1/350 Bismarck Revell + Pontos set
Mr. Church
Re: 1/350 Bismarck Revell + Pontos set
So much detail, love it. Always liked the look of the red main gun turret roofs.
SG1
- Edoardo81
Hi guys, here the last update before summer holidays.
Again, total check of dry fitting if everithing goes well
I changed the default detail of revell with the veterans models.
I must say that the differences are outstanding!!!
Happy summer holidays!!
- Edoardo81
Hi guys here, I'm back to continue this work.
The superstructure has been glued, because I had to do it for the next level (upper) of it.
This is the upper level. It's very tied with all the previous parts of the superstructure and this forced my to proceed to glue it. Hope I don't regret it forthe painting.
In the meanwhile I've begun with the funnel.
Only one side of the longest barrels are glued.
Tomorrow will the glued the opposite side.
I've also opened all the pipes. I think it gives a better aspect and realism
see you next time!
see you next time!
SG1
- Edoardo81
Hi guys, I'm back.
I used this week for mounting machine guns/ Anti-aircraft guns
I have a doubt about the colour
Black or German grey?
Here is the picture of how it should be
And here the 2 types
Tamiya black XF-1
Tamiya German Grey XF-63
Here both together
From reality I can say with black many details disappear, but it seems to me closer to the picture.
So any suggestion?
Tamiya black XF-1
Here both together
So any suggestion?
StevenVD
It could also be gunmetal with these, anyway it doesn't look black on pictures.
- Edoardo81
Here the test with tamiya gun metal!
I don't know. It's a strange colour. It's depends if you take with the brush the metal part, or the darker one.
- Edoardo81
Little progresses on the lower part of the piece.
It was been difficult to match all little pieces, handrails ecc. but seems quite good.
Now let's start on the upper part
In the meanwhile the overall superstructure proceed with the details
- Yuth
a gorgeous work
Someday I'll have to try this baltic scheme
In 1:700 we trust
There are three kinds of people: the living, the dead and those who go to sea.
- Edoardo81
Hi guys, here an update.
The main foward superstructure is closeto the end. Manydetails still missing like instruments (compass, binoculars, searchlight), weapons, handrails and radars ecc. but I think during this week I can come close completing them.
there's only big problem to solve:
That space beetween the upper part and the lower one.
The 2 parts are not glued (dry placed only to see how they fit) and I have some doubts on about what to use to close the gap.
I woulddiscardthe cyanoacrylic because I'm sure it will not appear a clear work.
My idea is a little piece of plasticard.
Any other ideas?
Thanks to all
Any other ideas?
Thanks to all
- Edoardo81
In the meantime I moved to the hangar behind the foward superstructure.
One is completed. Now I'm moving to the next one
- Edoardo81
Everything painted. Now I'll proceed with the details like painting the footbrides or the wood supports of the ships
StevenVD
Try to remove the cause of that seam first. It might require some woodcutting or plastic milling.Edoardo81 wrote:
Any other ideas?
Thanks to all
- Edoardo81
Thanks Steven. It should be the wood. I will try with the cutter to remove a little part.
Hope not to damage the structure (usually if I work over and over on a piece, I damage it
- Edoardo81
Hi all, foward superstructure almost completed, only few things miss before placing it on the hull (radars, 2 AA nearby the searchlight and 2 handrails).
I have followed Steven's suggestion about the wood and the gap really vanished. A bit of glue and paint and it almost disappears.
Maybe a foward photo without the light that increases the shadow can show it better.
Now a doubt: I'm beginning to assemble the funnel but for all those barrels I don't know what to do:
-If I glue them before painting, it would certainly do a better job, but I would have some problems with the tape when I have to do the camouflage which won't stick well alongthe profiles. Then they would come off with the pressure to make the tape adhere well. As happened to me with the tall turret of the superstructure.
- If I paint before, doing also the camouflage and then I glue the PE and then paint them with the brush, they shouldn't come off. The problem (I'm not sure, but it is my doubt) in this case would be the thickness created with the 3 layers of paint (primer, base grey, and camouflage). Knowing how these PEs are very precise, I'm afraid that they won't fit with consequent risks of bending or broking them.
What's the best suggestion from who has better experience?
Thanks a lot
Thanks a lot
Themongoose
Some excellent PE skills you have!
Possibly too late � my vote for th the AA is German grey if you�re painting right out of the bottle and not trying to mix anything.
- Edoardo81
Thanks themongoose, you're too generous!!
I have chosen the tamiya gunmetal after a long mixture.
- Edoardo81
Added wood on the boat supports as indicated by the fonts
StevenVD
About the funnel I think you shouldn't worry and glue everything first. If the tape is pulling something loose that can always be corrected later. You can sometimes provide location holes in the funnel if some of the pins have an attachment to the PE fret.
One thing I was still missing from your last image is that black boot line.
