H101 water ghost
Opinions
You may select up to 2 options
View results
Rc boat crazy!
H101 water ghost
Post by Rc boat crazy! »
Hull that will not spring leaks for a long time.when I looked at another page a ship almost sank from leaks but the h101 has a way out of that!it is double-hulled and strong from collisions.their is a drawback however.it only has one shaft.if you damage the propeller shaft it means danger.this is because in rough water it would have to be grounded because if they propeller shaft is damaged their is no spares.so watch it!.whats good about it?well say it capsizes and water gets into its electrics.well then tho you may think it�s done it isn�t.its electrics are waterproof and it can sometimes get enough water at the back to get it back into shore.but make sure you try not tip it.just encase the plan fails.it is mainly designed for small lakes with 1 rowing boat.DO NOT TRY IT IN WATER WITH A REAL BOATS AS PROPELLERS WILL DRAW IT IN.fully tested in water by me
Re: H101 water ghost
Post by Guest »
Rc boat crazy! wrote:Hull that will not spring leaks for a long time.when I looked at another page a ship almost sank from leaks but the h101 has a way out of that!it is double-hulled and strong from collisions.their is a drawback however.it only has one shaft.if you damage the propeller shaft it means danger.this is because in rough water it would have to be grounded because if they propeller shaft is damaged their is no spares.so watch it!.whats good about it?well say it capsizes and water gets into its electrics.well then tho you may think it�s done it isn�t.its electrics are waterproof and it can sometimes get enough water at the back to get it back into shore.but make sure you try not tip it.just encase the plan fails.it is mainly designed for small lakes with 1 rowing boat.DO NOT TRY IT IN WATER WITH A REAL BOATS AS PROPELLERS WILL DRAW IT IN.fully tested in water by me
What even could stop a battleship from sinking?nothing than cruise ships
Return to “Ships and Subs”
