Calling all Royal Navy Nuclear-powered submarine fans
SS, and SSN.
Woodstock74
Re: Calling all British Nuclear Submarine Fans
Post by Woodstock74 »
Any idea of the diameter of the HMS Resolution's screw? I see it exists and is on display at the Royal Navy's Submarine museum.
Woodstock74
Found the screw on Google earth, . Measured it out to 4.2-4.3 meters.
Annotation 2020-06-05 114447.jpg (23.89 KiB) Viewed 5649 times
Vepr157
Post by Vepr157 »
What's the lat-lon of the Resolution propeller?
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/350 George Washington
1/72 Type VIIC
Woodstock74
Vepr157 wrote:What's the lat-lon of the Resolution propeller?
Let me see if I can dig it up, it's on the grounds of the Royal Navy Submarine Museum Gosport, on the periphery, just off the side of a road leading in. If you start at the museum it's ultimately easy to find, but let me see if I can get those specifics.
Woodstock74
This should take you there:
https://goo.gl/maps/qmdq8t7LqtK5GBdY9
Vepr157
Post by Vepr157 »
Thanks! You can get a good view of the side on Streetview. I wonder where the Trafalgar propeller is.
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/72 Type VIIC
Woodstock74
Vepr157 wrote:Thanks! You can get a good view of the side on Streetview. I wonder where the Trafalgar propeller is.
Yes, and there are quite a few images taken from similar angles online. But, given that perspective, it's still difficult to determine blade shape. The satellite images helps for sure though.
Woodstock74
Oh, and yes, if anyone knows of ANY images of either the HMS Trafalgar's screw, or HMS Swiftsure, point me in the direction. I've seen nothing for either, and I presume part of the problem is one-off nature of each of those lead boats, and so the chance of sneaking a shot would be limited drastically.
bismarck builder
Post by bismarck builder »
guys
does anyone know if hms dreadnought is still in plymouth
gary r
FrancisMcN
Post by FrancisMcN »
Are you thinking of Courageous?
https://devonportnhc.wordpress.com/warshiptours/
bismarck builder
hi FrancisMcN
it could be it was over 15 years ago that i drove past it. I was delivering a pump to a Dutch frigate i asked if i could use to head and they invited me to stay for lunch, result. The boat was moored astern of the frigate.
cheers
gary r
FrancisMcN
I understand there are 13 decommissioned submarines stored afloat at Devonport dockyard but I'm not sure if sure that Dreadnought is one of them - if not then I assume she is one of the similar store at Rosyth. Either way, they are not in a state that would allow anyone to visit them even if Ministry of Defence allowed a visit. Courageous was made fit for visits and is occasionally open to visits as per the link I put in my previous post.
Vepr157
Post by Vepr157 »
The Dreadnought is in the Rosyth dockyard.
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/72 Type VIIC
Woodstock74
Some progress...just waiting on the Mikro Mir kit to arrive.
Annotation 2020-06-19 084805-2.jpg (21.01 KiB) Viewed 5461 times
Woodstock74
Just came across this image touting it as the HMS Trafalgar's screw. My gut reaction was that it was a mislabeled shot of the HMS Resolution's, but with the screw boss trailing edge vortex dissipator removed. But on closer inspection, the trailing edge of the blades end right at the split where the missing screw boss trailing edge hub would bolt on, and on the HMS Resolution's there is some distance/offset between the blade trailing edge and the break for the bolt-on vortex dissipator.
Anyone have any idea where this might be? Heading back to Google Earth and searching the grounds of the Royal Navy Submarine Museum in Gosport UK...
Woodstock74
Found it!
Woodstock74
Woodstock74
More Trafalgar:
Vepr157
Post by Vepr157 »
Nice work!
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/72 Type VIIC
EJFoeth
Post by EJFoeth »
Woodstock74 wrote:screw boss trailing edge vortex
Hub vortex :smallsmile:
Return to “Submarines”
