Calling all Baltimore-class (CA-68) fans
- DrPR
CA-72 CAD hull model
Here are two images of the CA-72 3D CAD hull. It is one of the second generation Baltimores with the rounded stern. This is still preliminary - notice the wrinkles in the surface. However, the pictures do show the characteristics of the hull surface.
This isn't a very accurate model. It was created from the station lines drawing on the blueprints, and there were some very large errors. The after lines were more than a foot narrower abeam than the forward lines, and none scaled correctly relative to length and height. Fortunately, in a CAD program there is a "Scale" function that allows you to correct such errors. I cannot imagine how they built these things without computers!
For really accurate models you need to work from the offsets tables (numerical definitions for points on the hull surface).
jssviii
Re: Calling all USS Baltimore (CA) class fans
Hello, I just stumbled onto this thread, and I'm hoping someone can help me. I'm building a boltimore class cruiser kit, and I would like to have the hangar open and maybe even an aircraft being raised/lowered, but I am stuck and I am hoping that maybe someone here could answer a couple of questions or point me to a source. Does anyone know how the kingfishers would be taken in/out of the hangar, The wingspan seems larger than the opening, would they fit diagonally, or maybe tilted so one wing came out first? or would they remove the wings and reinstall them on deck? (I've seen a photo of one in the hangar of the uss vincennes with the wings removed, although the caption reads that they are scrapping that one for parts so maybe thats why they are off in the photo.)
the second question is; Are their any plans of the hangar bay available, I've searched the web for quite awhile now (how I came upon this thread) and there aren't any photos showing the interrior, at least not enough to scratchbuild one from. I would even use photos of a cleveland class as a reference as there must have been some similarities, but there aren't any of those around either.
I really hope there is someone out there who can help,
thanks for your time - John
- Dick J
In answer to the aircraft question, a bit of history would help. Earlier cruisers carried the SOC and its variants. That aircraft had folding wings, as did all of the SO series. They were scouts first (the "S" in the designation). Their intended replacement was the SO3C Seamew. That aircraft suffered from a defective engine, and the other qualities of the aircraft did not lend themselves to an easy replacement. As a result of the failure of the SO3C, the SOC's were retained in the fleet, but their numbers were insufficient, so OS2U Kingfishers were pressed into service to fill the gap. These aircraft were designed for the BB's, so folding wings were not considered necessary. The net result was that cruisers that carried the Kingfishers couldn't use the hangar for what it was intended. The planes stayed on deck. The single-seat SC was the final floatplane solution for both cruisers and BB's, and it did have folding wings.
keithhufnagel
I have done a little reading and it seems the Curtis SO3C Seamew was designed with a 15'-3" folded wing width in order to fit new heavy/light cruiser hanger openings. Unfortunately the Seamew didn't work out . . . but the Vought O2SU Kingfisher, even though it had no folding wing capability (wingspan 35'-11" X length 33'-7"), was the most popular and prefered alternative. Most cruisers are listed as carrying four to six O2SU's and apparently those not stored on deck were kept in the hanger dis-assembled. I would guess they were not down to the nuts and bolts but probably 'wings removed' dis-assembled. The previous SOC-3 and later SC-1 both had folded wings. This seems to be a serious endorsement as to the rugged and effective capabilities of the Kingfisher.
keithhufnagel
Hello again, reading further it appears that the Kingfisher's original specifications were designed for coastal recon deployment and Battleship use. Folding wings were not required. Hope this helps!
- EN2Boger
Im currently working on the 1/700 trumpeter kit in 1943 fit, what measure was she painted as commissioned? From the photos I have found she appears to be in a neutral gray. The instructions are telling me to paint her hull in navy blue.
EDIT: I figured it out, she's measure 21
Donald Boger
USS John Paul Jones DDG 53 (Oct 2002-Dec 2005)
On the bench:
Dragon 1/350 USS Bunker Hill CG-52
In Line:
Tamiya 1/350 USS New Jersey BB62
On the bench:
In Line:
Russ2146
Film clip of USS Quincy that looks to be edited from different filmings. Nice shots of main battery fire control director..
