And here is part 3:
Second heavy-weather test:
http://www.youtube.com/watch?v=4NBjZzGX19A
Movie of the second heavy weather test.
First i needed to put the ballast in her, but by then she already was being hit by waves making it hard for her.
From the other side.
A very brave lady, giving more when she needs to in order to able to make it back home.
Pretty much list
Pretty much movement, but she moved slower then the waves, making her to hit the first wave with the bow pointing down, and the second with the bow pointed up.
Even the bulb came above the water.
Pretty much list again.
Made an new anchor, but that kept sinking.
It did keep the Well Enhancer in position.
Riding at anchor.
I bought a ROV (a RC model) for demostrations, and after having returned home i started working on the A-frame, which is under construction over here.
Since i'm using a gas-thing for soldering brass my soldering has improved quite a lot, and here is 1 of the results; the A-frame itself is mounted onto this.
My last sheet of Evergreen is being used to build the new outside of the superstructure.
When the outside is finished i will sand the wooden parts so they will fit inside it.
My idea for making the A-frame move is to build a cilinder and pump water in it at low pressure so that it will move, but that it isn't a danger on the water.
As the A-frame doesn't need to lift heavy stuff the pressure won't need to be that high.
All other progress is on the crane.
It starts to rotate now, though not quite as i want to.
A movie of the turning will come later.
Here i'm making a winch for the hoisting-cable.
The dark-blue thing at the background is my new tool for soldering brass.
The flame reaches temperatures of up to 1300degree C.
The moment of thruth coming, the crane is almost going to be placed.
And here it is in place, though it will remain temporarly as both the crane and the cilinders for moving it aren't finished yet.
The crane reaches higher then the tower.
The system for moving the crane up and down.
As you can see in the picture above the crane can turn to a very big angle, making it really very difficult to use this method to move it.
The length of the parts isn't the problem, the hole needing to come in either the crane or the foundation is a problem however.
Sanded the hull a little more due the to placing of the bulwark.
For those who have nothing to do: try to find out where every wire comes into the photo and where it stops, or leaves the photo.
The cilinder in the position for the highest angle.
And the last photo, showing the way of turning the crane.
The problem is that the crane has allways wanted to get out of position creating lots of friction on the parts that are trying to stop it from doing so.
That problem has been solved by supporting it at 2 heights, and now it is turning as the following movie will show, but it doesn't turn as it should be.
http://www.youtube.com/watch?v=o8GieBQMc8s
And a movie of a weird situation on the controls of the crane:
http://www.youtube.com/watch?v=_Y-RxvBW ... re=channel
Forunatly i now have a new transmitter and receiver for controlling this stuff, but that will come in the next pics in this post.
Superstructure has been grinded prior to making the new outer walls which are made of Evergreen.
The new outer walls are under construction.
Started with the helodeck, this will all be grinded and straightened much better, this is a difficult place to work, as it is almost inpossible to build it level with the other parts of the superstructure when it is not aboard the model and there is not much to keep everything in place properly when building it aboard the model.
New helo?
No, it isn't.
First airbrush-work before removing the tape.
And after removing the tape.
Sailing again.
Here in Holland the 40MHz is used for modelboats, but i found some 433MHz transmitters and receivers which are used mostly for turning on and off the heating inside houses and for alarm-purposes, but i will use it for the secondary functions, and i will be able to control 45 functions with it using only 8 channels, without needing special electronics, but just by using 2 buttons per function.
Here is the receiver, which i got as birthday-gift:
There is a switch in the top of the box, but that will be moved to the dive-area in order to be able to turn it on and off without needing to remove the superstructure.
The nice thing about this system is that it uses codes which make it impossible for other transmitters on the same frequency to control my model, but any transmitter on the system can be linked to that single receiver by programming the lot.
My secondary functions will therefore allways work properly.
The rotation of the main crane has been a big problem.
To solve that i decided to check if LEGO gearwheels would fit around the PVC-tube, but while i was doing so i remembered that i also have some LEGO turntables.
I took one of those and tried to fit it in place.
That really wasn't difficult, it appeared that LEGO doesn't make those things for their own models but for the crane on my shipmodel, it fits perfectly with the smallest LEGO-gearwheel on the engine.
Here is a photo of the new stuff:
The only problem is that i will now need to build a new crane-house to connect the arm to the turntable, but that is something i wanted to do for quite a while as well, so there is about no problem left.
Yesterday i ordered a housing for the new transmitter and a bowdenkable for making the crane-arm move up and down.
Here is the servo which will used to turn up and down the crane-arm attached to the deck.
Because of maintaince on asipods, couplings and engine's i have decided to just use some large screws.
Started making the winch which will be used to hoist things.
I have also been thinking about how i could best attach the LED's in the mast, and i came out that it would be best to take the entire mast of and completly the wiring so i can turn on and off the lights in such a way that i make the signals that are ordered to use by the law.
By the way, these posts are made using updates that were posted on an other forum, so the text might not be very well for this set-up.
And now you guys are also up to date.
Greetings Josse
Making a complete new Well Enhancer, again scale 1:75.
