Hull maker needed
Moderator: ArizonaBB39
yankeemodelworks
Hull maker needed
Post by yankeemodelworks »
I need someone who is interested in making hulls in 3d CAD (Rhino).
I will supply a set of hull lines and/or plans for you to work on. Please let me know if you are interested.
John Sheridan
Yankee Modelworks
Avery Boyer
Post by Avery Boyer »
Would be if A) I had the skills and B) Had the money. If I had $900+, then I might be tempted....
Good luck!
Do you want someone to make a digital hull in Rhino, or use Rhino to make a physical hull?
yankeemodelworks
Timmy C wrote:Do you want someone to make a digital hull in Rhino, or use Rhino to make a physical hull?
Both actually.
John Sheridan
Yankee Modelworks
Paper Lab
Post by Paper Lab »
I do this all the time in different scales. If you interested I can send you some samples of my work. Using Rhino of course.
Paper Lab
darius@paperlab.com
nicholasnoodle
Re: Hull maker needed
Post by nicholasnoodle »
hi, MY NAME IS NICK WEEGENAAR. i CAN MAKE U A HULL FROM PLANS/LINES ANY SIZE, ANY MATERIAL. i LIVE IN THE UK, BUT IT COULD STILL BE POSSIBLE WITH CURRENT COMUNICATIONS, INTERNET , SHIPPING ETC. HAVE MADE LARGE WARSHIP MODELS, AND HAVE MADE ACTUAL BOATS, AND WORKED AS SHIP BUILDER IN THE PAST, MADE 8FT. BISMARK GRP HULL AGES AGO, SOLD MODEL AT CHRISTIES AUCTION IN LONDON. REGARDS, NICK.
