Calling all IJN Kuma-class (球磨), Nagara-class (長良) & Sendai-class (川内) fans
Mike W
Re: Calling all IJN 5500ton (Kuma-Nagara-Sendai) class CL fa
Post by Mike W »
Dan K wrote:The L&W book will probably give a more authoritative answer, but in the meantime:
From Sendai's TROM
21 January 1943:
Two 25 mm guns removed from oiler SANYO MARU are transferred to SENDAI.
5 May 1943:
At Sasebo for repairs and refit. A Type 21 radar is installed. The No. five 5.5-inch gun mount is removed. Two triple 25-mm AA gun mounts are installed.
From Nagara's TROM:
26 January 1944:
Arrives at Maizuru. Refit. NAGARA's No. 7 140-mm gun mount is removed and replaced by a 127-mm unshielded HA gun mount. The fore and aft twin torpedo tubes are removed and replaced by two quadruple tube mounts aft. The catapult is removed and replaced by two triple-mount Type 96 25-mm AA gun mounts bringing NAGARA's total 25-mm AA suite to 22 barrels (2x3, 6x2, 4x1). DC rails are installed in the stern and a Type 93 hydrophone set is fitted in the bow.
2 July 1944:
Arrives at Yokosuka. Begins refit. Ten single mount Type 96 25-mm AA guns are installed, bringing NAGARA's 25-mm suite to 32 barrels (2x3, 6x2, 14x1). A Type 22 surface-search radar is fitted.
On the Tamiya model of Kinu, the well deck with the forward torpedo tubes and the aft deck around the aft gun mounts, mast and catapult, have no depiction of Linoleum covered decks. Is this wrong or right? It seems odd to me but Tamiya might know something I don't
thanks
Mike
The aft deck was certainly covered by linoleum. The torpedo well most likely.
Mike W
Post by Mike W »
Dan K wrote:The aft deck was certainly covered by linoleum. The torpedo well most likely.
thanks for that, I'll get it repainted then.
thanks
Mike
Posts concerning Tenryu, Katori, Yubari and Oyodo class ships have have been split out to a new topic, here: viewtopic.php?f=48&t=306746
5500t kits and galleries added up front.
Mykman
Post by Mykman »
Hi All ! :wave_1: :newbie:
This is my first post in this great forum ! :)
I was thinking to build IJN Abukuma for a small diorama in 1:700 with akagi at the start of Pearl Harbor.
Can I use tamiya Abukuma with IJN Light Cruiser Nagara 1944 Detail-up set for Tamiya 31322 kit (Rainbow 7081)? I have not found a dedicated PE set for this kit.
As i saw only the configuration around the funnels are different. Correct me if i wrong ! :)
Thanks !
Karoly
maxim
Post by maxim »
The main difference is the armament, the catapult and the masts - in 1941 Abukuma had:
7 x 140 mm L/50 Type 3 (single)
4 x 25 mm L/60 Type 96 (two twins)
4 x 13 mm Type 93 (one quad)
8 x 610 mm Type 8 torpedo tubes (two quad)
1 Kawanishi E7K2 Type 94 Alf aircraft
I had used #727 IJN LIGHT CRUISER by Tom's Modelworks.
I assume that many parts for the Nagara set are not suitable, whereas several are missing in the Rainbow set (e.g. the catapult?).
It also depends on how extensive the detailing you intend to make.
Mykman
Post by Mykman »
Thanks for the quick reply guys! :thumbs_up_1:
I think these 2 update sets would be more than enough for this project, they will replace half of the kit parts.
But firtst I need to start Akagi as soon the kit arrives form japan.
Quincy
Post by Quincy »
I see that Fujimi has released a kit of the 1/700 1942 Kuma. Does anyone have any idea if they will do others like: Kinu, Kiso, Yura??? Not that I don't have other kits to build! :heh:
Bob Pink :wave_1:
No clue. Their path on new releases is unclear. They seem more focused on endless variants of their current molds.
Quincy
Post by Quincy »
Thanks Dan! :thumbs_up_1:
Bob Pink :wave_1:
Mike W
Post by Mike W »
I've been eyeing up the Fujimi 1/700 kits of Kuma and Tama (new ones) on both HLJ and Hobby Search. Has anyone got any experience of them in the flesh? They look nice in pics but what about up close? Any accuracy issues? If you model them waterline is the split of the lower and upper hulls in the right place? Is it better to get the Tamiya kit and the expensive and extensive Five Star etch set or are the new Fujimi kits good enough to just enhance with things like etch catapults + railings etc? You can't get the kits in the UK, so I'm just after more info before I decide whether or not to order them
thanks
Mike
I don't have the kits, but I can make some observations.
Tama & Kuma are NEXT kits, so it's more like comparing apples to oranges when comparing to the Tamiya kit. I don't have either of these Fujimi kits, but based on my experience with some of their DD NEXT kits, I'd say that while the hulls and major superstructures are extremely nice and accurate, smaller parts suffer because of the nature of the kit. The upper and lower hulls do separate at the waterline, but you don't have any hint of a red waterline or a flat surfaced bottom; the kit will sit on the hull sides. (I tend to cut some styrene sheet for a bottom to glue on, preferably hidden.) It's not a given that the hull will lie absolutely flat. I've seen some variation between hulls. But that would be true of a standard kit hull as well.
FWIW.
Mike W
Post by Mike W »
Dan K wrote:I don't have the kits, but I can make some observations.
FWIW.
thanks Dan
Something to think about!
