Hi
I want to put a small amount of 'rigging' on my 1/1250 ships, however, as I only want a representation - will the readily available thread of 0.75 and 0.3 be too thick?
Can anyone advise please.
Everett
Rigging thread
Re: Rigging thread
I don't know what units your 0.75 and 0.3 are in (mm? inches?), but both would be too thick for sure. The best option would be to use stretched sprue, as per Jim Baumann's method, since you can control how thin you want it to be: viewtopic.php?f=4&t=37536
Alternatively, the thinnest commercial product is UNI-Caenis, a fly-tying line. It is just about right for 1/700 scale, so would be too thick for 1/1250 if you were thinking of doing ALL the rigging, but should be fine for your purposes of a few simple strands for representation.
Everett
Re: Rigging thread
Thanks Timmy
I have just been putting up masts with 'Flower Arranging' wire, very inexpensive instead of brass.
I will look at the site for my representational rigging....and keep in mind that recommended for 1/700
Everett
Everett
intruder500
Re: Rigging thread
Hi All:
You guys either have eagle eyes or have magnifiers that can see past the microscopic range! I have trouble with 1/700! How in blazes does one work in a scale that small? Holy Crap! Let me know please? Really interested to know. It may help me with 1/700 builds. Thanks
Stephen C.
intruder500
Stephen C.
intruder500
JoeP
Re: Rigging thread
Consider also fake hair from a wig shop. It is somewhat stretchy and comes in many colors.
JackSix
Re: Rigging thread
Hi Everett,Everett wrote:Hi
Everett
I use infini Black Lycra Rigging (https://freetimehobbies.com/infini-mode ... ier-145ft/) and Uni-Caenis (https://www.ffnproshop.com/uni-caenis-thread) in black and 20 Denier. The latter, if you need to attach flags, etc., as lycra is not stable enough for this. Works perfect. See an example in 1/1200 scale here in the board -> viewtopic.php?f=47&t=14016&p=909929#p909929
Jack
rfwood1
Re: Rigging thread
I'm new to rigging my 1/700 model ships and I'd like to get recommendations as to what the best products are to use as the "thread." I've looked at online videos, so I think I can figure out the actual installation process, but I'm unsure about the material to use for the simplest and best looking rigging. Thanks in advance for any help!
drasticplastic
Re: Rigging thread
This is Uni Caenis on Flyhawk 1/2000 Bismarck:
En-TACT
Re: Rigging thread
I found Modelkasten, 1/700 0.07mm - worked great for me.intruder500 wrote:Hi All:
Stephen C.
intruder500
viewtopic.php?f=59&t=161768&start=60
rfwood1
Re: Rigging thread
I just wanted to thank you folks who gave me advice on the use of Lycra and Modelkasten wire for rigging my 1/700 scale warships. It's worked out very well (I've updated 30 ships already) and I'm moving forward with adding rigging to the rest of my models!
Now I have a new question. To complete my warships I need to get WW1 German, WW2 Italian and WW2 British national flags. I bought assorted flag decals (from GMM?) in the past, but I can't find flags for these these specific nations. Also, I tried metal white ensigns, but they didn't work very well. I'd try paper flags, if I could find them, but no luck. I usually glue a bit of aluminum foil to the flagstaff and then place a water decal over the foil, so I'd like to continue using this method. Any ideas? Thanks in advance for any advice....
