Calling all Netherlands Hr.Ms. De Ruyter (1935) & Java-class fans
Perth_shipyard
Re: Calling All RNN DeRuyter and Java Class fans
Post by Perth_shipyard »
Thanks very EJ I'll give them a shot.
AT
1/72 Arleigh Burke flight iia
viewtopic.php?f=13&t=154767
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
1/72 HMAS Perth 1942
EJFoeth
Post by EJFoeth »
If you e-mail me at foeth at ontheslipway.com I'll send you this one slightly larger:
I found it in a book on Tromp I apparently own: De Tromp en haar Trompers.
Perth_shipyard
Thanks very much, I'll shoot you an email now.
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
KevinD
Post by KevinD »
Perth_shipyard wrote:I have both the Java and De Ruyter in 1/72 scale
If i may ask, where did you get those plans of Java and DR?
And what year do they portray, as built or......?
TIA.
Perth_shipyard
Hi Kevin, they're from here
http://profilemorskie.home.pl/72_Paper%20plans.htm
Both are as Battle of the java sea 1942
AT
1/72 Friesland
1/75 Wasa
1/53 STS Leeuwin II
KevinD
Post by KevinD »
Perth_shipyard wrote:Hi Kevin, they're from here
Thank you sir, I should have known. :-(
AussieBuilder
Post by AussieBuilder »
I've finally started my 1/600 De Ruyter build.
It's not really a scratch build, as I'm using a mixture of pieces from existing kits (for example a modified 1/600 Graf Spee hull, modified guns from 1/700 Prinz Eugen, some superstructure pieces from both kits, and other spare pieces I have etc), as well as specially created pieces (for example the deck, and most of the superstructure). I'll be using PE for some of the smaller guns, and modified guns for others.
Completed the first stage of the deck last night. I should be able to coerce the Graf Spee hull to fit the shape of the deck with some persistence - although it remains to be seen how successful it will be.
For detail of model, I'm relying on several builds and plans I have found, including these:
After so much backchat it is but right, that Soemba should join in this fight - Soemba Docket
AussieBuilder
The build is coming along well. It is my first time scratch building large parts of the ship, so I am learning as I go.
Most of the hull and superstructure has been modified or built, although still a few things to go.
AussieBuilder
Have made a bit of progress on the model this week, came down with a cold and the boss told me not to come into work.... :thumbs_up_1:
I've pretty much finished the primary bits of the superstructure, and finished off the hull. Done a rough paint of her colours in 1942 (I believe - according to Profile Morski and a photo I have found), and am fairly happy with how it's all coming along.
Next will be the detailing.
maxim
Post by maxim »
Looks good!
But why you painted the camouflage pattern to the lower hull?
AussieBuilder
maxim wrote:Looks good!
Because it's easier to paint over than to repaint ;) I know I over-killed below the waterline, but I didn't want to under-do it and have to come back to it.
AussieBuilder
For Maxim :wave_1:
Dan Banks
Re: Calling all RNN DeRuyter and Java class fans
Post by Dan Banks »
The new Pacific Crossroads Java is on its way, I noticed their paint instructions call out English greys. Why would the Dutch Navy use English paint in early 1942? They had their own paint, I assume. The tone of that paint has been variously described, but I've not seen anything that ever indicated they were using the three shades of 507 paints. That's like assuming USS Houston was in English colors.
KevinD
Post by KevinD »
Dan Banks wrote:The new Pacific Crossroads Java is on its way............ early 1942.
Do you know if it includes the aft Bofors 'shields' that, IIRC, was pointed out earlier in this thread?
Dan Banks
Post by Dan Banks »
Sheilds are included for Bofors. Nice kit, looks to include everything for "as sunk" version. I still wish they, and everyone else, would cast their full hull kits in one piece. I really don't like sanding and puttying. I know waterline guys don't like cutting and sanding, but since they are putting it in a water base, the lower hull edge can be rough, your sinking it in water. Much more demanding to get a good seamless waterline with joining upper and lower for full hull. Molded detail is very nice, and photo etch has relief details.
KevinD
Post by KevinD »
Dan Banks wrote:Sheilds are included for Bofors. Nice kit, looks to include everything for "as sunk" version.
Excellent, good to hear some model makers take some notice of indisputable 'advice'. :woo_hoo:
So goodo. Look forward to seeing a finished build then, as I just dive/d em (before salvaged that is), not build em. Leave that to you experts with nimble fingers!
Is there a pic of the model box somewhere?
Dan Banks
Post by Dan Banks »
Check Freetimes Hobby linc 1/350 new items, they have box top and contents pictures.
Here it is...
KevinD
Post by KevinD »
Thanks. Found the page myself. but couldn't see a good view of the Bofors anywhere.
KevinD
Post by KevinD »
AussieBuilder wrote:I've finally started my 1/600 De Ruyter build.
Sir, just noticed this post of yours. With all due respect, imagine you are finished build by now, so if for 1942 look, hopefully you included the shielded Bofors on De Ruyter, as also were there on her when sunk. :thumbs_up_1:
Return to “Cruisers”