Aside from the editing, this is labeled as 1946, but the enlisted still have their white caps dyed blue so I question that.
http://www.criticalpast.com/video/65675 ... enemy-ship
- gtbred
My Baltimore conversion USS Chicago CG-11. She will be part of my Tonkin Gulf fleet. found some photos on google that will help me out on the build.
- Kometa
On workbench:
Uss Montana - 1/350 - Very Fire
JMSDF Murasame 1/350 Trumpeter
F 86 Canarias
and more, more, more
My Galery:
Instagram: Tamboshipsmodels
F 86 Canarias
My Galery:
samssh
Help needed with Trumpeter 1943 USS Baltimore
Newbie to naval modeling here with a request. I've recently finished the Dragon USS San Diego and would like to build the Trumpeter USS Baltimore as the ship appeared during her first combat deployment. Reading earlier posts it appears some parts are needed from the 1944 version kit to bring the 43 up to this standard. Does anyone out there have a tweaks list identifying the parts/modifications needed?
- Haijun watcher
Hello all from Canada, (it's 4 AM here in Vancouver as of this posting and I can barely sleep)
I am another ship modeller who just found this wonderful forum. So much information and insights from past posts! Wow! I did a lot of modelling- mostly waterline 1/700 series ships from Tamiya, etc. - way back in my teenage years in the 1990s. Now in my 30s, I recently got back into ship models.
Still, I just have a question about the Baltimore class CAs as well, so I necroposted this older thread since it had the most posts for past reference.
Did all the Baltimore class ships have their bridge superstructures modified to have the square bridge top as stated below? Or were there any ships in the class that had their superstructures unmodified until at least 1945?
I am asking since I am considering buying the Trumpeter Baltimore 1943 kit, and was wondering if the kit can be used to depict other ships in the class, specifically the 2nd cruiser USS Chicago (CA-136). I assuming the Chicago had the square bridge top, but did she ever have the unmodified bridge that the class leader had at commissioning?
I would have bought the Baltimore 1944 kit, but it's not available at my local hobby store (strange they don't have this, but have the other one, eh?) and it takes a while for them to order such kits. I previously tried to order the Aoshima 1/700 Japanese battleship Yamashiro but the order didn't go through because their suppliers couldn't meet the order. That's why I was considering just buying the 1943 kit.
GaryJ in NC wrote:The Trumpeter 1943 BALTIMORE portrays the ship "as commissioned" on April 15, 1943. However, by June she had received additional quad 40mm mounts, including the fantail mount offset to port. She also received some bridge modifications which included a square front bridge top. By the time she deployed in September 1943, BALTIMORE looked more like the 1944 PITTSBURGH kit in the superstructure; therefore, I am using parts from an extra PITTSBURGH in order to represent BALTIMORE as she appeared in September 1943. As can be seen in the Trumpeter 1944 BALTIMORE kit, the July-October 1944 refit made further changes.
I have no idea why Trumpeter made the 1943 kit "as commissioned" instead of "first deployment." She was in that configuration for less than 60 days. The "first deployment" variation is much more interesting from a historical standpoint.
- Cliffy B
That's a quad 40mm on CA-68's stern David. Crane is blocking second set of barrels.
- Haijun watcher
David,DavidP wrote:CCGSailor, i'm in ontario north of toronto. baltimore has a flat transom http://www.navsource.org/archives/04/068/0406811.jpg compared to chicago's rounded transom http://www.navsource.org/archives/04/136/0413604.jpg . flat transom baltimores had 2 stern cranes with 2 20mm aa gun tubs later 1 twin 40mm aa tub http://www.navsource.org/archives/04/068/0406867.jpg wereas rounded transom baltimores had 1 stern crane & 2 twin 40mm aa tubs 1 on either side of the crane.
Thanks for your reply. It helped me in deciding not to buy Trumpeter's 1943 Baltimore kit. I would have preferred a kit of the class with a rounded transom.
- Bob Dedmon
I'm planning another collection (nearly finished with the Northamptons CA-26-31). This collection will be the 5 Chicago's I've already finished SSN-721 I have kits for CG-11 and CA-14, I plan to get another Corsair Armada Houston to do an early war/pre-war CA-29. I have the Trumpy Pittsburg to do CA-136 and have the book on the Los Angeles. My question is are there MAJOR differences between the LA and Chicago and how much work will be required to change Pittsburg to Chicago?
