Calling all USF Constitution (1797) "Old Ironsides" fans
- Model Monkey
Here are photos of the famous "Hull Model" and photos of the Smithsonian Museum's 1/48 scale model of USF Constitution.
The three photos below are National Archives photos of the famous "Hull Model" named for the model's first owner and ship's captain at the time, Isaac Hull. The Hull Model of USF Constitution was made by the real ship's crew and presented to their captain, Isaac Hull, as a gift just after their War of 1812 victories. The model now rests in the Peabody Museum in Massachusetts. Since the model was made by actual crew members it is considered to definitively show Constitution's true War of 1812 appearance. Certainly the ship's own crew knew what their ship looked like and built an accurate representation for their captain.
Of the many injection-molded plastic kits now commercially available the Revell 1/96 scale kit most closely resembles the Hull Model.
Note that Hull Model shows that Old Ironsides only carries gun port lids at the extreme bow. Period documents confirm that Old Ironsides carried no hinged lids at this time. Those lids that were present were removable and stored below decks prior to going into action.
Also note the coloring of the masts and fighting tops (white) and yards (black) and that this model of Constitution does not carry her name on the transom. Compare the Hull Model photos to those of the Smithsonian Museum's 1/48 scale USF Constitution model which was built from early plans and using the Hull Model as a significant reference. The Smithsonian's modeler(s) chose to paint the gun deck stripe an off-white, very similar in tone and hue to what we today might call "radome tan". The rigging of this model is nearly identical to the Hull Model in arrangement. Some sources state that about 1809, her inner spar deck (upper deck) and forecastle bulwarks may have been painted "red ochre", a common practice at the time. The Smithsonian model is painted this way. Sometime between 1812-1815 her inner spar deck and forecastle bulwarks were repainted from red ochre to green as they are today on the actual ship at Boston. The Hull Model's inner bulwarks, rails and trim are painted green as is most of the spar deck trim moldings and the pinrails. During the War of 1812 it is believed that the inner bulwarks of the gun deck, one deck below, were whitewashed to aid in visibility. Also note that the Smithsonian model's boats are all individually colored. This is consistent with period practice in order to help identify individual boats at a distance at sea.
Various sources state that when originally built her hull was not painted black, just tarred, and that she had no white gun deck stripe or any gun deck stripe at all. The contemporary artist Michel Felice Corn� was commissioned at the time to paint Constitution at Tripoli as the ship appeared eight years before the War of 1812. Note the different coloration and that the ship's name does appear on the transom. Compare the 1804 Corn� painting to this superb model in the possession of the US Naval Academy Museum. Some sources state that Constitution as built had a red stripe and blue stripe painted on one strake each immediately above the gun deck gun ports.
Sometime shortly before 1809 her hull was painted black and she received a white or yellow ochre gun deck stripe painted on the four strakes between the gun deck gun ports achieving her now familiar black hull with white stripe appearance. Her gun deck stripe was alternately white and yellow ochre throughout the War of 1812. Constitution acted as a raider during that war. Her log and other documents state that her crew changed her coloring from time to time partly as a deceptive measure to confuse her pursuers as to her actual identity.
The painting and a cropped detail of it below are also by Michel Felice Corn�. The painting depicts Constitution's approach to HMS Guerriere in preparation for battle. It was commissioned as part of a set by Captain Hull. The paintings of that set were supervised by Constitution's purser Thomas Chew. The set of Corn� paintings are considered to be accurate representations of the ship at the time of the battle, both in color and detail. This is because the artist had access to the ship and her crew, several members of which he interviewed. Corn� personally visited the ship shortly after the battle and he took extensive notes regarding details and coloring from which he developed his paintings.
Here are some significant observations about the ship's appearance and coloring as depicted by Corn� in this painting and others in the set. Note:
- no gunport lids
- black hull, beak and transom background
- yellow ochre gun deck stripe (in other paintings of the set, the forward end of the stripe is a semi-circle terminating just ahead of the forward-most gunport, aft of the anchor line hawsepipes)
- yellow ochre lower masts
- natural wood upper masts
- white beak decorations
- white gallery decorations
- red gallery window frames
- pale green ship's boats, which may be the same green color applied to the inner bulwarks
- white and yellow/gold colors of the transom decorations
- red transom window frames
Also note that, like the Hull Model, the name "CONSTITUTION" does not appear on the transom.
The coloring of her masts and yards also changed a bit during these early years. In all of the Corn� paintings, the lower masts are painted yellow ochre, not white as they are today. It is difficult to make out the color of the yards but several, if not all, appear very dark, possibly black, a common practice at the time.
- no gunport lids
- Neptune
rcboater
Check out the FSM forum for more info
The "Ships" group over on the FineScale Modeler has had some extensive discussions on the Constitution and how her appearance has changed over the years. (For some reason, the ships forum at FSM has become the gathering place for builders of plastic sailing ship models.)
Having said that, I think Steve Larsen's post was spot on-- he gave a great summary of many of th emain points discussed at greater length over on FSM.
One resource worth checking out: CDR Ty Martin's book, "A Most Fortunate Ship". CDR Martin was the Constitution's CO during her overhaul and trip under sail int eh late 1990s. He has doen extensive research in primary documents, and pulled together a tremendous amount of material on the ship's history, including her changes in appearance over the years.
Check out my USCG Model kit list
- Neptune
- Model Monkey
Hello Roel!
She was coppered, no boot topping.
This thread was too good to leave in main and possibly use.
Here are some other links:
USSConstitution.Navy.mil
USSConstitutionMuseum.org
USS Constitution - The History
She's one of two sailing ships I want to build (Cutty Sark is the other)
- Neptune
I agree Tracy, I was thinking the same thing this morning but didn't want to bother Steve in rewriting that reply if I posted the same topic again in the "Calling all" forum. I already had trouble finding it back to check the colour pictures again!
Thanks Steve, I'll go forward in painting this baby then. Unfortunately I'm a bit slowed down by a colour I don't have in my posession!
I also found some mistakes on the Revell model too, I think the bow is completely different from the real one! Also the white line doesn't really attach to the bow in the correct way...
Thanks for all the help!
Roel
Roel
The merchant shipyard
- Avery Boyer
That's funny, 'cause I was just saying exactly the same thing to somebody! I don't much go for sailing ships, but I like Clipper Ships and ConstitutionTracy White wrote:She's one of two sailing ships I want to build (Cutty Sark is the other)
- Neptune
The Workbench (USS Constitution and others)
Hello Everyone,
Here's a view of my extremely messy workbench!
USS Constitution is now the priority ship, soon to be completed. If you look well you can also see a Dzeyran hovercraft, Sovremenny destroyer and Slava cruiser around.
The USS Constitution isn't worth a dollar and should be given to very experienced modellers with the aim of presenting them a challenge.
I have had to cut about every part on this ship to match them.
For example, as you can see on the top view, the masts are facing a totally wrong direction due to the small pins in the bottom to fit in the deck. I'll have to cut these off to let the mast face forward.
All the small cannons on the main deck have small pins on their bottoms too, to match the wooden supports. Funnily none of these pins fits into the holes in the wooden supports, so again cutting all of them off and just stick the cannon to the support (with of course the associated trouble of having them with the right side up and more or less straight.
Apart from that there are numerious flaws in the parts, not to mention that it isn't really a model of an existing ship but rather a "sailing ship" without a match in reality. Therefore it is also my aim to make it look nice rather than to represent the real ship. The customer for whom I'm building it isn't really demanding and likes good looking ships. He doesn't really care if this is a super detailed Constitution or something that looks like Connie.
Anyhow finished my rant, here's the pics:
Regards
Roel
Regards
Roel
- pingjockey
- PetrOs
- PetrOs Modellbau
I've done her sistership, the USS United States this summer, also from a Revell kit. Even if it was listed as 1:150, it was a 1:216 in fact.
You can see a number of her photos at
http://model.worldwar2ships.info/uss_united_states
I built her in 3 weeks straight out of the box, with only replacement being handmade ratlines. I also simplified her rigging a bit, just wanted her to look right.
Further kits in preparation.
- Neptune
It's 1/146 I checked the box. I don't know what it is in reality though, i'm not that interested in sailing ships apart from their nice appearance.
Currently I've all together been working for roughly 3 or 4 days on this one. No special add-ons will be done. It's getting forward pretty well, except for the bad and missing parts. She's on the workbench for a lot longer than those 3 days though, she's there for a couple of months now.
Anyway once she's finished I'll be able to clean things up a bit. Somehow I still don't feel ready to get that Slava and Sovremenny finished though!!!
Ron, maybe that's because you have more space and only one ship? (a big one in that though
). I kinda like to work messy, if you mess around with the paint or cut in the desk, it's not that hard. It wasn't clean so it's no disaster if there's any drop of paint more or less on it.
Could help to get things apart from each other though, I'm seeing a disaster coming, there's a PE 1/700 Krivak mast there and a Sovremenny one and an Orekh illuminator too, so I'll have to be careful with cleaning up things!!!
Rusty White
- Flagship Models
- PetrOs
- PetrOs Modellbau
Well, once in 2-3 weeks I cleanup my workbench, as I simply get a few dozens of color bottles, paint brushes, sprue trees, frets etc cluttering the table to the extent that I have no place for the models! ;o)les wrote:Clean workbench, sick mind.
Steve Adams
Heck, you guys are lucky to have a work bench to clean up or not. My work area is the kitchen table, so when I am finished it gets cleaned. Now that is a real pain in the you know what. One of these days when I retire an extra bedroom may be turned into my work area. Until then, pass the butter,.... er glue please.
- Model Monkey
Yup, kitchen table builder here too. It all has to be cleaned up by suppertime.
More Hull Model photos taken by Steve Hawley and used here with his permission.
