http://www.britishpathe.com/video/hms-v ... ing-cruise
Calling all HMS Vanguard (1944-1960) fans
- modellmariner
Re: Calling all HMS Vanguard (1944-1960) fans
By the way, there are some interesting shots of the HMS Vanguard.
J�rg
http://www.modellmarine.de
Current Project:
French Navy Antiaircraft Cruiser Colbert C 611,1964, 1/700
Current Project:
- modellmariner
The deck in front of the breakwater has a wooden deck structure. When painting with RN Deck Gray but that's no problem.
J�rg
Current Project:
Current Project:
- Aop Aur
Hello,
I need to gather some more references and drawings of Vanguard's 5.25 inch gun and turret. If anyone could send me copies or scans of the drawings, I would be appreciated. They will be used to design a 3D model of the turret and uploaded on Shapeways.
Aop
Aop
On the way:
And our artworks!
And our artworks!
- Maarten Sch�nfeld
Very different: they are considerably larger and hexagonal in planform (instead of round/oval).DavidP wrote:how different are they from the kgv & dido classes?
Roger Whittaker +9/13/2023
- Aop Aur
Hi all,
I am looking for more photos of the Vanguard 5.25" gun, especially close-ups. So far there are not many on the internet and all are of low res. If anyone got some better ones, please PM me or send them to the email aopaurshipmodels at gmail dot com
Thanks in advance!
Aop
Thanks in advance!
Aop
On the way:
And our artworks!
And our artworks!
- Aop Aur
Hi all,
Could anyone help me with the Vanguard 5.25 inch gun dimension info? O/A length of the gun is all needed...
Aop
Aop
On the way:
And our artworks!
And our artworks!
- Aop Aur
Well, from the butt-end of the gun house to the tip of the barrel...
Thanks!
Aop
Thanks!
Aop
On the way:
And our artworks!
And our artworks!
- Aop Aur
Any thoughts?
Aop
Aop
On the way:
And our artworks!
And our artworks!
rotley
Aop Aur wrote:Hi all,
Thanks in advance!
Aop
G'day Aop
Have you seen these?
http://www.zhanliejian.com/navweaps/WNB ... 1_pics.htm
http://web.archive.org/web/201504070732 ... teria=5.25
Plus some detailed info
http://www.navweaps.com/Weapons/WNBR_525-50_mk1.php
HTH
Rod
- Aop Aur
Hi Rod,
Thanks for the links. I have seen all of them. Navweaps says the overall gun length is 6.998 metres. It did not mention any differences between Vanguard gun version and the rest (KGV, Dido), so would it be possible that they are all of the same length? Vanguard still has enlarged gun houses...
Aop
Aop
On the way:
And our artworks!
And our artworks!
- Aop Aur
I still need comfirmation whether the Vanguard guns are identical in overall length to the rest (KGV, Dido, Spartan, etc.) The reason I have this question is the fact that Vanguard had enlarged gun houses, so the length could have been different.
Anyone?
Aop
Anyone?
Aop
On the way:
And our artworks!
And our artworks!
SeanF
There is no indication of a new gun barrel being a part of the Vanguard's mounts, so 5.25"/50 remains 5.25"/50. Possibly a larger breach mechanism could have added to overall gun assembly length, but that would be inside the turret; externally there would be no difference in gun length.
Could they have used the larger gunhouse size to mount a longer barreled gun? Say, a 5.25"/60? Possibly, but that would likely have required a lot more changes to the machinery, and it wouldn't still be designated as a Mark of a twin 5.25"/50 gun mount.
- Sean F.
- Sean F.
- Aop Aur
Thanks for the reply, Sean! It really helps. Now I could continue my design!
Aop
Aop
On the way:
And our artworks!
And our artworks!
- Spot
Is anyone aware of a PE set for the Hasegawa 1/450 kit?
The most attractive project, to me, is the one that I've just heard someone say can't be done.
- Dave Rowe
Peter Hall of Atlantic Models produces the p.e. set.
Also, these have just been released in the last week. I plan to get a set of each:
https://www.shapeways.com/product/2WRQG ... d=63990391
https://www.shapeways.com/product/KT3CN ... d=63997201
- Spot
Those look great!Dave Rowe wrote:Peter Hall of Atlantic Models produces the p.e. set.
That kit leaves so much room for added detail it'd be a shame not to use it. I had thought about scratch-building turrets and/or retooling what's there, but those prices are quite reasonable so I might go that route.
- Dave Rowe
Does anybody happen to know the size(s) of Carley Floats Vanguard carried?
EJFoeth
I do not but the list of possible floats is (type and box size)
5 3ft 6in x 6 ft 12in
6 3ft 9in x 6ft 6in 13in
7 4ft x 7ft 14in
8 4ft 6in x 7ft 6in 14in
19 5ft x 8ft 14.5in
20 5ft x 10ft 15.5in
14 6ft x 10ft 16in
15 6ft6in x 10ft6in 17in
16 7ft x 12ft 18in
17 8ft x 12ft 19in
18 9ft x 14ft 20in
may be helpful to get the right type from pics?
7 4ft x 7ft 14in
19 5ft x 8ft 14.5in
14 6ft x 10ft 16in
16 7ft x 12ft 18in
17 8ft x 12ft 19in
18 9ft x 14ft 20in
- Dave Rowe
Thanks Evert-Jan. That's a start at least.
- Dave Rowe
These have been added to Shapeways this morning, a huge improvement over the blobs of plastic in the kit.
https://www.shapeways.com/product/Z5Q6F ... arketplace[
