1/144 Kiev by Dave Wooley
JIM BAUMANN
Re: 1/96 Kiev by Dave Wooley
Post by JIM BAUMANN »
Sharp sharp!
I like the davit methodology--and the removable boat bay will ease the pain enormously!
Bravo--looking forward to further progress!
JIM B :thumbs_up_1: :wave_1:
GTDEATH13
Post by GTDEATH13 »
Was the removable bay a decision made during the progress of the build or was it a wise preparation when the build of the hull started?
Very interesting method and very effective... :thumbs_up_1: :thumbs_up_1:
NIKOS (NICK)
Post by Dave Wooley »
GTDEATH13 wrote:Was the removable bay a decision made during the progress of the build or was it a wise preparation when the build of the hull started?
Hi Nick Yes I would like to think it was planned , the rational was there but the method came much later. Thanks for asking. and thank you Jim for your kind comments .
Dave Wooley :thumbs_up_1:
The next stage is to scratch build 2 of the 4 motor boats carried by Kiev.
The design of these was slightly changed towards the end of her career
and can be seen in the back ground photo.
The materials of choice for the hull is Gelutong timber.. This is a pattern
makers timber and can be cut and sanded into any hull shape. 1mm styrene
was used for the deck and cab. The model is in its basic form. Fittings
such as , rudders , props etc will have to wait until the boats are fitted
into each of their davits. This will be shown as we progress.
The timber hull is prepared .
Each of the sides of the cab and windows are cut to size and the deck is
laid using 1mm styrene bonded to the timber hull using an adhesive under
the name of R/C modellers glue .
All the parts of the cab are laid out ready to be assembled
The cab sides temporarily in place.
The roof on the cab is fitted . Allowances are made for the curve of the roof.
Sections of styrene are used as spaces to support the after cab roof.
It will be noticed that the underside of the cab is open this is to allow for
glazing once the boat is painted.
The first stage of scratch building up the motor boat is almost complete.
All that remains is to fit a number of rails to each cab roof.
Next time scratch building the liberty boat.
J. Soca
Post by J. Soca »
Stunning work Dave :thumbs_up_1: :thumbs_up_1: i don't know how but you make it all look so easy and simple when is really not.
Jose
JIM BAUMANN
very neat Dave!
The styrene sheet joins; are they flush( melted together with mekpak/styrene glue-or do they need a primer filler?
Certainly has captured the feel of the boat!
JIM Baumann
Hi Jim The cab is welded with Humbrol liquid Poly and some filling in work will need to be done, then the rest of the fittings to the boat can be added.
GTDEATH13
Post by GTDEATH13 »
Dave Wooley wrote:Next time scratch building the liberty boat.
What??? :Tirade: The liberty boat?? What for? No liberty for your Kiev, :Tirade: We want to see more and soon... Work work work...
Excellent work :thumbs_up_1: :thumbs_up_1: :wave_1:
NIKOS (NICK)
Scratch building the Liberty boat . This followed a similar pattern to the
motor boat . Except the hull once carved and sanded to shape is separated
into two halves.. The purpose for this is to allow for the inside to be removed
easily . A centre profile in used to join the two halves together.
The two halves are joined thus.
The deck and the interior are cut to size.
The interior deck is laid along with the raised sides . These are cut from
0.50mm styrene strip.
Each of the three sides and windows of the cab are cut to size.
The cab is quite basic . First the sides are assembled with the roof ready to
be fitted.
Once again the cab is removable and the underside made accessible for easy glazing .
The motor boat and Liberty boat are ready for a trial run. Not I hasten to
add on water, much to small for that but into their respective positions
in the boat bay.
Now the rational for building up a removable boat bay comes into its own.
Each boat is temporarily placed on the davits so that the head of the davit
and the boat fall { when fitted will be in the right spot. This would be
excruciatingly difficult if not impossible in -situ . First the motor boat.
Next the liberty boat .
All the davits line up
The proof of the pudding is how the boats fit onto the davits with the boat
bay in place . Well they do!
Still lots of work to do but the method works .
Dave Wooley Next time the heavy lift cranes.
ingura
Post by ingura »
Hi Peter thanks for your kind comments. The real problem that I didn't mention and you touched on was the use of frames. These boats were carved using the photo as a guide. Alas there are no drawings of these boats that I know of that show either body plan or lines. I wish there were. :thumbs_up_1:
JIM BAUMANN
EXCELLENT methodolgy- I shall be employing soem of these techniques in my much smaller builds!
JIM B
The title of the thread suggests this build is 1/96- I thought it was smaller- 1/144...?
was I dreaming?
JB :wave_1: :wave_1:
Avery not logged in
Post by Avery not logged in »
Fantastic work Dave, really amazing. Thank you for taking the time to show us how it's all done. As was said, I am in awe of your carving skills. I'm somewhat of a woodworker myself, but I could never, ever come close to making something as exquisite as your hulls. And it is easy to see the same amount of care going into the entire build. Well done indeed!
mitchell300
Post by mitchell300 »
OOOOOOOOOOOOOOOMMMMMMMMMMM FREAKING HELL!
This is way to cool ;)
If we had a competizion from who has the best build.
I whas voting for u ;)
get me a new update plz :D
Mitch ;)
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
You might well ask , �What's he up to now� �What's this lot of material going
to be� .What fitting is this?
Here is a selection of the tools for the job.But what job?
This is the job in question One of two large heavy lift cranes. This particular
one sited forward is used for a variety of tasks and is shunted along rails
between the SS-N-12 launch tubes from port to starboard. Quite a complex
piece to make but here goes. .
ozpirate
Post by ozpirate »
Last image is reversed
Mick
ozpirate wrote:Last image is reversed
Mick
Yes you are quite right .
Fine details within the drawing are a lot the be desired . But the drawing
remains a guide only and not taken in any way as definitive .
The alternative like so much on this project was to sketch up some sizes
to 1:144 scale that correspond to the photos.
The basic components are lifted from the sketch and the parts shaped as per
the photos Here is the main sections of the jib and cross members cut to size,
with the pulley arm purchase partly made. Materials used for the jib are
2mm styrene. In preparation is the base and the slewing drum. Next assembling
the jib and pulley arm to the base so the two sections will function important
when rigging.
Dave Wooley .
GTDEATH13
Post by GTDEATH13 »
What I cannot comprehend from the drawing is which part of the crane is raised... Are the two arms you have built based on an axis and the Y shaped the counter weight? And if so, why are they thinner on the part were the axis of movement is based? Very curious to seeing more progress...
P.S. Someone should tell those guys in your previous photo to change sides or they will get a really bad sunburn... (Sorry but I could not help saying it) :wave_1:
NIKOS (NICK)
GTDEATH13 wrote:What I cannot comprehend from the drawing is which part of the crane is raised... Are the two arms you have built based on an axis and the Y shaped the counter weight? And if so, why are they thinner on the part were the axis of movement is based? Very curious to seeing more progress...
All will be revealed in due course. :thumbs_up_1:
