Calling all IJN Fubuki-class (吹雪) fans
Given the amount of information I have gathered on the Fubuki class over the last two years as I build four kits of the new PitRoad tooling, and play with a Tamiya kit as well (see build progress log here: viewtopic.php?f=59&t=36732 ), and with FineMolds set to release a 1/350 version sometime in 2009, it seems only proper that I attempt to share the information I have at hand.
As a start, a reasonably good overview is available at wikipedia: http://en.wikipedia.org/wiki/Fubuki_class_destroyers
I�ve pasted a copy of that overview immediately below.
Overview
Preceded by: Mutsuki-class destroyer
Succeeded by: Hatsuharu-class destroyer
Subclasses: Type I (Fubuki class)
Type II (Ayanami class)
Type III ( Akatsuki-class)
Built: 1926�1933
In commission: 1928�1945
Completed: 24
Lost: 22
General characteristics
Type: Destroyer
Displacement: 1,750 long tons (1,778 t)
Length: 118.5 m (388 ft 9 in)
Beam: 10.4 m (34 ft 1 in)
Draft: 3.2 m (10 ft 6 in)
Propulsion: 2 shaft Kampon geared turbines
4 (Groups I & II) or 3 (Group III) boilers
50,000 hp (37,000 kW)
Speed: 38 knots (44 mph; 70 km/h)
Complement: 197[1]
Armament: � 6 � 127 mm (5 in)/50 caliber DP guns (3�2)
� 2 � 13 mm (0.51 in) Type 93 machine guns (2�1)
� 9 � 600 mm (24 in) torpedo tubes (3�3)
� 18 � Type 91 torpedoes
� 18 � depth charges
Introduction
The Fubuki-class destroyers (????), originally only known as numbered destroyers 35 to 54 of the Imperial Japanese Navy "Special Type", were completed between 1928 and 1931. They were assigned names as they were launched, in keeping with Japanese practise.
Intended to set a new standard for IJN destroyers, the Fubukis were part of a program after World War I to give Japan a qualitative edge with the world's most modern ships.[2] As a result, they had heavy armament, high speed, and large radius of action. The Fubuki's not only set a new standard for Japanese vessels, but for destroyers around the world. At a time when British and American destroyers had changed little from their unturreted, single-gun mounts and light weaponry, the Japanese destroyers were bigger, more powerfully armed, and faster than anything that any other fleet possessed. They were to remain formidable opponents to the end of the war, despite being much older than many of their adversaries. (They also sparked the U.S. Navy's Porter-class, only eight of which were built.[3]) The Fubuki class has been called "the world's first modern destroyer."[4]
Description
Initially designed as a 2000 tonner with a 5-inch (127 mm) battery, two twin 24-inch torpedo tubes (just introduced in Mutsuki), and capable of 40 knots (74 km/h), they were modified in response to the Washington Treaty as 1680 tonners with more tubes, but slower, only 35 knots (65 km/h).[5] Contrary to previous IJN destroyer practice, the Fubukis had the forward torpedo tubes not in the fo'c'sle break, but between the siamesed[6] stacks (a location similar to U.S. ships). In addition, they introduced splinterproof, gas-tight turrets for the 5-inch guns, far ahead of their time.[7]
To increase comfort, the fo'c'sle was raised, the bridge enlarged and enclosed,[8] and the bows given a significant flare, to offer protection against weather in the Pacific.
Between June 1928 and March 1933, twenty-four Fubukis were built, in three groups.[7] The second and third groups had new 5-inch DP mounts, capable of elevating to 75� for AA use, making them the world's first destroyers with this ability.[7] The first group can be distinguished from later ships by their lack of ventilators atop the stacks,[7] while the third group's larger boilers gave them a narrower fore funnel.[7] As completed, group three introduced a unique splinterproof torpedo tube turret (later retrofitted),[7] allowing the tubes to be reloaded in action (both of which Western destroyers still did not do in the 1990s).
In 1934, Miyuki was sunk in a collision.[9]
As a result of several IJN ships suffering damage in a 1935 typhoon,[7] the Fubukis were rebuilt between 1935 and 1937 to improve hull strength and stability. This increased the displacement to 2050 tons standard and 2400 tons full load. The rebuild reduced the top speed slightly. They had a range of roughly 5,000 miles (8,000 km) at 14 knots.
