HMS Eskimo - 1/350 - Trumpeter
PiperMat
Post by PiperMat »
Almost finished! Build went rather well although I had some troubles with the paint. I overdid the weathering a little bit in some areas. I used the WEM photo etch set.
JCRAY
Re: HMS Eskimo - 1/350 - Trumpeter
Post by JCRAY »
Very pretty model, love the WA colors. Like to see more!
kylewoody
Post by kylewoody »
Indeed, I'd like to see some more of her too! :big_grin: Weathering looks spot on to me, I like a realistic ship.
Kyle
Dave Spencer
Post by Dave Spencer »
She looks pretty spot on to me.
Regards, Dave
PiperMat
Post by PiperMat »
Thank you for your kind comments!
This evening I did the smallest of the 4 boats:
I also made one of the Radar Yagi Antennae:
Only I'm confused as where it is supposed to go. According to the instructions, it should be 'mounted on a plastic rod pintles' (no idea what a pintles is�) and 'fit into the curved extensions to the rear of the bridge above the forward AA deck'. I think that's where I drew the red circle in the image below. Am I correct?
Admhawk
Post by Admhawk »
A pintle is a pivot mount like a pin that the item can rotate on.
I haven't found any clear photos that show the antenna in that spot, but I have seen small pins sticking up from the edge of the bulwark in and near the area circled, maybe 5" to 10" high.
Darren (Admiral Hawk)