It's easier to beg foregiveness than it is to ask for permission.
- Haijun watcher
Dave,DavidP wrote:CCGSailor, i'm in ontario north of toronto. baltimore has a flat transom http://www.navsource.org/archives/04/068/0406811.jpg compared to chicago's rounded transom http://www.navsource.org/archives/04/136/0413604.jpg . flat transom baltimores had 2 stern cranes with 2 20mm aa gun tubs later 1 twin 40mm aa tub http://www.navsource.org/archives/04/068/0406867.jpg wereas rounded transom baltimores had 1 stern crane & 2 twin 40mm aa tubs 1 on either side of the crane.
If you don't mind my asking which source that has a comprehensive list that says which of the class members have rounded or flat transoms?
Or should I go through photos of each class member individually at navsource.org?
Thanks in advance.
- Cliffy B
If I remember correctly ONLY the first 4 members of the class had the twin crane/squared stern arrangement, IE CA-68-71. The remainder had the 1 crane/rounded stern arrangement. All ships retained their respective stern shapes regardless of the modernizations/conversions performed.
- Haijun watcher
Thank you CliffyB for the reply.Cliffy B wrote:If I remember correctly ONLY the first 4 members of the class had the twin crane/squared stern arrangement, IE CA-68-71. The remainder had the 1 crane/rounded stern arrangement. All ships retained their respective stern shapes regardless of the modernizations/conversions performed.
Looks like that rules out using Trumpeter kits as a stand-in for USS Chicago, CA-136, which I like since she was the only member of the class to have fired at an enemy ship. (This was during the time US Navy Adm. Shafroth's task force encountered a small Japanese C class escort ship during the bombardment of the Kamaishi Steelworks in July 1945)
...unless of course you are aware of another Baltimore class member that did shoot at an enemy vessel?
SeanF
You should start with the Trumpeter Pittsburg kit for a Chicago conversion - it has the rounded single-crane stern you need.CCGSailor wrote:Thank you CliffyB for the reply.Cliffy B wrote:If I remember correctly ONLY the first 4 members of the class had the twin crane/squared stern arrangement, IE CA-68-71. The remainder had the 1 crane/rounded stern arrangement. All ships retained their respective stern shapes regardless of the modernizations/conversions performed.
As for Los Angeles/Chicago comparisons, be aware that while Chicago got fully converted to CG-11, Los Angeles remained a gun cruiser to the end but got a few additional refits - so be careful what time period you're referencing in that book. Up to halfway through the Korean War should be pretty similar.
One additional variation I've noticed that will be a little tricky with the Trumpeter kits (all three) is that the planking stops well ahead of the catapults and hanger door (where the alternate stern is split from the main hull). From studying photos, it looks to me like several ships (particularly the early ones which Trumpeter is providing) were configured that way. However, some later ships look to have planking all the way back. Adding in the missing planking and seamlessly blend it in to the existing planking forward is something I haven't had the guts to tackle yet.
Say... might one of the wood deck makers consider a late-Baltimore class deck with planking all the way back?
- Sean F.
- Cliffy B
Trumpeter makes both stern variations in 1/700. For square sterns look for the Baltimore kits and for the rounded sterns look for the Pittsburgh kit.
Reviews for both are located here: http://www.modelwarships.com/reviews/sh ... peter.html
So to make Chicago, get the Pittsburgh kit. Not sure how different she is but you'll probably need to alter the AA guns, their directors, radars, various antennae, and other little sundry details depending on how accurate you want to depict her. Look through her NavSource page http://www.navsource.org/archives/04/136/04136.htm.
Best photo of her on there is this one: http://www.navsource.org/archives/04/136/0413601.jpg Its a nice high-res shot that should show you the majority of her layout and highlight the differences between her and the kit.
Two things I know they omit from the kits are the openings in the bow for the paravane chains and these two openings in the stern (only the rounded ships) had: http://www.navsource.org/archives/04/136/0413608.jpg
A nice shot of Bremerton highlighting the bow opening:
http://www.navsource.org/archives/04/130/0413016.jpg
Can anyone tell me what the stern opening are for and what's inside behind them. Are they just for mooring lines or do they serve some other purpose?
