Calling all Arleigh Burke-class (DDG-51) fans
HvyCgn9
Re: Calling all Arleigh Burke Class Fans!
I read somewhere that some ships with 1 CIWS are getting a second during refits. If I was doing a later FltIIa I would go for BAINBRIDGE the pirate killer....plus if you are thinking of redoing aft SS adding the RMS hanger would not be that hard.
Cheers Bruce
Cheers Bruce
building:
1/72 RC USS LONG BEACH CGN9
1/72 RC USS CALIFORNIA CGN36
1/72 RC USS SAIPAN LHA2
1/72 RC USS SHARK SSN591
1/72 RC USS SEAWOLF SSN21
1/72 RC USS ALBANY CG10
- Perth_shipyard
Ah, now there's a thought! Captain Phillips one. There was some talk on here about some of those ships having the RMS hangar sealed up?? But a cool idea, need to look at getting plans and stuff for the RMS then.
AT
1/72 Arleigh Burke flight iia
viewtopic.php?f=13&t=154767
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 HMAS Perth 1942
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
HvyCgn9
The plans Rob has show the variations between flat funnel top and early funnels and the RMS hanger (which I would convert to a SpecOps hanger if I was in charge of USN...). Also has a really good mast drawing too...
I have a copy of Rob's plans plus the APS plans and there is some variation in the Angles of the hanger roof deck between the two.
Cheers Bruce
Cheers Bruce
building:
- Perth_shipyard
That sounds about right! Haha nothing ever seems to be the same with plans, but I'm going to assume ribs are more accurate than the one from APS. It seems strange to me that the guy that started my AB missed such a big thing, seems to be quite noticeable to me. Unless he just wanted to take a shortcut. The rest seems to be quite good but again will wait to compare to the plans. The shaft a frames also look like there too far aft - very close to the rudders. Though from looking at photos of the real ships the ones from APS are far too large.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
HvyCgn9
Most people won't notice that the rudders are longer than they should be, All the Oz built Burkes I have seen running have all handled superbly so I think the longer rudder is a good thing. I had my CGN36 rudders made by GT Sitek and they are slightly longer than they should be and I really enjoy how she steers...much better at slow speeds too!! You have to remember the original APS plans and running set was made from info available at the time they where drawn up almost 16 years ago.
You will find when buying half started stuff that people all do things differently!! plus as long as she looks right above the waterline then the rest don't matter!!
Cheers Bruce
Cheers Bruce
building:
- Perth_shipyard
No absolutely agree haha it does look from the closer distance of the props and rudders the steering should actually handle quite well. Am tempted to see if I can replicate the new designed rudders that some of the latest AB's have with the curve on the aft end of the rudders to see what difference it would make. Though a lot of work for what might not make much of a difference scale wise. It's a shame there's no absolute design released on the flight iii's seen a few 3D mock ups which seem easy to do but of course like the AWD's until ones actually built...
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
HvyCgn9
I can save you the trouble mate Russ French can make em for you.....Scott got some for his USS Spruance DDG111 just email him about a price, he also does the mini typhoons and some other bits for the main mast.Perth_shipyard wrote: Am tempted to see if I can replicate the new designed rudders that some of the latest AB's have with the curve on the aft end of the rudders to see what difference it would make. Though a lot of work for what might not make much of a difference scale wise.
Also stacks of good Photo etch now available for DDG51s from Scale warship in UK.
Bruce
building:
- Perth_shipyard
Ah brilliant! Yeah I used Russ's fittings for the AWD and they are great to work with.
I've actually ordered most of the PE from scale warship for the AB's. The flight deck tracks and tie downs plus the Aegis radar sheet. They've also got the name plates in PE but only a few ready. Once I've decided finally on the ship I'll send them an email about when they could produce a new sheet. Their website isn't the easiest to use anymore, used to be much easier to navigate and they had in the past depth marks in PE also. They would be great with the name plates to give the proper raised look.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
FRAMSailor
Over on the Main Forum "MikeyBugs" is looking at maybe 3D printing the USC-38 & WSC-6 domes to update the Arleigh Burke kits. They look good to me, but perhaps some of the DDG-51 class experts might want to check them out for accuracy.
MikeyBugs
If anyone could consult with examining the accuracy of the models, it would help.
Mike, MikeyBugs
- task force 58
Which 1/350 Arleigh Burke from Trumpeter would be best for building USS Decatur DDG-73? Thanks
Planned projects
1/700 USS Macon CA-132
1/350 USS Wasp CV-18
1/350 USS Alabama BB-60
Mil.K
Only Hopper.
Cole has a pipe under the main bridge and does not match the original.For the construction of Cole and others thus choose Hopper
So for the construction of Decatur select only Hopper.
Hello,I'm Jakub posted You from Poland, I find your topic and I'm realy happy, loved Arlegih class, and first question which model in 700 scale is good/ brilliant or awesome ?? :) Pit Road, Dragon, Revell or HB. In Poland I found in press Modelarstwo Okretowe nr 57, 58 and special nr 19 very good plans (in 350 scale), photos and 3d drawing ,in Modelarz nr 2/2002 We have very good plans For 5in Mark 45 mode 4 in 1:50 scale.
The Hobby Boss kits are the newest ones and the most accurate, as well as detailed. There are issues with some of the Dragon versions, mainly the wrong hangar length - it should have been discussed earlier in this thread.
MikeyBugs
I think the radar sets I made, the USC-38 and WSC-65, are way over scale. I just got a 1/700 set in and they dwarf the bridge of a 1/700 Dragon Arleigh Burke kit I have. Does anyone know the height from base to top of these radar housings?
Mike, MikeyBugs
maxim
Have all four Arleigh Burke (Donald Cook, Ross, Porter, and Carney) of the 6th fleet now Sea Ram launchers instead of the after Phalanx?
USS Donald Cook:
http://www.c6f.navy.mil/news/%E2%80%9Cs ... n%E2%80%9D
The decoy launchers midships I had also not yet seen on a Arleigh Burke.
USS Donald Cook:
- bilou06
I have visited Porter last year and Carney in january...they have SeaRam launcher !
Gilles
maxim
Interesting. Only one rear the after funnel or also one in front of the bridge?
maxim
USS Russell (DDG-59), USS Paul Hamilton (DDG-60), USS Milius (DDG-69), USS Decatur (DDG-73), USS Higgins (DDG-76), USS Howard (DDG-83), USS Dewey (DDG-105), USS Stockdale (DDG-106) and USS Spruance (DDG-111) in January 2017 in San Diego:
Arleigh Burke class destroyers in San Diego
(click on "Link zur Bildergalerie" to see the photos)
- navydavesof
They all should be Phalanx Block 1B forward, 11-cell SeaRAM aft.maxim wrote:Interesting. Only one rear the after funnel or also one in front of the bridge?
