit yet but from the layout it seems the No.1 kit has the 40 mm gun.
Greetings Christian
I think those are just Type 93 or 96 AA Guns (13mm or 25mm).
I haven't seen anything in any of the kits that looks like the 40mm Pom-Pom.
I've built one out of Styrene, and the base to one of the 80mm AA Guns from Five Star.
MB
Working on:
HIJMS Nagara
USS San Francisco
USS Helena
USS St. Louis
Harpy
Post by Harpy »
Niko makes a 1/700 40mm.
tom!
Post by tom! »
Hi.
MatthewB wrote:They typically had single dual 40mm Vickers Automatic Guns (similar to the British Pom-Pom, but only two guns, side-by-side).
MB
Here is a pic of the twin barreled version:
Yours
tom! ;)
Harpy
Post by Harpy »
Good shot of the 40mm on what looks like one of 251 class.
ImageVedsx
phant3
Post by phant3 »
Hi all,
Im curious if anyone knows the colors of these ships? Deck, hull, superstructure.
I have the Rainbow No 28 I'm about to start and am hoping for some guidance towards paint.
Clair
Hulls and treaded metal decks are grey. From what I can see of the kit ( http://www.rainbowmodel.com/proshow.asp?proid=211 ), the decking is all treaded, which means no linoleum coverings.
phant3
Post by phant3 »
Thank you Dan,
That's what I was thinking but I'm no specialist in IJN in the least.
Reference material on these boats seems very lacking when compared to other nations.
Clair
