Solidworks
Moderator: ArizonaBB39
- Cadman
- Site Admin
Solidworks
OK, against my better judgment, I have agreed to give Solidworks a fair shake. Yes, it has some cool features, but one thing is driving me freaking nuts. Why is my Z-axis pointing down on all my models? When I click the top view, my model capsizes and I have to use the bottom view button to flip it back. I can't find any help online, my tech people tell me that's just the way it is and I can customize it. Well then how do I do that globally so all my drawings will display in the normal CAD mode?
- Jefgte
When you begin to draw...
Choose the good plan -yz - for the sketch
the extrusion is - x - direction.
That what I made.
So,if you edit the extrusion, you could reverse it
When I made the Panzerschiff rangefinder, I made a square for the base in -yz- and made the extrusion in -x-
It is certainly possible to change the axis but, I don't know how to made
It is very important when you assemble the ship on the hull that all pieces must be with the good representation axis
When I design my Panzerschiff 10.5m rangefinder, their arms are not vertical
Jef
That what I made.
Jef
Current 1/700 WL
HMS Repulse
HMS Repulse
- Cadman
- Site Admin
The problem is that these are drawings that I am importing from AutoCAD. They come in with the part laying on it's side.
I miss my object snaps and easy editing commands. However a part constructed in the beginning as a solidworks file has other advantages that you can't get in ACAD.
But just today I received my copy of AutoCAD 2008 Mechanical, so I will be busy checking out the new features.
- rtwpsom2
Re: Solidworks
That's because AutoCAD's front view imports to SolidWorks top view. You have to rotate the entire AutoCad model backwards 90 degrees to have it import properly.
- Jefgte
Re: Solidworks
Since april 2008, I loging in Navalism (Alternate history)
I am in charge of Peru Fleet & I design some ships for Armada in 3D.
Here is Battleship Cuzco 1897-1899 - 10400t Pre-dreadnought design with Solidworks
Jef
Current 1/700 WL
HMS Repulse
HMS Repulse
- Cadman
- Site Admin
Re: Solidworks
Well just maybe Solidworks should adjust their interface to properly import AutoCAD files. AutoCAD is king of the CADD world anyway.rtwpsom2 wrote:That's because AutoCAD's front view imports to SolidWorks top view. You have to rotate the entire AutoCad model backwards 90 degrees to have it import properly.
- Cadman
- Site Admin
Re: Solidworks
That looks pretty cool. Keep up the good work.Jefgte wrote:![]()
TommyL
Re: Solidworks
I just got the 2008 version and HATE IT! They change the way some of the tool bars are laid out and it just gives me a Fisher Price kind of feeling. At least 2006 doesn't look and feel like a clown designed it. Excuse me.......I have to go PUKE now.
TommyL.
TommyL.
- Cadman
- Site Admin
Re: Solidworks
Tell us how you really feel Tommy!TommyL wrote:Excuse me.......I have to go PUKE now.
Don't feel bad, some clowns at AutoDesk felt that redesigning all the icons in AutoCAD 2009 was a good idea. Never mind that we have been used to the old ones and now have to stop and hunt for the right icon.
TommyL
Re: Solidworks
Tim,
--The simple solution that would have saved them time and money: If its not broke DON'T *#$% WITH IT.
I need a dose of ambition to either reinstall 2006 or learn to navigate 2008.
I'm done ranting and raving now. All is well in the world.
TommyL.
TommyL.
proflooney
Re: Solidworks
how do you guys get the weird shapes in the sterns to loft up in solidworks? I been lofting plane fuselages for years but have yet to be able to get a good ships hull. I am trying to do the bismark and cant get it for nothing
Joe
Joe
- DrPR
Re: Solidworks
I'm curious about the plane rotation problem when importing AutoCRUD files into SolidWorks. I abandoned AutoCRUD 20 years ago, so I don't know how it works now, and I haven't used SolidWorks.
In the program I use (DesignCAD) we have an option to set a default axis combination (XY, XZ, YZ) as the up/down and left/right plane for the side/front view. Can you do this in SolidWorks? If so, can you select a default plane that causes AutoCRUD files to import correctly?
proflooney
Re: Solidworks
not sure on autocrud but once in solidworks you can easily adjust everything with the change option which allows you to change the standard orientation your model comes in at to match what you want in solidworks.
so the bringing in of other parts shouldnt be any big problem.
Joe
Joe