Roy
1/350 Flyhawk Nagara set
Post by Roy »
Forgive me if this is something which is answered elsewhere, but I just got the Flyhawk P.E. and brass set for the Aoshima Nagara kit (beautiful set by the way) and I'm wondering about the included instructions; they seem pretty truncated. I have two sheets which contain pages 1-4 but there's an awful lot not dealt with on these sheets including the numbered and obviously specific side rails - nada. If anyone else is familiar with the set am I missing sheets?
Thanks, Roy
Re: 1/350 Flyhawk Nagara set
You might try contacting Angeliccypher (Gabriel) via PM
He used that set for his Nagara build: viewtopic.php?f=59&t=155871&hilit=1%2F350+Nagara
Roy
Post by Roy »
Thanks Dan. I'm sorry this ended up in it's own sub-forum, I intended it to be under the IJN 5500 tonner sub-heading. Perhaps admin would be willing to move it? Apologies again- rank newbie!
Roy
Reason: Merged!
Post by Guest »
Roy wrote:Thanks Dan. I'm sorry this ended up in it's own sub-forum, I intended it to be under the IJN 5500 tonner sub-heading. Perhaps admin would be willing to move it? Apologies again- rank newbie!
Roy
Thanks Timmy!
MatthewB
Post by MatthewB »
OMG! OMG!
I got a copy of LaCroix� & Wells� Japanese Cruisers of the Pacific War for less than a Kidney.
It will arrive in about two weeks, but it came with a PDF! I don�t know if the PDF is �Authorized� or not.
But the images in it are amazing.
The resolution allows me to blow the images up much larger than those I have seen posted to this forum from the book.
In reading the Forward/Introduction, I learned that it was one of the first publications to use Digital Image Processing to recover more data from existing negatives.
That caused me to wonder if anyone has subjected the same negatives to even more Powerful Digital Processing Tools of either Photoshop (which is only a Billion Times more Powerful than ANY 1980s Digital Image Processing Tools � That includes those of any Intelligence Agency on Earth at the time) or applications that make Photoshop look like a tricycle in comparison, such as Mathematica, MATLab, or similar computational tools that don�t have the Graphic Interface of Photoshop, but whose tools are many orders of magnitude beyond Photoshop.
And the use of Mathematica on ANY kind of larger Mainframe Computer provides even more power (Mathematica comes with built-in tools that rival those of Intelligence Professionals or Governments, but require more than a Desktop to utilize in a time-frame that would make their use worthwhile. Waiting months for a single Render Pass is not something most would care to do).
BUT�.
To get to the actual point here.
In LaCroix� & Wells� IJN Cruiser Book, I noticed that on Page 192 is an image of the aft Deck Alterations of the Isuzu, Kinu, and Nagara (and possibly Yura), where it shows that not only was the Boat Deck Extension over the after Superstructure extended to Starboard forward of the #7 Gun, but that to Port the area around the #6 gun was extended rearward, tapering toward the Center, rather than the Circular shape of the deck previously.
The 1/700 Models show this to be simply a larger Semi-Circle for the Tamiya 1941 Nagara (which is released for the Anime Arpeggio of Blue Steel and for the 1943/44 Nagara, where the forward Torpedo Tubes were landed, the aft replaced with Quad Launchers, and a Type 21 Radar attached to the prior Location of the 4m Rangefinder and Director.
BUT� The Rainbow Models Photo-Etch kit for the 1943/44 Nagara has this shape of Deck provided.
I am trying to kitbash a Photo-Etch set for a 1942 Nagara, where the PE Deck has the appropriate brass tie-down strips for the Synthetic deck material used by the IJN, which the 1943/44 set from Rainbow had, save for the #7 gun position, where the earlier 14cm Gun was replaced with a Type 89 Twin 12.5cm DP Gun Mount. But the Rainbow set for the 1942 Tama has the correct #7 Gun Position, and the appropriate AA Gun Outfit for the Midship Deck Mounted AA guns (whether just the two Twin Type 93 P/S of the first Funnel, or the suggested second pair P/S of the Third Funnel, which can be used from the Nagara PE set), including the appropriate Midships Ventilation Hoods, Railings, and such, with the forward Torpedo Well-Decking, and the bridge over it, with the correct ladders and that cage thing always shown on it (I have yet to get to where LaCroix & Wells describe what that cage is, or why it totally blocks that bridge).
The only thing that really bugs me about the PE for the Bridge of the Nagara is that the railings CLEARLY show to be going OUTSIDE of the rear legs of the forward Tripod Mast, and NOT INSIDE as the PE Kits all show (The kits also do not show the chamfered corners of the Upper Aft Deck of the Compass Bridge Level in the proper dimensions, nor the Radio House on the Bridge Level previously occupied by the Hangar).
I had previously made a styrene replacement bridge that I intended to use, rather than the one provided by Tamiya or Fujimi (whose older kit is atrocious� I wonder why it hasn�t yet been re-made in 1/700 with the appropriate outfit for 1942, when it led one of the DesRons in the Solomons?), but given the time elapsed since I lost the use of my left arm for four+ years (now finally recovering) I cannot recall where I left it, and I�d like to finish the damned thing.
MB
OMG LOOK! A signature
Working on:
1/700 (All Fall 1942):
HIJMS Nagara
HIJMS Aoba & Kinugasa
USS San Francisco
USS Helena
USS St. Louis
USS Laffey & Farenholt
HIJMS Sub-Chasers No. 4 - 7
HIJMS Sub-Chasers No. 13 - 16
Return to “Cruisers”