As completed, Fubukis had twin 5-inch in "A", "X", and "Y" positions, with triple torpedo tubes in "D", "P", and "Q",[10] making them the most powerful destroyers in the world at the time of their completion. During the Pacific War, "X" turret was replaced by more AA, and radar was installed.
Only Hibiki and Ushio survived the war. An astounding eight were sunk by submarines, and two by mines.
As was common with most ships during World War II, the anti-aircraft armament was steadily upgraded during the war as the extent of the aircraft threat was realized. The anti-submarine capability was also upgraded. By 1945, the surviving ships of the class had one aft turret removed to create space and lighten the top for the addition of fourteen 25 mm anti-aircraft guns, two additional 13 mm anti-aircraft machine guns, and 18 more depth charges.
Types
There were actually two models of Fubuki, the original Type I (Fubuki) type, built in 1928 and 1929 and the following Type II (Ayanami) type built in 1930 and 1931. The Type I's primary 5-inch turret was known as the Model 'A', and could only elevate to 40�, whereas the Type II's Model 'B' turret could elevate to 75�. Furthermore, the Type II's bridge was enlarged and the boiler room's air inlet was changed from a pipe to a bowl shape. Sometimes listed as a third type, the Akatsuki-class was based heavily on the Fubuki.
The Fubuki destroyers sorted by type and order of registration are as follows:
Type I (Fubuki)
Fubuki (N�35) - built at Maizuru Navy Yard
Shirayuki (N�36) - built at Yokohama Navy Yard
Hatsuyuki (N�37) - built at Maizuru Navy Yard
Miyuki (N�38) - built at Uraga Dock Company
Murakumo (N�39) - built at Fujinagata
Shinonome (N�40) - built at Sasebo Navy Yard
Usugumo (N�41) - built at Ishikawajima
Shirakumo (N�42) - built at Fujinagata
Isonami (N�43) - built at Uraga Dock Company
Uranami (N�44) - built at Sasebo Navy Yard
Type II (Ayanami)
Ayanami (N�45) - built at Fujinagata
Shikinami (N�46) - built at Maizuru Navy Yard
Asagiri (N�47) - built at Sasebo Navy Yard
Yugiri (N�48) - built at Maizuru Navy Yard
Amagiri (N�49) - built at Ishikawajima
Sagiri (N�50) - built at Uraga Dock Company
Oboro (N�51) - built at Sasebo Navy Yard
Akebono (N�52) - built at Fujinagata
Sazanami (N�53) - built at Maizuru Navy Yard
Ushio (N�54) - built at Uraga Dock Company; scrapped 1948.
Inazuma - built at Fujinagata
Akatsuki - built at Sasebo Navy Yard
Ikazuchi - built at Uraga Dock Company
Hibiki - built at Maizuru Navy Yard
Dan's note: I will add that 36 units were originally planned, but concerns about exceeding treaty limits for destroyer tonnage led to a cut back to 24 units. Also, note that Uranami is a transition ship between Types I & II and is officially considered its own class, Type I-hai. Further, the Type IIIs are clearly, & officially, a separate, and improved, subclass. Details regarding late war AA fit differ from ship to ship.
Available kits: (1/350 updated June 2026)
1/700
1972 (Waterline Consortium 1st generation) � Tamiya Issued
Type I
Fubuki, 1940 -Item # 31401, kit # WL401, originally issued 1972, re-issued 1994
Hatsuyuki,1943 -Item # 31404, kit # WL404, originally issued 1972, re-issued 1994
Type II
Ayanami, 1942 - Item # 31405, kit # WL405, originally issued 1972, re-issued 1994
Shikinami, 1944 - Item # 31408, kit # WL408, originally issued 1972, re-issued 1994
Type III
Akatsuki, 1940 - Item # 31406, kit # WL406, originally issued 1972, re-issued 1994
Hibiki, 1944 - Item # 31408, kit # WL407, originally issued 1972, re-issued 1994
2007+ Second Generation �Pit-Road (Skywave) issued (all come with lower hull option)
Type I
Fubuki, 1941 - Item # PITW-106, issued 2007
-Item # PITW-106E, with photo etched parts, released late 2007
Shirakumo, 1944 - Item # PITW-107, issued 2008
-Item # PITW-107E, with photo etched parts, released late 2007
Shinonome, 1941 - Item # SPW-08, issued late 2010
Murakumo, 1940 -Item # SPW-25, with new equipment set NE-07, released late 2013
Hatsuyuki, 1940 -Item # SPW-26, with new equipment set NE-07, released early 2014
