1/144 Kiev by Dave Wooley
ingura
Re: 1/96 Kiev by Dave Wooley
Post by ingura »
Post by Dave Wooley »
ingura wrote:Hi Dave, the crane on KIEV is a real task - the more you have to start with a sketch-like drawing and some photos. This is where experience comes into the game. A lot to learn for me and I'm very glad you share this with all of us.
:thumbs_up_1:
Hi Peter we all learn from each other, that�s one of the parts of our hobby that makes it so appealing . I noted that you were using an original drawing. That is what is lacking with Kiev. Although the drawing if you could call it that is of Russian origin, it lacks detail. I'm no draughtsman or have any skill what so ever in CAD, but I can draw sketches which can be translated with photos into the fittings, it works for me and it can work for others. I�m following your build closely as you are using methods and techniques that are of great interest to me keep the posts flowing and thanks for posting :thumbs_up_1: :thumbs_up_1: :wave_1: .
Here the base is built up using 4mmx 0.50mm raised styrene strip around
the outer edge .The reason for this will become clearer as we progress.
The next stage is to unite both jib and pulley arm to the base .
With the desired location on an axis the next stage is to locate the tube and
pin that will allow both jib and pulley arm to move freely .
Using the pin vice holes are made through the jib and pulley arm to correspond
to each tube
Each pin is then inserted through the arms and in to the tube to enable
each side of the arm to be united on a common axis
This simple method enables the arms to move up or down , essential for
rigging.
The two arms, in place and free to move.
More to follow
Dave Wooley :thumbs_up_1:
ARH
Post by ARH »
Very nicely done Dave, its shaping up well. :thumbs_up_1: :thumbs_up_1: :heh:
Simple but effective.
Hi Ron thanks for your comments , always appreciated :thumbs_up_1: .
The next step is to make the purchase and hoist wire guides, which lift
and track the wires clear of the machinery . Basically these take the
form of two supports {styrene] linked by a roller [aluminium tube} with
an insert .45 wire which allows the rollers to turn.
These are fitted onto the top of the base .
All the fittings such as the barrel and shafts for hoisting , piping, various
cylinders, and pulley wheels are prepared ready to be assembled onto the
base and jib head .
ARH
Post by ARH »
Nice work again Dave, I see some of Gordons wheels on the bench, keep this up and you might get me building again. :heh: :heh:
Hi Ron It would be great to get you back in the build mode . I think the board needs more build projects like Duane and Moffitt . :yeah:
ingura
Post by ingura »
Lou
Post by Lou »
Third!
Great job on the build Dave, looking each day to see if there is a new update.
mitchell300
Post by mitchell300 »
Dave ur to cool :cool_1: :cool_2:
This is just amazing :D
Mitch ;)
New Ships Planned For Shipyard:
USS.Missouri 1.545 scale to new jersey desert combat
Ships in dock:
USS.Saratoga 1.535 scale Desert combat (currently on hold)
Ships in repair:
SMS Tirpitz 1/540 (adding new radars and fixing the main guns)
seaphoto
SeaPhoto
SeaPhoto
Post by seaphoto »
That is some might fine work there Dave, I have been working more on the website than my models lately, but now that I have caught up a bit I can get out to my own shop and work. The crane is an inspiration!
Kurt
Kurt Greiner
http://www.warshipmodelsunderway.com
Home of the Big Models
http://www.warshipphotos.com
SeaPhoto Maritime Photography
Hi Kurt good to to hear from you . Which ship are you working on?
Dave Wooley :thumbs_up_1: :thumbs_up_1:
mitchell300 wrote:Dave ur to cool :cool_1: :cool_2:
Mitch ;)
Hi Mitch Thanks for your kind comments more detail work to come. Then another crane but of a slightly different type. :thumbs_up_1:
Next the forward drum barrel is fitted .
The larger of a number of cylinders sited around the base. This is made
up from aluminium tube .
These cylinders are fitted into place .
The rear barrels are fitted.
All the barrel barrels are now in place.
More to follow .
:thumbs_up_1:
ozpirate
Post by ozpirate »
A few days ago I was talking with Brian In Wagga Wagga and he is now looking at making a fiberglass mould and hulls of his Kiev class at 1/72. What you thoughts on that. If I can afford one I hope to get one and make the Minck. That would make a nice view on the water both Kuznetsov and Minck. BTW next wednesday is fiberglass day for Kuznetsov. Its been waxed and release agent is on now. But going away for weekend. Have a few people comming over to help and will get plenty of pictures of the hull under construction.
Hi Mick Now a Minsk at 1:72 would be impressive. What surprises me is the number of differences that separate each of the Kiev's . I've been following your Kuznetsov build and I'm looking forward to seeing the GRP mould .
seaphoto
SeaPhoto
SeaPhoto
Post by seaphoto »
Hi Dave,
I am still working on Gneisenau in 1/100 scale. What time I have been able to spend on her in the last few months has been dedicated to making the turrets operational. I have been experimenting with some new ways to control the rotation - the theory is sound, but I have to work on the execution to make it smoother and more reliable.
Kurt
Kurt Greiner
The main jib is fitted with two sections of styrene along the centre.
Additionally two lengths of brass wire are seated along side these sections .
The reasons for this are unclear but they could provide greater strength
to the jib and are visible in the photos.
Attention now shifted to the making of the pulley wheels. The two outer
wheels are from PE supplied by Gordon Brooks . The inner part of the
pulley or sheave is formed using aluminium tube.
All the parts joined together.
The smaller lifting arm is fitted with a length of .45mm brass wire at the head
of the arm that will form the common spindle for the pulleys to reeve the
derricking purchase.
Pulleys are ready to be fitted . There is also a cylinder arrangement that will
be fitted to the front section of the base.
More to follow :thumbs_up_1: :wave_1:
JIM BAUMANN
Post by JIM BAUMANN »
EXCELLENT work Dave!
Beautifully sharp modelmaking!
A pleasure to see the parts takig shape
JIM B :thumbs_up_1: :thumbs_up_1:
