HMS Blackmore (L43) 1/700 from an IBG kit.
Donald
Post by Donald »
Here's HMS Blackmore built from IBG's Slazak kit. This took my fancy as I don't think I've ever seen this vessel modelled before. A very easy build (apart from the very fiddly PE brass 20mm guns on the bridge wings). After pre-painting I got the bulk of it put together between elevenses and lunch on Monday. Very satisfying indeed. It's lacking the dipole antenna on the mast which I'm sure is included on other IBG PE sheets. Otherwise, a pleasant model to build.
HMS Blackmore.
HMS Blackmore.
Return to “Completed Models”