Shirayuki, 1941 -Item # SPW-39, with new equipment set NE-07, released mid 2015
Miyuki, 1934 -Item # SPW-42, with new equipment set NE-07, released early 2016
Isonami, 1941 -Item # SPW-48, with new equipment set NE-07, released mid 2016
Type II
Ayanami, 1942 - Item #PITW-102, issued 2007
-Item # PITW-102E, with photo etched parts, released mid 2007
Shikinami, 1944 - Item #PITW-103, issued 2007
-Item # PITW-103E, with photo etched parts, released mid 2007
Oboro, 1942 -Item # SPW-28, with new equipment set NE-07, released mid 2014
Sazanami, 1944 -Item # SPW-29, with new equipment set NE-07, released mid 2014
Akebono, 1941 -Item # SPW-50, with new equipment set NE-07, released early 2017
Sagiri, 1941 -Item # SPW-61, with new equipment set NE-07, released April, 2019
Type III
Hibiki, 1945 - Item #PITW-104, issued 2007
-Item # PITW-104E, with photo etched parts, released late 2007
Ikazuchi, 1944 - Item #PITW-105, issued 2007
-Item # PITW-105E, with photo etched parts, released late 2007
Inazuma, 1944 -Item # SPW-24, with new equipment set NE-07, released late 2013
Akatsuki, 1940 -Item # SPW-27, with new equipment set NE-07, released early 2014
2015 Third generation � Yamashita Hobby Issued
Type I
Fubuki, 1941 - Item # NV.1, released 2015
Fubiki, 1941 - Item # 20309, limited edition version with photo etch parts, released July, 2016
Type II
Ayanami, 1942 - Item # NV.3, incorrect upper bridge face (appropriate for Amagiri/Sagiri/Yugiri/Asagiri) released November, 2016
Amagiri, mid 1943 - Item # NV.5, released October, 2017
Sagiri, 1941 - Item # NV.6, released November, 2017
Ayanami, 1942 - Item # NV3R, REVISED & CORRECTED Ayanami with correct bridge face, released May, 2018
Ushio, 1945 - Item # NV7, released May, 2018
Akebono, 1942 - Item # NV8, released August, 2018
Shikinami, 1942 - Item # NV9S, limited edition with some FineMolds parts, released December, 2018
Uranami, 1941 - Item # NV10, the transition Type 1A vessel, released mid-December, 2019
Shikinami, 1942 - Item # NV9, standard kit, but with new, corrected lower bridge & a section of torpedo trolley rails, released mid-July 2020
Ayanami, 1942 - Item # NV3U, REVISED & CORRECTED upper & lower bridge face & a section of torpedo trolley rails, pending release mid August 2020
Type III
Hibiki, 1941 - Item # NV.2, released June, 2016
Inazuma, 1944 - Item # NV.4, released July, 2017
1/350
Triumph - cast resin hull with 3D printed superstructure and parts
Fubuki 1941 -Item # TRFM35004WL (waterline) or TRFM35004FH (full hull), with full PE available, released March 2026
Fine Molds - styrene injection
Type II
Ayanami, 1942 -Item # FW1, released late 2010
Shikinami 1936 or 1941 -Item #38901, released July, 2011
Amagiri, mid 1943 -Item # FW2, released December, 2011
Ushio 1944 -Item # FW3, released July, 2021
Akebono 1944 -Item #FW4, released August 2023
Sagiri 1941 -Item #FW5, released August 2023
Some photos follow below to illustrate the different types, configurations and variations within type. I used some colorized photos because the contrasts show certain details a bit better than the standard black & white photograph, given the limits of this site�s resolution parameters:
Overview
Built: 1926�1933
Completed: 24
Lost: 22
Type: Destroyer
Complement: 197[1]
Introduction
Description
Types
Type I (Fubuki)
Type II (Ayanami)
1/700
Type I
Type II
Type III
Type I
Type II
Type III
Type I
Type II
Type III
1/350
Type II
Re: Calling all IJN Fubuki class Toku-gata fans
Type I Isonami & Type IA Uranami, both in original configuration
Type I Usugumo after modernization 1936
Type II Ayanami as built
Type II Asagiri as built
Type II Asagiri as modernized
Type II Akebono as modernized 1936
Type II Ushio after refit 1943
Type III Hibiki bridge before modernization
Type III Akatsuki after modernization 1937
There are several builds of Fubuki Types in the gallery. Apologies if I�ve missed any. As follows:
Type Is
A 1/700 build of Fubuki from the PitRoad kit by Andrew Johnson:
Another 1/700 build of Fubuki from the Tamiya kit by Waldo Silva:
A build of Shirayuki from the 1/700 Tamiya kit by Eric Navas:
My recent build of Shirayuki from the new 1/700 PitRoad kit: http://www.modelshipgallery.com/gallery ... index.html
A build of mine of Shirakumo 1944, from a kitbash of the Tamiya hull and PitRoad parts:
Type IIs
1/350
The first build of the exquisite FineMolds kit of Ayanami 1942 from Bill Kluge:
Here is a diorama build of Amagiri running down PT-109 by Basilios Giehos: http://www.modelshipgallery.com/gallery ... /index.htm
Another diorama of Amagiri and PT-109 from John Leyland: http://www.modelshipgallery.com/gallery ... /index.htm
1/700
A very notable, accurate, and smart, 1/700 build of Ushio via the PitRoad kit in her original configuration by Jeff Lin � see also the link of the buildup:
A 1/700 build of Shikanami from the Tamiya kit by Ralph Kuo:
A 1/700 build of Ayanami from the Tamiya kit by Steve Shrimpton. I think he did a great job with this kit:
A 1/700 build of Sazanami from the Tamiya kit by Jesus Alcocer:
My attempt to correct the 1/700 Tamiya kit into a Type II for Sazanami (ironically, my recent research makes me realize that this build cannot be of Sazanami, but more likely Amagiri in late 1943; I expect to cover that further on in this thread): http://www.modelshipgallery.com/gallery ... index.html
Another nice 1/700 build of Ayanami from the Tamiya kit by Yifeng-Mao:
My 1/700 build of a late war Ushio from the PitRoad Shikanami kit:
My 1/700 build of Ayanami 1942, from the PitRoad Ayanami kit:
Type IIIs
A 1/700 build of Hibiki from the Tamiya kit by Eric Navas: http://www.modelshipgallery.com/gallery ... index.html
A 1/700 build of Akatsuki from the Tamiya kit by Pete Longo:
Among the more surprising points that my research has enlightened me on are:
� Forecastle arrangements: Type I vs. Type II/III
� Air Intakes/hoods at the base of the funnels , other ventilator arrangements
� Funnels
� Foremasts arrangements
� AA fit
� Smoke generators
� Depth Charge Arrangements:
� RDF Compartments
� Bridge mounted running lights
I�ll try to tackle them as time allows.
Type Is
Type IIs
1/350
1/700
Type IIIs
� Funnels
� AA fit
� Smoke generators
� RDF Compartments
- Gilbert
- L'Arsenal
Hi Dan,
Very interesting indeed
Could you give as well some japanese references as well, please ?
Congratulations for this detailed research
cheers
Gilbert
PS - Looking forward to an update on your IJN DD WIP
cheers
Gilbert
Some Japanese references include:
Gakken #18 on Fubuki class DDs
Gakken #70 on Fubuki class DDs
Gran Prix Shuppan Anatomy of IJN destroyers
Kojinsha Mechanisms of IJN destroyers
Kajainsha History of Japanese destroyers
Kure Maritime Museum � IJN Destroyer volume
Maru Special #s 7, 17, 21, 94, 95, 98 & 111
Model Art Ship Modeling Special # 27
Selected photos from the Shizuo Fukui collection 2 vol. set
Takagi IJN Photo Album
Hara Shobo IJN plans sets volume
I will add Main Armament as a category to be addressed.
Without access to detailed references in Japanese, perhaps all English speaking IJN modelers, myself included, have assumed that the all three Fubuki Type hulls were identical. For that matter, I believe that many Japanese modelers shared that belief. The truth appears to be otherwise.
I had no clue until I happened to compare the newly released PitRoad Type I kit with their new Type II and Type IIl kits. The Type I kit forecastle was shorter and finished more simply. That was a surprise, so I took a closer look at numerous photo references for all the Fubuki types.
Doing my best to visually match up the perspective angle from ship to ship in the KMM DD book (which is tricky as the perspective shifts subtly between photos), it does appear that the Type I�s forecastle break starts its transition a few meters aft the end of the bridge, whereas the forecastle break for the later types appears to begin few meters further aft, closer to the front of the #1 funnel. The first photo posted in this CASF, that of Isonami and Uranami, exemplifies this difference reasonably well as the photo angle is almost identical. Another key is the length of the triangular side plating that marks the transition between the decks.
