Calling all USS Enterprise CV-6 fans
- Gordon Bjorklund
- Michael Vorrasi
Steve Larsen wrote:Thanks gentlemen! Both posts are very helpful.
I had been leaning towards a late-war Enterprise with the extensive AA fit but
don't want to have to extensively modify the flight deck.
Is there a wartime period when Enterprise's catapults were parallel?
Trumpy's Hornet kit has catapults and they are parallel with the centerline.
You can see here that Big E's catapults aren't parallel. I fear that modifying
the kit's flight deck to achieve the proper catapult layout would spoil the
detail of the kit's deck.
Steve, Enterprise originally had two H-2 catapults which were rated for 7000 lb. aircraft. These were per the original design, and CV5 and CV8 had the same setup. The H-2's on CV6 were replaced with H-2-1 catapults rated for 11,000 lb aircraft during her 10/43 refit. These cats were a bit longer, and necessitated angling a bit so the holdback tracks could bracket either side of the forward elevator well. Also angling gave a bit more deck room for wider landing gear aircraft than the CV5/6 deck design allowed. CV8's forward flight deck was modified, in part, to help remedy this, as well as allow a safer rolling takeoff, which was far more normal than cat shots.
Mike
- John W.
CV-6 photo
Mike V. -
Did you notice what is apparently one of the port HF antenna supports in the photo above?
Did you get the PM I sent last week?
- Michael Vorrasi
Re: CV-6 photo
Yep, it's there. See my last post in the CV-8 thread. Missed your PM, I'll go check.John W. wrote:Mike V. -
Mike
- Model Monkey
Mike, thanks! That's exactly what I wanted to know.
I'm actually now more inclined to attempt a post 10/43 refit conversion from Trumpy's Hornet. Not sure yet. If anyone has some detailed information on the hull blisters please pass it along. That'll be the other big factor. I truly like the late-war AA fit. Bofors rock.
I'll need to finish Yorktown first before I start on Big E.
To all who have posted: thanks for all the wonderful information captured here!
- Blue Devil
McClusky's SBD
Jack,
Here's a link to a Midway site where one Ken Durling made a nice model of McClusky's SBD.
http://www.centuryinter.net/midway/durling/sbd4618.html
He doesn't say where he got the info for how it should look, but it seems pretty logical to me. I've been looking for info on this issue for years myself but this is the only thing I've found. Hey, no one can say you're wrong!
HTH
BD
HTH
BD
- jackyoung
Blue Devil,
Thanks. I think Ken would not make a so delicate model if he didn't get any proof. The GC is so small and I decide to delicate it.
The 6-B-1 here.
No B charactor and the tail line is also inaccuracy。
Jack
The 6-B-1 here.
Jack
http://www.ModelFleetCN.com
Welcome to China Ship Model site.
Rich Mathsen
NMNA (Pensacola) CV-6 model 1/72
Check out the photos of the ENTERPRISE model at the National Museum of Naval Aviation on the Steel Navy site: http://www.steelnavy.com/EnterpriseCV6NMNA.htm
- Michael Vorrasi
Re: NMNA (Pensacola) CV-6 model 1/72
It is a stunning model, but I was a bit let down by the colors (or lack thereof) the builders used. I'm hoping it is just the photographic limitations and /or lighting, but there seems to be a definite aversion to the fact that the ship was a fairly dark blue-gray with dark blue decks. I know they were trying for a weathered look, but geez. Pure neutral gray tones. Anti-blue syndrome: it is closely related to brown flight deck syndrome! At least they didn't make the deck tan, as some do. But for detail... I'll be studying those shots for a while!Rich Mathsen wrote:Check out the photos of the ENTERPRISE model at the National Museum of Naval Aviation on the Steel Navy site: http://www.steelnavy.com/EnterpriseCV6NMNA.htm
Mike
Rich Mathsen
CV-6 model color
I thought at first it was due to lighting, etc. But John Snyder (John@WEM) says that when he saw the model without the case, it was gray. Too bad. It is, even with this error, a superb model in every other way.
Rich Mathsen
Contact info
Jack: E-mail me at rich101250@verizon.net (those are all numbers following rich). Can't say my response will be prompt, though, as most of the time my daughter's using the computer, but I do check my mail at least once a week.
Rich
Rich
- jackyoung
1942 June 4 Midway CV6 Enterprise
Finished 10 mins before.
- jackyoung
- Cadman
- Site Admin
Rich Mathsen
Very nice Big E model
Nice work there, Jack. One minor point: I've seen no evidence that tractors were in use aboard ENTERPRISE prior to her return to the Hawaiian area in April (?) of 1943. Other than that, I believe that you've produced an excellent representation of the ship. Congratulations!
Yeah, what he said!! Very nice!Cadman wrote:Nice work, very clean build.
