Calling all Russian submarine fans
SS, and SSN.
ssn705
Re: Calling all Russian submarine fans
Post by ssn705 »
Woodstock74 wrote:Mikro-Mir doing a Yankee class:
https://www.facebook.com/mikro.mir.dnep ... SFw9mBpjsl
Saw it yesterday. Very exciting. Especially with the hull break that could potentially make STRETCH, SIDECAR and NOTCH more easily possible :)
Planning on doing screws for it (and others I might have mentioned)?
Dave
Woodstock74
Post by Woodstock74 »
Dave
Always a possibility of course. As for the Oscar I and Akula suggestion. The Akula was fairly straight forward but I haven't printed a production level yet, only a handful of prototypes. The Oscar is a pickle and I've been working on it on and off since the summer; without photos to go off of I'm using the Victor screw (the tandem-fixed screw like on the Mike) as a surrogate. And I'm struggling to get anything I like and for now avoiding reevaluating the Mike while I'm at it (but once I crack the Oscar I'll probably look at reworking the Mike).
it is unlike the Mike and more like the Victor but for now I just can't get it to look 'right'. And I'm avoiding reevaluating the Mike, and it'll probably need it once I crack the shape issues I'm running into with the Oscar I. And the shame of it all is that using the Victor screw as a surrogate, there are actually tons of photos from different angles and what I'm running into is a hardstop on my CAD abilities I think, for now.
ssn705
Post by ssn705 »
I appreciate you considering the things I proposed and putting so much work in. Unfortunately pictures of OSCAR I screws are few (and are probably all screencaps from the same movie). I'll keep looking.
Dave
Tom Dougherty
Post by Tom Dougherty »
Dave, Mike,
Here are the Oscar propellers photos I have, and are Oscar II.
Oscar I is reported to have (depending on the source) either 4 or 5 blade non-skew screws. Probably similar to the Delta III and Papa 5 blade screws below
These are from Vepr's collection. He would probably answer himself but is busy on his research work.
Delta III 5 blade screws
Papa 5 blade screws
Papa 5 blade screws
Last edited by Tom Dougherty on Thu Dec 14, 2023 10:10 am, edited 1 time in total.
Tom Dougherty
Tom Dougherty
And the Yankee Class screws, which were not skewback and probably emitted a significant "blade rate" low frequency for US sonar detections.
Tom Dougherty
Mr. Church
Post by Mr. Church »
Russian Nuclear-Powered Submarine Arrives in Cuba:
https://www.themoscowtimes.com/2024/06/ ... uba-a85388
It's the Yasen Class Submarine Kazan. Wonder what is the black flag / symbol she is displaying on the side of her sail? Re-posted for ease of viewing, copyright rests with original owner:
A dragon perhaps? As that features in the coat of arms of the city of Kazan?
Here's a close-up of that flag, posted by Capt_Navy on Twitter and credited to Alexandre Meneghini of Reuters. Resembles some kind of Spartan or other Ancient Greek hoplite with a Swordfish on the shield.
ssn705
Post by ssn705 »
Not as cool as USS INDIANA's Bad Ass Battle Bass, but still pretty sweet.
Dance
Mr. Church
Timmy C wrote:Here's a close-up of that flag, posted by Capt_Navy on Twitter and credited to Alexandre Meneghini of Reuters. Resembles some kind of Spartan or other Ancient Greek hoplite with a Swordfish on the shield.
Good stuff Timmy. That answers that! Thanks.
Takom has released a 1/350 Project 658M (Hotel) SSBN: https://www.1999.co.jp/eng/11135558
Vepr157
Post by Vepr157 »
Wow, I'm impressed, that actually looks quite good. I suspect they used these plans, which I believe are quite accurate:
https://i.imgur.com/nDoI73K.png
Jacob
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/350 George Washington
1/72 Type VIIC
Woodstock74
Am I correct to think that the small maneuvering propellers the Russians use are "variable" geometry? That is, they can be planed/rotated for use, and they rotated so the blades are parrallel to travel direction (and lower drag)?
Vepr157
Post by Vepr157 »
Woodstock74 wrote:Am I correct to think that the small maneuvering propellers the Russians use are "variable" geometry? That is, they can be planed/rotated for use, and they rotated so the blades are parrallel to travel direction (and lower drag)?
There is a photo of the Komsomolets wreck that shows one of the secondary propulsion motors (note these are essentially only for emergency use, like their U.S. and British counterparts):
https://i.imgur.com/Ge0m7OA.jpeg
The blades are rotated to feather as you mentioned, and you can see a circle at the blade root, which is highly suggestive of a controllable pitch propeller.
Jacob
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/72 Type VIIC
Woodstock74
Anyone else pick up Iron Shipwrights new Sierra I/II kits? I have some questions about hull shape/cross section. Will post pictures later.
Tom Dougherty
Just received my Iron Shipwrights Sierra II today. Hefty chunk of resin!
What was your question?
Tom Dougherty
Woodstock74
The cross section on the IronShipwrights model appears like a horizontal oval. It looks very odd. Is this correct?
Vepr157
Post by Vepr157 »
Woodstock74 wrote:The cross section on the IronShipwrights model appears like a horizontal oval. It looks very odd. Is this correct?
The outer hull cross-section should be approximately circular like the drawing shows, so that looks way off.
Jacob
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/72 Type VIIC
Jon Warneke
Post by Jon Warneke »
Jacob
Hi Jacob,
The plans posted show a Project 945 boat (Sierra 1), while the kit posted is the Project 945A boat (Sierra 2). The Sierra 2 hull is 6.7 feet wider than a Sierra 1, as well as 8.5 feet longer, (40.3 foot beam and 351.6 foot length for the Sierra 1, 47 foot beam and 360 foot length for the Sierra 2) with the same vertical height. This will show the cross section to be oblong along the y-axis when viewed from the bow rather than somewhat circular with the Sierra 1 viewed from the bow.
Jon
Vepr157
Post by Vepr157 »
Jon Warneke wrote:
Hi Jacob,
Jon
No Russian source I have mentions any difference between the beams of the Sierra I and Sierra II; both have the same beam of 12.2 m (40.0 feet). Where did you get the 47-foot figure? I don't see any evidence for this in drydock photos or drawings.
Jacob
Under Construction:
1/350 Typhoon
1/350 Skate
1/350 USS Nautilus
1/350 Tang
1/350 November
1/350 Hotel II
1/350 Alfa
1/72 Type VIIC
Woodstock74
Sierra II:
Return to “Submarines”