Perhaps a better set of comparisons can be seen below. The cropped photo of Type I Usugumo�s bridge is at exactly the right angle to show the transition from the forecastle deck to the main deck. Compare that to the similar photo of the Type II Ushio and I think you can get a good sense of what I am trying to illustrate.
A review of the photo record also reveals that not all Type I vessels had the short forecastle. Two of them, Hatsuyuki and Murakumo, were built with the long forecastle. I�ve no idea why that is, other than as a prelude or test for the succeeding Type IIs. My Japanese source stated that the only the Type I lead ship from each yard had the short version, which would mean several more vessels with the longer forecastle, but the photographic record simply does not bear this out.
A good photo of Hatsuyuki depicting her longer forecastle is also depicted below. Note the length of the triangular side plating, along with the additional portholes typical of the long forecastle ships.
From a modeling perspective, this difference goes along way towards explaining why the old Tamiya 1/700 Fubuki kits are so frustratingly inaccurate. A quick comparison between Tamiya and PitRoad reveals that the Tamiya hull is (relatively) accurate only for the Type I. The late Types cannot be built using the Tamiya kit without heavy scratchbuilding.
Interestingly enough, the new PitRoad Fubuki offerings include a long forecastle Type I kit marketed as Shirakumo. While Shirakumo would seemingly qualify for this distinction under the qualifier of the lead yard ships, the photographic record says otherwise. So, the kit should probably built as Hatsuyuki, Murakumo or, (special bonus) Uranami, as Type II funnels & intakes are included in the kit sprues. In fact, you would need this particular kit to make Uranami.
One last note on forecastles: While the PitRoad Type II/III kits depict an overhang under the extended rear of the forecastle deck, this space was actually filled by compartmentation. See the photos below of the Type II Ushio or Sazanami, and the Type III Akatsuki.
- Gilbert
- L'Arsenal
Thanks a lot Dan for sharing these very useful infos.
Would it be possible for you to list the ships which could be actually built with the existing kits ?
TIA
cheers
Gilbert
TIA
cheers
Gilbert
No, problem, Gilbert.
The PitRoad Fubuki kit & the Tamiya Fubuki/Hatsuyuki kit can be used to build all the Type I's except Hatsuyuki, Murakumo & the Type 1a Uranami. So, that would include:
Fubuki
Shirayuki
Miyuki
Shinonome
Usugumo
Shirakumo
Isonami
The PitRoad Shirakumo kit can be used to build Hatsuyuki, Murakumo or Uranami. Neither Tamiya Type I kit is appropriate for these 3 ships.
None of the other Tamiya Fubuki class kits (Ayanami, Shikanami, Hibiki & Akatsuki) is really appropriate for building a Type II or III. The other PitRoad kits are good for their respective types. I will be going into more details/corrections for those kits when time allows.
DK Note 11/19/10 - PitRoad has just released it's Type I kit as Shinonome 1941. Odd choice as her combat record was all of 2.5 weeks, sunk with all hands after being bombed by a Dutch flying boat off the NEI and having her aft magazine explode. The same ship limitations apply to this boxing as they did for the Fubuki boxing. PiRoad took the easy way out on the box art, too, taking the Fubuki boxart and changing it from a night to daytime setting. Lame. Compare.
Fubuki
Shirayuki
Miyuki
Shinonome
Usugumo
Shirakumo
Isonami
- Gilbert
- L'Arsenal
Thanks Dan, this is a good guideline to prevent fatal mistakes in builts
cheers
Gilbert
cheers
Gilbert
- J. Soca
Suberb job compiling all this info in here Dan
, i thank you for taking your time.
Jose
Jose
Main Armament
All the Fubuki Types carried three twin mountings of the 12.7cm, 50cal DP weapon. However, these guns were carried in 4 successive turret types.
All the Type Is, and Uranami, carried Type A turrets. An improved mount, known as Type B, allowing a higher level of barrel elevation was introduced with the first Type II ship, Ayanami. All the Type II & III ships were so equipped. The Type B turret underwent two revisions known as B1 & B2.
Contrary to the information carried in some publications, Type I ships & Uranami carried the Type A turret throughout the war. The upgrade to the B1 turret occurred in the early to mid 1930s, the final upgrade to the B2 version seems to have taken place in the 1936-1938 timeframe. It varied from ship to ship. Also contrary to the information carried in some publications, the Fubuki Type IIIs were not upgraded to a Type C turret.
Edited 1-26-2012
It's come to my attention that the change to the B2 turret was limited to ONLY mount #1. This seems to be an often missed detail (certainly it was for me) as there just aren�t that many clear, detailed photos of #s 2 & 3 turrets of the Fubuki class units from the immediately prewar and early war periods. Fortunately, there are high quality photos of Sagiri and Sazanami in 1940 that confirms this mix of turret models.
Some illustrations and pics below.
Type A, B, B1, & B2 drawings
Type B2 turret pic, #1 mount, probably aboard Akebono
Edited 1-26-2012
- Type B2 turret drawing small.jpg (51.8 KiB) Viewed 49649 times
- Type B2 turret #2 small.jpg (85.28 KiB) Viewed 49647 times
Another misconception (probably initiated by the Tamiya Fubuki kits), is the size of the Type A turret. Many seem to assume it is significantly smaller then the Type B turrets but, this is not so. The two turret types are comparable in height and length; only the width of the B turret is significantly greater. The weapon is the same except for the improved elevation in the later turret.
Some size comparisons below:
A cropping from a photo in Maru Special #17 with 3 of the DDs from DesDiv 19, circa 1931. Uranami with Type A turrets is on the left, Ayanami & Shikanami with the Type B turret are center and right, respectively.
Type A vs. Type B in Gakken #18
Three Type A turrets are available in 1/700: the turrets from the original Tamiya Fubuki/Hatsuyuki kits, the A turret from the new PitRoad kits, and the Type A turret from the PitRoad Equipment Set E-02 (formerly #38). The Tamiya turrets are nicely shaped but too small. The turrets that come with the PitRoad Fubuki kits aren�t bad either, but also too small. Only the A turrets from the E-02/38 set are correctly sized and detailed.
Two Type B turrets are available: those that come with the new kits, and those from the E-02/38 set. Again, IMHO, the those from the E-02/38 set are more correct.
Three Type B1/B2 sets are available (B1s differ from B2s in the details of the turret side vents and stiffeners and none of the available units has this detail on the sides; it has to be added.): from the PitRoad E-10 Equipment Set (one tree is included with each of the new Fubuki kits), from the older PitRoad E-02/38 set, and from the Leviathan/Tamiya/waterline consortium IJN Light Ordnance set for 1/700. Although a hair oversized, either PitRoad choice is far superior to the Leviathan/Tamiya offering, which is too small, and not as well shaped. Again, IMHO.
- Gilbert
- L'Arsenal
Hi Dan,
Thanks a lot again for sharing with us these detailed infos
. With all the information gathered, you are on the right path to publish in future a booklet fully dedicated on IJN Fubuki class. If this appears, I will definitely get one
cheers
Gilbert
cheers
Gilbert
THx, Gilbert. Perhaps you can publish it.
Funnels
Type I � As originally completed, Type I funnels were capped with barely raked funnel grills. The previously posted photo of Usugumo�s bridge and forecastle break shows her #1 funnel in this configuration to good effect.
It appears that the funnel caps were refit and revised at least twice. The first time, the caps/grills were raked at a greater angle and topped out considerably taller than as built. They were subsequently lowered in the mid 1930�s, retaining most of the rake angle.
In terms of overall funnel height (to the top of the raked grill), the final configuration seems to top out about even with the top of the canopy covered lookout station atop the compass bridge level. The previously posted photos of Isonami or Usagumo 1936 on p. 1 of this thread, are a good illustration of the relative height of the funnel to the bridge. It is also worth noting that Type I funnels are noticeably thinner in profile then Type II and III (excepting fore funnel) funnels. There also may be some slight differences in cap angle/height between Type I ships.
The funnel design for Type II�s changed to a funnel approximately 20-25% wider in profile that the Type 1s. The earliest Type II�s (Ayanami & Shikanami, along with Type 1a Uranami ), were completed with funnel caps in the same flat manner as the original Type 1 configuration. These ships were later revised to higher cap with greater rake as illustrated by the Type II photo comparison below (Ayanami shows original funnel cap configuration, Amagiri shows revised funnel cap configuration, as does Oboro). Later Type II ships were completed with the raised arrangement.
